Rough idle at startup? Before replacing your $600 throttle body, fix it for FREE!
After reading the entirety of this thread, I decided the TB (throttle body/actuator) had to be the source of my problems. I believe a new TB is about $600. Instead of immediately buying a new one and replacing it, I decided to see what I could do with my current one, so I took the TB out completely.
I found on the other side of the butterfly flap - the side facing the engine - there was a large amount of oil residue on the flap itself and around the opening. This is the side you can't see or access if you are just cleaning it from the front of the car. I didn't think to take pictures until after I had finished the job.
Anyway, I used some TB cleaner to get all the gunk off to where all you could see was shiny silver. Then I went to work on the internals. I figured since I was possibly going to have to buy a new TB anyway, it wouldn't really matter if I screwed this one up. I removed the 6 or so metal clips that held the black plastic piece on the side and then pulled the plastic piece straight out. The attached picture below is what it looks like with this plastic piece detached.
I used electrical contact cleaner to clean the carbon tracks and little metal "brushes" and then did a few light sprays on the gears and copper connectors and put the cover and clips back on. Note that if you do this, the plastic/nylon gear may fall off but you can just gently put it back in place. I would advise not actually touching the metal "brushes." I cleaned the carbon tracks with a shop towel and was able to get a good amount of black residue off.
I then re-installed the TB and had the smoothest start and idle I've ever felt while owning this car. It has been 2 weeks now and everything seems perfect, so I think I finally fixed the problem and avoided having to buy a new TB. Cruise control is now much smoother than it had been and even on cold mornings the starts and idles are flawless now.
So in summary, I would suggest saving yourself $600 by attempting to thoroughly clean your TB before buying a new one.
From what I found out no one hasn't really fixed this problem. Its leaking somewhere i'm guessing at the head gasket or supercharger gasket.
Thanks for sharing. How is your car running now?
The rough idle started for me again about 10k miles ago.
I just ordered a used throttle body and will be replacing my throttle body this weekend (this will be the third TB in the car). When I take out the TB, I'll check it out and clean it per your recommendations.
I can't believe this now $800 part is a wear item on this car.
Thanks! I'll report back in a couple weeks.
after more than 2 months and did:
1: cleaned TB in\outside.
2:replace 2 hoses under air filter
3:clean MAF.
4:replace all mounten .
there is no error codes.
i still have rough vibration when in red light if AC on +gear on D.
send me whatsapp if u want to join MB group
00971506740840
please help guys
plzzzzzzzzzzzzzzzzzzzzzzzz
hi every body
3:clean MAF.
please help guys
3:clean MAF.
please help guys
3:clean MAF.
please help guys
3:clean MAF.
please help guys
