smart key won't lock or unlock coupe??
You need to buy the genuine antenna amp. You can possibly save money by buying online from the US from one of these.
RMeuropean.com - Parts.com - mymercedes parts.com - autohausaz.com - getmercedesparts.com - genuinemercedesparts.com
Good luck!
Good luck!
Thanks,
It's one of the following if all smart keys are working:
They have damaged the screen itself
They have cut the wires where they exit the screen center top
The sticky pad has come loose center top of screen
They have got water in the antenna amplifier behind the LHS C pillar cover & blown it.
Good luck!
Thanks for the info!
Good luck!
Good luck!
I am trying to send you a PM,
is there any way you can clear your inbox?
Thanks.
From what I've read this is due to the tint messing with the antenna wires in the rear window that are used to transmit the radio signal to the remote. Both remote batteries changed, all fuses checked, car battery replaced, it must be the tint, too coincidental.
After reading multiple threads about tint and this problem it must be the problem.
