Carlab Motorsports W203 Adjustable Rear Camber Arm
Adjustable Rear Camber Arm for W203 Model. +/- 4 Degrees. Bolt on Installation. Price is $200 shipped.
The kit consist of:
1 Pair of Adjustable Camber Arm
8 Precision Machined Aluminum Adapetes
1 Packet of Anti Siezed Grease
Regards
Darwin W
The kit consist of:
Regards
Darwin W
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Originally Posted by Guiness Beer Guy
A six pack of beer ! BRILLIANT !!!
What is it ????
What is it ????
2005 C55, 1988 260E, 2000 Chevrolet Silverado
They allow you to adjust the camber in the rear when you lower the car past the designed position. When you start to see your tires wear on the inside or the tire leans inward. This will allow for you to adjust that so it is straight. Or so you can adjust for a positive camber if you decide to run the car on a track.
Super Moderator
nice! how are these different from the speedybnz (www.speedybnz.com) arms though? are they better? or is it just the price point? I think for only $50 more, I'd go with the one that's trusted and has been around for a lot longer especially for something as crucial as my suspension... but, yours could be better, let us know!
and are these better than the kmac kits that you were selling not too long ago?
Super Moderator
bone stock E55 AMG
wow! 200 bux is nice investment to save for uneven tire wear...
from searching around the forums, kmac seems to 'last' longer than speedybenz... not sure what price differences are...
02' C240 Luxury Model
not bad. Haha, would work for guys like me who want even more negative camber...or two even it out a little more depending on which wheels I use at the time.
'09 A4 S Line
MJ, I've never heard any complaints about speedybnz arms not lasting long. I can't think of a reason why they would fail based on the design. It's a pretty standard looking camber arm from what I can tell. I inspected mine after my accident and they seemed to withstand the impact without any problems.
Regards
Darwin W
I had speedybnz camber arms on my sedan and they look identical to these, but a bit more expensive.
Blake,
You should have one installed before you take your car for alignment.
Regards
Darwin W
Regards
Darwin W
is it the same design for the W203 Sedan and CL203 Coupe ?
cool !
me likey.... might have to order a pair, even though I'm not sure I really need them. Might camber is spot-on in the rear. However, would come in handy for tracking. Hmmmmm....
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
cool !
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
I recommend you to get this if you track your car. The factory stock arm is not adjustable. These will allow you to adjust the camber precisely how you want them.
Regards
Darwin W
'09 A4 S Line
2003 C-Class Sportcoupe
Darwin,
I was just about to place an order for the Kmac kit, but I haven't ordered them yet. What kind of insert/bushing does the ball joint have on your kit? Kmac has different options, street-->race. From regular teflon insert to replaceable pillow ball inserts. I was going to order their stage 2 kit, with the replaceable pillow ball insert. Can you shed any light on the differences?
Darwin,
The balljoint is teflon lined. Thank You
Regards
Darwin W
