C280 Build Thread
Rating: Thread Rating: 3 votes, 5.00 average.
Old 04-11-2014, 07:01 AM
  #76
vinceC's Avatar
2014 ML350 4Matic
If it has the early tensioner it is very hard to tell if it is failed (or going to fail soon). I actually clamped mine in a vise and tried to test it with a large wrench and it seemed OK, yet it failed two weeks later. It is easier to change it now with the extra room available.
Old 04-12-2014, 05:15 PM
  #77
jenk_ins's Avatar
C280
Good point. I will get one ordered.
Got the timing chain installed
Timing Covers installed, and new front seal.
Timing Chain Tensioner installed.
Throttlebody installed and wired/cabled back up
Got the oil pan and tranny pan installed hard to see the powder coated blue color in the dark picture
Old 04-13-2014, 05:45 PM
  #78
jenk_ins's Avatar
C280
worked on getting the carpet changed from tan to black. The dye didn't work, it just turned it a purple-ish blue color. I'm actually using some interior paint designed for carpets and vinyl. It's actually working pretty well.
Old 04-16-2014, 11:55 AM
  #79
mickey13's Avatar
1999 AMG C43
Nice write up. Keep it up.
Old 04-17-2014, 10:45 AM
  #80
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Glad to see this Project continued!
What did you use for painting the carpet. Does it still feel soft after painting?
Old 04-20-2014, 12:22 PM
  #81
jenk_ins's Avatar
C280
Right now it's got that "stiff plastic" feeling, but I was told to just brush it with a stiff or even soft wire brush to breakup the fibers and it should soften up.
ON with the build!
Got the timing chain tool in the mail. Installed the timing chain link
Crimper on the chain.
Crimped timing chain link.
Valve cover installed
Installing Coils
Old 04-20-2014, 10:35 PM
  #82
Redneckgearhead's Avatar
2005 c230 kompressor
Nice progress.
Old 04-23-2014, 12:57 AM
  #83
jenk_ins's Avatar
C280
Got some more done tonight
Got the intake installed, vacuum hoses connected and Fuel rail and Injectors installed.
Wireing Harness starting to get connected all up
Hoping I may actually get to start it in the next week or so! We'll see how everything goes.
Old 04-23-2014, 01:14 AM
  #84
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Very good job MaaaaaaN....,
LOVE that Blue either.....
ZAYED,,
Old 05-05-2014, 03:44 AM
  #85
jenk_ins's Avatar
C280
Installed steering rack, getting ready to install exhaust manifolds
Installed exhaust manifolds
Got the accessories installed
Radiator Installed
Got the rear carpet put back in.
And the front carpet
I also got the headliner installed, but I didn't get any good pictures of it. I'll try to get some with better lighting. Also filled it up with fluids, and cranked it over with the fuel relay pulled out to make sure everything was good to go. Now I gotta go buy some gas and put the relay back in for the actual first start test!
Old 05-05-2014, 08:03 PM
  #86
jenk_ins's Avatar
C280
I used some interior spray paint by a company called SEM
So got the car started today. here's a couple videos.
First Start!
Short clip of it running after it warmed up.
Old 05-06-2014, 05:37 PM
  #87
ptcruiser's Avatar
C230
As one of the many watchers from the beginning, I wondered why you didn't do the engine compartment when you had the engine out?
Just a question, not a criticism, which I am sure some people will jump all over.
Old 05-10-2014, 10:49 PM
  #88
jenk_ins's Avatar
C280
This is going to be a driver, not really a show car. If I do anything to the engine bay, it'll probably just be plastidip.
Old 05-10-2014, 10:50 PM
  #89
jenk_ins's Avatar
C280
Decided to try ditching the belt driven fan. We'll see if this electric one can keep up.
Installed the electric fan on the radiator.
Mounting straps for the fan
Removed the fan pulley, and bought a shorter belt.
And the final install with very little room to spare!
Video of the Car and Fan running.
Old 05-10-2014, 11:07 PM
  #90
cm60k's Avatar
That's great MaaaN, Thankss for sharing..,
what's the out-put power of this fan..?,
as i remember the W202/W210 OEM electric fan power is "430W", isn't..??
ZAYED,,
Old 05-11-2014, 12:16 AM
  #91
jenk_ins's Avatar
C280
I'm not sure what the power is, I think the only stat it had was like 1500cfm. I wasn't aware that any of the w202's came with an electric fan. Maybe I should have just tried to fine one of those! haha. The one I bought is a Flex-A-Lite universal fit fan.
Old 05-11-2014, 10:57 AM
  #92
cm60k's Avatar
Whatever, you do a Fantastic job...
ZAYED,,
Old 05-11-2014, 05:42 PM
  #93
vinceC's Avatar
2014 ML350 4Matic
The W202 V6 cars don't have engine driven fans. They use a variable speed electric fan controlled by a module in the left wheel well.
Old 05-14-2014, 12:48 PM
  #94
jenk_ins's Avatar
C280
that would make sense, there's probably a little more room between the radiator and engine on a V6 verses an I6
Old 05-15-2014, 10:54 PM
  #95
jenk_ins's Avatar
C280
Found a vacuum leak while removing the transmission wiring harness. The hose going to the MAP sensor had a hole in it.
Got the new transmission harness!
Installed and ready to hook up.
Old 05-16-2014, 03:14 PM
  #96
jenk_ins's Avatar
C280
Got all the LED lighting installed. Here's a couple videos.
Front turn signals / parking lights. Went with switchbacks.
Also converted all the rear to LED. The lower tail lights don't actually flash as they appear to in the video, just an anomoli.
Old 05-16-2014, 04:47 PM
  #97
Mirza210's Avatar
W210 E300 TD (SOLD) W220 S400 CDI & W211 E500/E550
Looks good! Only thing i would change is the color of the car and the rims but it looks very well!
Old 05-16-2014, 05:39 PM
  #98
ruzhkata's Avatar
Mercedes Benz C280
About the front bumper cover
I was wondering is that the "polish" bumper cover from e-bay, about the front one. Looks like prior design.
Old 05-16-2014, 06:59 PM
  #99
jenk_ins's Avatar
C280
The color of the car is going to be Matte Blue Metallic as shown earlier in the thread. Nice rims seem to be hard to find for these cars. These were good wheels and a great price.
Yes it is the S-Tuning Body kit shipped in from Poland.
Old 05-22-2014, 07:37 PM
  #100
jenk_ins's Avatar
C280
Made some more progress today.
Wrapped one of the mirror covers.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C280 Build Thread
