C280 Build Thread
Rating: Thread Rating: 3 votes, 5.00 average.
Old 06-09-2013, 03:31 PM
jenk_ins's Avatar
C280
The Garage Helper was in Texas this weekend, so when she got back she came out to look at the work that I did on the headliner.
Old 06-12-2013, 05:36 PM
jenk_ins's Avatar
C280
Started painting some of the trim..
Old 06-12-2013, 07:22 PM
jenk_ins's Avatar
C280
Dash painted. (having the window replaced, so didn't bother taping it off. haha.
Old 06-12-2013, 10:47 PM
jenk_ins's Avatar
C280
Started tearing down one of the seats.
Old 06-13-2013, 12:14 PM
jenk_ins's Avatar
C280
Here's a pic of my first attempt at a leather seam on re C Piller. Not too bad, still have to tuck the edges, but it turned out pretty good. The leather didn't want to wrap where the compound cure is, so I put a seam there. (well the garage helper did anyway)
Old 06-13-2013, 12:25 PM
BVC500's Avatar
2016 GLC300 (prev 99 C43 AMG)
Hey, I see that you removed the wood strip on top of the dash without removing the dash. How did you do that? Thanks!
Old 06-13-2013, 12:36 PM
  #32
jenk_ins's Avatar
C280
you just pop off the passanger side corner, then pull the entire strip toward the passanger side. it just has a slide locking system on all but the last clip on the passanger side.
Old 06-13-2013, 12:40 PM
  #33
aquinob's Avatar
2010 E350, Sold 1998 C230
I knew you might have problems on the c-pillar, I know I did. Nice job. So are you covering all the pillars in leather to match the seats?
Old 06-13-2013, 12:51 PM
  #34
jenk_ins's Avatar
C280
yep, they'll all be black with blue stitching.
Old 06-13-2013, 02:28 PM
  #35
aquinob's Avatar
While you have the dash apart, did you check the operation of the vent door actuators? If you have the digital control for the HVAC, then you most likely have the pneumatic bellows that with age all start to leak causing the system to open and close them with changes in engine vacuum. Not the hardest thing to fix, especially if you have most of the dash torn apart in the first place.
Old 06-13-2013, 04:00 PM
  #36
jenk_ins's Avatar
C280
I know for a fact that this car has that issue, and I planned on looking up the fix while it's apart. Do you happened to know if there is a writeup on the repair?
Old 06-13-2013, 04:59 PM
  #37
aquinob's Avatar
Ask and you shall receive: http://www.zadefaraj.com/dashboard.htm
Old 06-14-2013, 01:04 PM
  #38
jenk_ins's Avatar
C280
awesome thanks!
Old 06-16-2013, 12:51 AM
  #39
jenk_ins's Avatar
C280
worked some more on the seats today. Got all the parts ripped apart so I can use them as patterns. Got the first panel made for the seat bottom.
Also started working on the sunroof shade. I'm not a fan of the louvers in the factory shade, so I decided to fill them with fiberglass before I wrap it with headliner material.
Old 06-19-2013, 11:06 PM
  #40
jenk_ins's Avatar
C280
got the head back from the machine shop today.
Also started sandblasting the valve cover so I can have it powder coated
Old 06-21-2013, 10:13 AM
  #41
ptcruiser's Avatar
C230
Amazing how something for free can end up costing a bundle.
Regardless, the end result is the reward, and it seems your doing a great job.
Hope to see it finished.
Old 07-03-2013, 09:48 AM
  #42
jenk_ins's Avatar
C280
cams and caps going back on. Garage Helper is torqueing them down!
Old 07-13-2013, 12:09 AM
  #43
jenk_ins's Avatar
C280
decided to brave the heat today and do some work on the car.
Got the oil pan out. Major PITA!
Removed the old water pump, had to drill the bottom front bolt out as it was striped, I'll never understand why they used hex bolts here, I hate hex bolts.
After dark I went inside and we started working on the upholstery some more. So the Garage Helper was doing 90% of this job.
Tracing the old seat parts..
Getting ready to cut the parts out (no turning back now)
I must have made a bad joke...
Okay, back to cutting
Trimming some of the pieces
Getting her sew on!
Old 07-14-2013, 11:27 PM
  #44
jenk_ins's Avatar
C280
tested our French Stitching skills on some scrap material.
Got the middle piece of the seat bottom done, test fitting the sides, then we'll sew them on!
Old 07-20-2013, 11:11 PM
  #45
Redneckgearhead's Avatar
2005 c230 kompressor
Nice build!
Old 07-22-2013, 11:30 PM
  #46
Cigarsmoke23's Avatar
1997 c280
can't wait to see how this turns out!!! great job so far. any estimation on the total cost of this project?
Old 07-23-2013, 02:52 PM
  #47
jenk_ins's Avatar
C280
no cost estimation. I may go back and calculate after I'm done.. lol...
Upgraded from the old style door panel to the 99 style door panels. Also wrapped the wood trim in carbon fiber vinyl..
New Panel on the door (with wood trim)
New Panel with carbon wrap.
Old 07-23-2013, 08:39 PM
  #48
Where'd you get the cf vinyl?
Old 07-24-2013, 10:00 AM
  #49
jenk_ins's Avatar
C280
I ordered it from a local wholesaler. But you can get it off of ebay very easily. It's 3M 1080 Series Vinyl
Old 08-05-2013, 11:26 PM
  #50
jenk_ins's Avatar
C280
Got some of my parts back from the powder coater. (Oil Pan, Tranny Pan and Valve Cover)
Installed the new water pump. Will start going back together with the engine soon since I got my parts back.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C280 Build Thread
