Mercedes-Benz C-Class and C-Class AMG: Interior Modifications
There are several ways to change your car's interior. Some are more complex and time-consuming than others. Here are some ideas for the C-Class.
This article applies to the Mercedes-Benz C-Class and C-Class AMG (2007-2014).
Interior modifications can be as simple as swapping out the lights or something more complex, such as outfitting your car with new seats. Whether you're in the mood for a small change or a more extensive one, it's possible to save money and complete the project yourself. However, some tasks are tougher and require more time to complete than others. No matter how new or old your C-Class is, you can give it an entirely new appearance with interior modifications.
Whether you're an auto enthusiast or a dedicated car owner, most interior modifications take a bit of time and patience to complete. However, the result is often well worth the effort. In many instances, these DIY projects will save time and money spent at a dealership or in the hands of a professional. Here are some helpful interior modification ideas.
![](https://cimg1.ibsrv.net/cimg/www.mbworld.org/830x600_85/465/c63-amg-interior-hgtqsmiw-68465.jpg)
Center Trim
![](https://cimg0.ibsrv.net/cimg/www.mbworld.org/1024x768_85/460/figure-1-interior-modifications-68460.jpg)
DIY Cost – $200-300
Professional Cost – $400
Skill Level – Easy; Requires a minimal amount of tools.
You can replace your car's stock aluminum trim with a pricier but nicer-looking carbon fiber trim kit. It's not cheap, but simply replacing the center trim can greatly enhance your car's appearance. Before you begin, make sure that the new pieces have the same number of tabs and posts as the old ones. You might need to remove the shifter's base plate if it's blocking removal of the center console piece.
Dome Lights
![](https://cimg0.ibsrv.net/cimg/www.mbworld.org/800x600_85/468/figure-3-replace-interior-lights-68468.jpg)
DIY Cost – $5
Professional Cost – $50-$100
Skill Level – Easy; Doesn't require special tools or prior knowledge.
Swapping out the front dome lights is a fast and effective way to boost your car's interior. Depending on personal preference, you may choose a different colored light or one with unique features, such as extended bulb life. You'll want to have a flat tip screwdriver and a soft microfiber cloth on hand.
Racing Seats
![](https://cimg3.ibsrv.net/cimg/www.mbworld.org/595x382_85/471/11111111-68471.jpg)
DIY Cost – $1,500+
Professional Cost – $2,000+
Skill Level – Difficult; Professional skill required.
If you plan on bringing your car to the track (or just want the interior to look a bit sportier), then swapping out the seats is one solution. Before getting the seats installed, you'll want to make sure that the new seats are compatible with the car's OEM seat belts. Unless you've done a similar DIY project before, it's best to leave this task to the professionals.
Steering Wheel
![](https://cimg1.ibsrv.net/cimg/www.mbworld.org/640x480_85/473/figure-5-steering-wheel-replacement-68473.jpg)
DIY Cost – $1,000+ due to cost of airbag
Professional Cost – $1,300+
Skill Level – Moderate to Difficult; Requires separate steering wheel and column.
Some drivers prefer to swap out steering wheels. This could be for aesthetics, safety features such as airbags, or features such as steering wheel mounted controls. Unless you have previous experience, it's a good idea to leave this task to the professionals as certain airbags and steering wheels have specific characteristics unique to particular models and years.
Related Discussions
- DIY Interior Trim Replacement - MBWorld.org
- DIY Interior Light Removal - MBWorld.org
- Status Seats for Your W204 - MBWorld.org
- 2012 W204 Steering Wheel - MBWorld.org
