Old Jun 11, 2015, 01:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
2012 W204 steering wheel on 08 C350
Old Oct 19, 2011 | 12:38 AM
DCTMOTORSPORTS's Avatar
SPONSOR
W211 Estate
We just test fit the 2012 C63 steering wheel with airbag on a C350
Attached Thumbnails 2012 W204 steering wheel on 08 C350-img_8200.jpg   2012 W204 steering wheel on 08 C350-img_8203.jpg
Old Oct 19, 2011 | 01:22 AM
steven1888's Avatar
2008 c350 sport
That looks awesome ..
Old Oct 19, 2011 | 03:35 AM
CA-C300's Avatar
W204 C300 09' (GONE) W205 C63S Edition 1 Estate
WOW!
Old Oct 19, 2011 | 04:48 AM
GINGER's Avatar
C219 CLS 500(sold), R171 SLK 350(sold), W210 E320 (sold), W204 C280, W221 S500
is it a direct bolt on? how much?
Old Oct 19, 2011 | 09:14 AM
until the end's Avatar
2009 c350 arctic White pano. MM HK
Awesome
The lights of the botons do thay work??? And all botons function is ok ??
Old Oct 19, 2011 | 10:38 AM
matthew121170's Avatar
2012 E350 - Cabrio; 2017 GLS 450
What about the paddle shifters, do they work now too?
Old Oct 19, 2011 | 12:06 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
gonna run you at around $1.0-$1.5K with new bag
you can get the wheel by itself off ebay (search the forum for my previous post) for around $500 sometimes
Old Oct 19, 2011 | 02:19 PM
Sportstick's Avatar
Another round of ICE
A word of caution....with the changes to the 2012 model for the new engine based on size, mounting, kinematics during impact, it is possible that the crash pulse of the vehicle may have been modified, therefore also changing the air bag deployment characteristics. I would be very careful before making the swap to determine if the part number of the new air bag is compatible with the pre-2012 car receiving it, if Mercedes-Benz will even offer that information. This is far beyond swapping out radios!!
Old Oct 19, 2011 | 08:14 PM
SPONSOR
W211 Estate
Originally Posted by until the end
Awesome
We are working on the lighting part, other than that, all remote control buttons work.
Old Oct 19, 2011 | 08:18 PM
SPONSOR
W211 Estate
it is the car telling the airbag when to work, not the airbag tells the car how airbag works
This same airbag is generally used on W218 CLS, W204 2012 C-class and W207 new E class, I believe different car models have different deployment characteristics, but when the car ask the bag to pop, the bag will pop.
Old Oct 19, 2011 | 08:34 PM
Sportstick's Avatar
The vehicle's sensors measure the change in vehicle velocity, resulting in a deploy/no deploy decision. However, the size, shape, and rate of inflation are characteristics of the specified air bag module. Each of those characteristics is designed with consideration to the specific vehicle's crash pulse and frontal deformation. There are more variables involved than whether or not the air bag "pops". Installing an air bag which MB does not approve for the vehicle is asking for potential injury.
Old Oct 19, 2011 | 08:43 PM
rb23lb's Avatar
you also need the new steering column for 2012 retrofit
dont forget you also need the new 2012 steering column or else your buttons wont all light up on the wheel and work
quoted from other thread:
Here is the part you need
A212 900 7702 (9051).
The code 9051 is color code for Black. The price is about 350€."
Old Oct 20, 2011 | 04:20 AM
TonCoronel's Avatar
Mercedes ML350, Mercedes C63 AMG
Ive got the 2012 steering wheel and airbag module also and am going to install it next week. I was aware that for the lighting to work that there should be a new steering column installed.
But shouldnt it just be a cable harness change that is needed? Everything else is working like buttons and shifter paddles. I would assume that the + or ground (or both)for the lighting just changed location on the harness? or is it completely different?
Old Dec 16, 2011 | 10:03 AM
miloc204's Avatar
w204 amg
is it posible to write part numbers of the steering columns that needed in order to have light in the buttons?my car is european version but i think it doesn't matter...
Old Dec 16, 2011 | 09:59 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Think it will fit on a 2010-2012 GLK?
Old Dec 16, 2011 | 10:07 PM
acr2001's Avatar
2012 C300 4Matic
This +10000.
DCTMOTORSPORTS, just like Sportstick said - the SRS system is merely sending the airbag a deploy signal (stage 1 or 2).
The airbag is designed to have VERY specific characteristics that depend on the vehicle itself in a multitude of ways.
An airbag from one model of Mercedes might look completely identical, and will fit and plug into another model without triggering an SRS light. It is still very likely to have very different deployment characteristics based on the vehicle it was meant for - it could inflate faster, slower, and in different directions. Many airbag designs have been changed during crash testing because they either hurt or under-protect the test dummy. The wrong airbag might fail to properly protect you in a crash or it might snap your neck.
Your insurance company would have a field day if you had an accident and they found out about this.
Old Dec 19, 2011 | 09:39 PM
SPONSOR
W211 Estate
Originally Posted by acr2001
This +10000.
Thanks for the advise, we will inform our customers about what have been mentioned above and just sell these as original Mercedes parts so customers make their own decision putting on these parts on their cars!
Old Jan 31, 2012 | 06:16 AM
emerged's Avatar
08 w204 c350 || 06 Audi a4 2.0T
while searching i stumbled upon this thread, by chance do you have a DIY for this?
thanks!
Old Jan 31, 2012 | 02:42 PM
tasho3's Avatar
2014 C63 Sedan
can you put this on a c300 with no paddle shifter and make the shifters work?
Old Jan 31, 2012 | 03:54 PM
jl9j's Avatar
2009 C63 AMG
I love this. I hate the 3 spoke wheel that I currently have on the W204 and think the new wheels look hot.
Can anyone tell me if I can get a wheel without paddle shifters and stick it on my w204?
Thanks in advance
Old Jan 31, 2012 | 05:34 PM
tasho3's Avatar
2014 C63 Sedan
Thanks in advance
I'm with you on the 3 spoke, I prefer the non sport model steering much better
Old Feb 1, 2012 | 08:10 AM
jl9j's Avatar
2009 C63 AMG
YES!
If I can't have a w204 4 spoke wheel, at least I want the 2012 steering wheels.
Old Mar 7, 2012 | 04:59 PM
C63sydney's Avatar
C63 ML350
Update???
Old Jul 2, 2012 | 05:37 PM
Hamza458's Avatar
C280 Sport w204
Hi all, I have just installed the new 2012 s/wheel on my 07 C280 sport W204 saloon, all functions work fine including the paddles except the lights and wanted to know if anyone knows for certain if there is a way to get the lights on the s/wheel to illuminate without also changing the column?
Thanks in advance
Old Jul 2, 2012 | 05:45 PM
JimPap's Avatar
2008 C300 Sport, RWD, US
snip
Thanks in advance
Pros.....I love the shape.
Cons....A little too much metal.
Leather is of a slick variety. I prefer the textured type better.
