Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class and C-Class AMG: Why is My Heater Not Working?
Guide to diagnose trouble and recommended solutions
08 C300 Sport - Blower Motor Failure
1 Post
2008 Mercedes Benz C300 Sport | 2005 Yamaha R6
Hey guys,
i have a 2008 C300 Sport that doesn't want to pump out any hot air through the vents / defroster. Upon further investigation, it seems that the early models of this year did not have drainage holes on the blower motor which would freeze up and burn out during severe winter storms. I haven't checked the fuse for this device yet, but i do hear the motor TRYING to push out air when i turn on the vents, but unfortunately nothing is coming out!
What is involved with performing this maintenance myself? It looks like the part online is only ~200, but dealership prices are about ~600.
Has anyone performed this maintenance themselves? is there a how to hidden somewhere here?
Thanks,
Ben
Thanks,
Ben
There was Bulletin for this issue which needed a new cowl with some steel net to prevent ice/ snow entering in the blower. I dont know if this will cover you blower motor issue if out of warranty.
If you take off the battery cover you can see the fan just behind the batt. Give the fan a manual push and it may start by itself . Nothing to lose by trying. I don't think it has a separate fuse from the rest of the hvac
hth
hth
2004 Mazda6, 1993 RX7
Good idea. Or let it sit in a heated garage for 1/2 day, and see if it works ( motor good), icing likely.
If you can get to the fan motor as easily, look for a connector, find ground in supply plug, and supply external 12V + gnd to the motor.
Hi All,
I have the same issue. I just pulled the battery cover off and barely touched the cage while the car was running and it took off. What do you think that would indicate? Motor failing? It has been super cold here the past couple of days but I do not see any ice or moisture in the cage compartment.
2009 C300 4Matic Sport + Premium 2
Hi All,
I park in my garage at night but I still have to manually tap the blower with my fingers to start it. Then if I shut off the car and re-start it I can use the heater speed buttons again and its works fine using the in-car heater options. However If I leave work at night the blower won't start again and I have to manually tap it.
Is it time for me to get a new blower motor??????
wow, I have the EXACT same problem right now. Been like this for about 3 days now. I have an '09.
2009 C230 4MATIC
Hi
I am having this same issue with 2009 C Class, Blower motor stops and then work after giving it a manual push. is it blower motor issue??? Can it be a DIY replacement???
its possible to do this as a DYI but I would say this is a medium-level work. I have to change mine before next winter comes since it will jam again (especially in colder weather). I may have it done but like others have said its not cheap.
MB 2008 C300 sport, 2008 Rally blue Subaru Impreza 2.5 SI 1995 MB C280 W202
MB C300 Blower FAN not working or sometimes
just got mine replaced on C300 08. Out of warranty and cost me $650 plus taxes with my mechanic shop that I know.
the blower been a issue with 08 - 2010 C classs and MB not acknowledge this as a defect. should have this as a recall.
According to my mechanic seem like all C Class from 08 - 2011 have the same issue with blower fan. will failed either after 5 yrs or less. Hopefully you all got this replace under warranty (within 4 yrs). I got C class 300 2008 and the blower fan failed yesterday and the replacement cost me CND $650 plus taxes (part and installed) in Toronto.
Kind of pissed as this is should be recall consider so much failure rate.
bring this to dealer if you still have warranty. yes this is blower fan issue and been well know as mine failed yesterday with replacement cost $650 Canadian plus taxes...incl part and installation.
C350 Sport
Hi
I am new to the forum. I bought 2008 C350 Sport in last March. Two weeks back Cabin Blower Fan started behaving erratically, will stop working in middle of the trip and then will start back on its own. After research I think Fan needs to be changed.
Please some senior member can provide DIY information for changing the Blower Fan. Pictures will definitely help. Also can provide part number for Fan.
How are after market Fans? are they reliable or should go for OEM? Please advice.
Thanks for your help in advance.
2009 C230 4MATIC
Replaced mine, took me 2 hrs (slow novice DIYer). I bought TYC $150.00 CAD, including tax/shipping, it works great !! ..OEM BEHR would have a bit more I guess.
Dealer quote was 800 installed (650 for motor only)... Lots of cash saved !!
mine did the same last winter, just gave it a push last year and ever since its been fine but. called dealer and i think oem one is only about 250$ i might pull the pulg and change it as i don't want to be frozen in this cold Canadian winter
E350 4M (2012), C300 4M Sport (2009)
I had the same problem with mine ('09 c300) this morning. Will try giving the fan a nudge this evening and see what happens. It's been pretty cold, but the car is parked in the garage overnight.
Does anyone know if the blower motor (if that turns out to be dead) is covered under the CPO warranty?
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
Yeap..had this happen in the Canadian Ottawa winter before. At times, pieces of leaves would come rushing out too....I think it's fixed or works okay now, been such a long time I really forget.
Greetings everyone, I'm from New York and the temperature currently here is 2 degrees. My girlfriend mentioned to me that there's in air coming from the vents. This fourm was extremely helpful and solved my problem. All I had to do was remove the battery cover contaiming two clips on each side. I then had access to the blower motor. I simply gave the motor couple of spins with my fiingers and then blasted the fan. but I'm guessing I have to be replacing the motor soon?
This is exactly how I brought mine back to life. After a weekend filled with freezing rain, I wasn't getting anything through my vents when I started the car up the next day. I brought the car into the garage for a couple of hours, opened the garage door, started the vehicle and gave the blower fan a manual spin, and it took off. Make sure you dry the plastic housing you removed to get to it, as mine was quite damp.
blower issue
Yes it was during the summer. I've been out of town for a bit. Had
a friend take care of the car when I was gone. Probably stopped working when it was cold and seized up because when I was spinning it at first it was almost like it was stuck then it became loose and worked fine.
