Mercedes-Benz C-Class: Average Maintenance Costs
Before you purchased or leased your Mercedes-Benz C-Class, whether new or pre-owned, chances are you did some homework to make sure you received the best value for your money. The same should go for finding the right factory-authorized service facility to take care of your investment. This article is about the recommended maintenance intervals for your C-Class, and how much it might cost.
This article applies to the Mercedes-Benz C Class w204 (2007-2014).
In addition to the recommended maintenance schedule provided in the maintenance booklet, your dashboard has indicator lights alerting you to servicing needs. The schedule in the booklet is based on time and/or miles driven. Since 1998 Mercedes has also been using a Flexible Service System (FSS), which has indicators that appear in the middle area of your instrument cluster.
The way you drive, driving conditions, climate, engine warm-up time, as well as altitude are some of the things the FSS monitors, and gives you a more accurate time to service your vehicle. A picture of a wrench will appear in the middle of the instrument cluster telling you that service will be needed soon. It will count down the miles until it is due.
Edmunds.com lists average maintenance costs for a C-Class w204 between $6,000 to $8,000 over a five-year period.
Here is the recommended C-Class w204 maintenance schedule outlining "A," "B," and "C" services as well as their costs.
FSS Service "A"
This is the most basic of scheduled service for your car. Basically, it's an oil and filter change. Mercedes-Benz (MBZ) also recommends checking all fluid levels, a brake component inspection, and a tire inflation check. The dealership will also do a function check on all of your lighting systems, check your wiper blades, check the hood latch, and check the battery. The "A" service is recommended at the first 10,000 to 13,000 miles, or one year. After that, it should be done every 23,000 miles or two years. The "A" service indicator wrench icon will come on and tell you how soon that service is required.
C-Class owners report costs between $200 to $340 for an A1 service. The number signifies the number of times an FSS service has been performed. A1 makes this the first service in this category. A suggestion would be to shop around by calling several dealerships and qualified service facilities to get the best price because they will vary. An oil and filter change on a w204 is pretty straightforward. If you are a DIY type, you can do it yourself. Just save the receipts for your service records.
![](https://cimg2.ibsrv.net/cimg/www.mbworld.org/750x365_85/846/JPEG-3-Removing-Oil-Filler-Cap-and-Filter-65846.png)
FSS Service "B"
At approximately 20,000 miles or one year after your "A" service, the "B" service wrench icon will appear. Again, it will display the number of miles you have left before the service is required. The "B" service is recommended typically every 20,000 miles or two years, while the "A" service repeats every year.
The "B" service includes another oil and filter change. This service interval also includes the change of the cabin air filter, and a change of brake fluid. Additionally, MBZ suggests checking the poly-V belt, tire pressure, and all fluid levels.
Again, w204 owners report a wide range of prices for this service when performed at a dealership. Costs are reported from $350 to $650. Once again, you may want to shop around for the best value. Keep in mind that the best value is not necessarily the lowest price.
Maintenance Intervals and Service Recommendations For the First 50,000 Miles:
- 1yr/10,000 - Service A1: Oil and Filter Change
- 2yr/20,000 - Service B1 : Brake Fluid and Cabin Filter
- 3yr/30,000 - Service A2: Transmission Fluid Flush
- 4yr/40,000 - Service B2: Brake Fluid, Engine Air Filter, and Cabin Air Filter
- 5yr/50,000 - Service A3: Spark Plugs
FSS Service "C" and Beyond
As mentioned earlier, MBZ recommends maintenance based on time/mileage. The FSS monitors your car based on your actual driving conditions. This means that service is suggested when it is needed. Codes "A" and "B" signify the maintenance that is recommended based on time and driving conditions. Service "C" usually includes a coolant flush, transmission fluid change, and oil change. This service runs about $600 dollars, and is due when the FSS senses it through its monitoring system. The FSS service codes run from "A" to "H." The higher the letter, the longer the actual servicing will take. Figure 3 shows the codes and the time it takes to perform the service.
Figure 2. Service "D" indicated. Figure 3. Service chart for your vehicle.
Remember, by following your car's recommended service schedule and servicing it efficiently as well as economically, you will get the most from your "investment."
Related Discussions, and Site
- C-Class Maintenance Costs - MBWorld.org
- 40k Mile Service Head's Up - MBWorld.org
- Flexible Service Schedule - MBWorld.org
- What Does Service "A" Entail - MBWorld.org
- Service "B" - MBWorld.org
- True Cost of Ownership Tool - Edmunds.com
