2005 c230 kompressor engine start up sound and engine shake
Old 02-18-2017, 06:31 PM
Joey Perez's Avatar
2005 C230 Kompressor
So I just got this 2005 c230k at 116k miles and the next day the check engine light came on -_- and I noticed it's pretty loud when starting up but the noise goes away after the car is warmed up about 10 seconds after, also when accelerating I can hear some noise. Today I was getting off the highway coming to a light when I noticed some shaking and the car turned off in drive but it started back up and I was able to make it home but every red light the car would shake. I have no clue what I got myself into..send help
Old 02-20-2017, 09:57 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W203 forum...
did you scan to see what codes came up?
Old 02-21-2017, 08:38 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
So you got check engine light, kept driving the car without checking it, and now want us to tell you whats wrong with no info.
Old 02-21-2017, 12:01 PM
YvngGold's Avatar
2012 c63
It could possibly be a misfire like a bad coil or spark plug check those
Old 02-21-2017, 02:30 PM
dboyrusky's Avatar
2019 GLC300 4matic, 2019 C300 4matic, 2018 C300 4matic, 2009 C300 Flex, 2004 C230 Kompressor
The noise on start up could be the timing chain, i would advise you to check and see if its been serviced yet and if its stretched because it is a problem on these cars (m271 engine).
The shaking at red light can be worn engine mounts but also can be many other things, not enough info to know..
Old 02-21-2017, 03:04 PM
jkowtko's Avatar
2005 c230SS
please post a video ...
Old 02-22-2017, 03:46 PM
Roger161's Avatar
2005 C230 Sport
Have the codes checked out and do the required fix. Shaking.....might have to change your engine mounts. If you're gonna change your engine mounts, change out the tranny mount also since you're at it.
