smart key won't lock or unlock coupe??
Rating: Thread Rating: 6 votes, 5.00 average.
Old 05-08-2011, 12:39 PM
  #51
Jerkin's Avatar
C230 Coupe Silver
Originally Posted by Glyn M Ruck
Let's hope that's the problem.
Yeah. Now it's time to research new interior
Old 05-12-2011, 12:36 PM
  #52
qask's Avatar
Mercedes c180 coupe
My c180 coupe central locking with the key and radio are also not working, the windows are tinted if that makes any difference. What is the solution?
Old 05-12-2011, 03:02 PM
  #53
Jerkin's Avatar
C230 Coupe Silver
Ask the shop if the tint is metalized... And tell them you need non metalized because radio frequency is blocked. Or they could have blown your antenna amplifier with water. Or cut your antenna wires... Read the thread.
Old 05-13-2011, 07:26 AM
  #54
qask's Avatar
Mercedes c180 coupe
I went back to the tint place and they said it is non metalized tint and didnt cut the wires as they cut the tint from the outside, the only possibility left is water got into the antenna amplifier. Does that mean I would need to buy the part direct from mercedes then? £330 they quoted for it.
Old 05-13-2011, 08:51 AM
  #55
Super Moderator
Glyn M Ruck's Avatar
Please make sure that the tint is not metalised. Is the tint applied externally on your rear screen?
You need to buy the genuine antenna amp. You can possibly save money by buying online from the US from one of these.
RMeuropean.com - Parts.com - mymercedes parts.com - autohausaz.com - getmercedesparts.com - genuinemercedesparts.com
Old 05-13-2011, 11:03 AM
  #56
qask's Avatar
Mercedes c180 coupe
It was applied internally on the back windscreen, will have to buy the part and see. Thanks
Old 05-13-2011, 11:48 AM
  #57
Jerkin's Avatar
C230 Coupe Silver
i wouldn't buy it... i would just explain to them that you had it working when you went there.. then all of a sudden it doesn't work and your mechanic said it usually happens when you get your windows tinted because the people do one of those three things. i would nicely go back to the tint shop and have them take off the covers so that you prove to them you didn't touch it because "you don't know how" then inspect the wires very carefully and tell them that the amp must have been blown with the water if the tint is non metalized and that most likely they blew it with water and have them replace it. they may also be lying about the tint being non metalized because they don't want to replace it.. but they would much sooner replace your tint then your amp... i'm having my shop replace the tint this saturday and if it still doesn't work then it's going to be ALLLL BAD.
Old 05-13-2011, 11:50 AM
  #58
Super Moderator
This sounds like a water problem but please check with the tint manufacturer whether the tint is metalised. Half of these tinting shops talk crap. I would still check wiring into the rear screen. They may have damaged it with a squeegy when applying the tint.
Good luck!
Old 05-13-2011, 03:04 PM
  #59
Jerkin's Avatar
C230 Coupe Silver
Good luck!
yeah they told me it will work after replacing the tint... but if it doesn't... then we are going to have a long talk ..... which hopefully doesn't have to happen
Old 05-13-2011, 06:53 PM
  #60
Super Moderator
Yeah - I was aiming my comment at qask
Old 05-13-2011, 08:04 PM
  #61
Jerkin's Avatar
C230 Coupe Silver
Haha yeah I have no idea why I replied to you
Old 08-16-2011, 10:58 PM
  #62
emmruiz's Avatar
c230
Just had my tints done and ran into the same issue where my remote does not work. Will check tomorrow morning if my AM stations work. its been like this for about a week. In any case can someone link me to the sedan version of this on this forum?
Old 02-10-2012, 01:10 PM
  #63
Moderator Alumni
TruTaing's Avatar
w203 m112
Damnit, I just got a tint and this started happening... Glyn, do you have some info about the potential wires that may be damaged?
Thanks,
Old 02-10-2012, 01:53 PM
  #64
Super Moderator
Tru - If you are sure it's not a metallic tint.
It's one of the following if all smart keys are working:
They have damaged the screen itself
They have cut the wires where they exit the screen center top
The sticky pad has come loose center top of screen
They have got water in the antenna amplifier behind the LHS C pillar cover & blown it.
Good luck!
Old 02-10-2012, 02:35 PM
  #65
Moderator Alumni
TruTaing's Avatar
w203 m112
Mine works... Just very randomly. Sounds like its just a bit sketchy - probably loose. They definitely did not install a metallic tint as I was sure to avoid that material. Ill have to take a better look at it when I have a chance.
Thanks for the info!
Good luck!
Old 03-15-2012, 02:42 AM
  #66
auto-links's Avatar
e39 m5
Good luck!
Hi Glyn
I am trying to send you a PM,
is there any way you can clear your inbox?
Old 03-15-2012, 03:27 AM
  #67
Jerkin's Avatar
C230 Coupe Silver
I hate that this ever happened to me... The tint shop eventually installed a new "used" amplifier since they blew the old one.. And it works so much worse than my old on :/
Old 12-09-2012, 01:19 PM
  #68
Septguy's Avatar
2005 CLK 320
Fuse #8 and Remote locking with key
I can confirm that fuse #8 in the trunk controls the RF receiver that works with remote locking/unlocking of the car. It also affects the radio signal as it must have a signal booster for the radio from the rear window antenna. I was looking for a possible bad fuse and removed the #8 fuse and replaced it in the wrong slot. This caused me to not be able to remotely lock and unlock the car except through the direct pointing method at the driver's door handle receiver. I also experienced the scratchy radio reception I saw someone else refer to. Upon doing a bit more research I saw the reference to #8 fuse and upon checking realized i had left the slot open with no fuse. This solved both problems.
Old 12-09-2012, 03:03 PM
  #69
TTR
TTR's Avatar
R129 SL500 & W140 S500
Where should I be telling the installer to be careful and conservative with their squeegee when installing tints? I'm assuming that this is in reference to installing tints to the back window.
Thanks.
Old 10-24-2014, 11:42 PM
  #70
ModeloDrive.com's Avatar
C230 Coupe
Post
BTW - this problem is sometimes caused by a poor antenna earth or damaged antenna wires when tints are done.
Same here, My C230 Coupe 2002 has the same problem. It started immediately after my rear window was tinted, my alarm stopped working. Now it seems to randomly work, about a 1/5 ratio depending on the time of day it seems.
From what I've read this is due to the tint messing with the antenna wires in the rear window that are used to transmit the radio signal to the remote. Both remote batteries changed, all fuses checked, car battery replaced, it must be the tint, too coincidental.
After reading multiple threads about tint and this problem it must be the problem.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: smart key won't lock or unlock coupe??
