Sponsored by: MB Part Haus
FS: 19in DPE S20 3 Piece Wheels 5x112 - $2000 San Diego
Old Mar 25, 2015 | 07:23 PM
MrVu's Avatar
2005 Granite Gray C55
Excellent condition DPE Signature S20 Series 3 Piece Wheels. These wheels were $5428 a set brand new at $1357 per wheel. This is basically a steal. These wheels have no problem, bends, cracks or rashes on the lips at all, come check them out, they are also fully polished, not chrome.
I am selling these for $2000 as I am moving down from 19s to 18s. My loss your gain.
The specifications are:
19x9.5 Front et38
Lip is 2.5inch lip w/ 7inch inner barrel
19x10 Rear et 23
Lip is 3inch lip w/7inch inner barrel
Bore size is universal now as I have taken the adapter ring off the hub. Any car that has 5x112 pattern can run hub rings purchased from autozone to run to your exact hub ring size.
If you have any questions, please feel free to contact me via email or PM
Price is $2000 firm. Preferred local pick up but will ship at owners expense.
Old Mar 26, 2015 | 01:00 PM
jmb614's Avatar
E55 AMG
I imagine these wouldn't fit a w211 E55 without fender pulling?
Old Mar 26, 2015 | 01:46 PM
MrVu's Avatar
I am honestly not good at figuring out the offsets and fitment but I do have a couple of buddies that are pretty knowledgeable in wheel fitment.
What set up are you currently running?
Old Mar 27, 2015 | 01:03 PM
jmb614's Avatar
E55 AMG
Stock
Old Mar 27, 2015 | 05:49 PM
MrVu's Avatar
Stock
would you know the offsets of them? And the tire specifications as well
thanks
Old Mar 28, 2015 | 01:47 PM
MrVu's Avatar
Bump! Fixed the broken pic images.
Old Mar 29, 2015 | 05:01 PM
Panduh's Avatar
Slow Ones!
This is a great deal for someone. 3 weeks ago I would have been all over these.
Good luck with the sale, these are some awesome wheels at an awesome price!
Old Mar 30, 2015 | 06:06 AM
MrVu's Avatar
Thanks brotha! Hopefully these get sold soon!
Old Mar 30, 2015 | 10:34 PM
Twaz's Avatar
E
I'd be all over these, but I doubt the rears would fit my w211 without body work.
Great deal! good luck
Old Mar 31, 2015 | 04:42 AM
MrVu's Avatar
I'm just going off the E63 wheel specs. I used http://www.willtheyfit.com to calculate the offsets.
Fronts:
245/40 18 18x8.5 et38 (with 12mm spacer to clear calipers, so it would be et26)
Compared to your existing wheel, this new wheel will have an inner rim which is 0.7mm closer to the suspension strut.
The outer rim will poke out 24.7mm more than before.
Rears:
265/35 18 18x9.5 et39
Compared to your existing wheel, this new wheel will have an inner rim which is 9.6mm further away from the suspension strut.
The outer rim will poke out 22.4mm more than before
All in all, I believe it would fit but I am by no means an expert on this.
w203 and w211 stock wheel offsets are not far off by any means.
My 07 w203 stock offsets are et36 front and et34 rear, while the w211 stock offsets are et38 front and et39 rear.
If you're lowered or slammed, I would definitely get fenders rolled. Good thing getting fenders rolled are relatively cheap though
With this set up, I believe you should be flushed with the fenders.
Old Apr 5, 2015 | 05:02 PM
MrVu's Avatar
Bump, still available!
Old Apr 8, 2015 | 02:42 AM
MrVu's Avatar
Old Apr 9, 2015 | 03:17 PM
BlessedByJesus's Avatar
2007 CLS 550
do these fit the w219 cls?
Old Apr 9, 2015 | 09:43 PM
MrVu's Avatar
Yes, if you run 12mm or 15mm in the front, the offsets will be et26 or et23 dexpending on how much you want it to stick out.
The rears offsets are fine at where they are at.
Old Apr 11, 2015 | 03:59 PM
MrVu's Avatar
bump
Old Apr 13, 2015 | 02:30 PM
MrVu's Avatar
still for sale
Old Apr 14, 2015 | 06:06 PM
MrVu's Avatar
Sale $2000 obo
Old Apr 17, 2015 | 06:15 PM
MrVu's Avatar
price dropped to $1900
