Oil usage?
Old 01-13-2017, 04:50 PM
johnng117's Avatar
2002 C32 AMG
Originally Posted by insame1
I think this is crap. Maybe if you track the car for a 1000 miles. I have a rear main seal leak and i use about a qt every 5000k miles.
I agree... Sounds crap, where did this info come from? I dont add any oil between oil changes. Your leaking somewhere if your need to add oil.
Old 01-14-2017, 08:32 AM
Smokey31's Avatar
C55 AMG
I have to top up every 3 months or so. No leaks. Its not uncommon for big v8's to use oil.
You are the ones talking crap not MB.
Old 01-14-2017, 11:31 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
So... now that I am on my 3rd car with a m113, 2 of them being AMG's, and non of them consuming oil at that rate I must be full of it right? I would definitely trust hearsay over first hand knowledge.
Old 01-14-2017, 11:36 AM
Rocman8's Avatar
E55
nobody is saying that they will consume that much or should consume that much. This is just simply the Mercedes tolerance range before warranting a repair. So, if you don't consume 1.35 qt in 1000 miles then Mercedes considers this normal operation.
Old 01-14-2017, 02:15 PM
Smokey31's Avatar
C55 AMG
Ive had 2x c55's, so that's more knowledge.
Old 01-14-2017, 03:24 PM
Morphh's Avatar
C32 amg
I have c32 with 61,000 miles and I don't use any between oil changes, I change ever 6000 miles with Driven (Joe Gibbs) 5w40 or red line 5w40
Old 01-14-2017, 06:45 PM
  #32
Smokey31's Avatar
C55 AMG
The point is, every engine is different. Some will use oil, some won't.
Old 01-14-2017, 09:33 PM
  #33
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Math works differently over there, eh? Over here, 2<3.
With a tick over 120k miles, mine uses no oil. No blow-by on startup and I've had friends chop the throttle from WOT and none then either.
Old 01-15-2017, 09:51 AM
  #34
kjb55's Avatar
2016 E350 4Matic; 2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
Just do what I do ... drive it around 300 miles a year, change the oil every 2 years and even if your engine drinks oil - you'll barely notice. Just trying to bring some levity to the discussion. Oil gets burned no matter what - it just variable across engines.
Old 01-16-2017, 08:28 AM
  #35
insame1's Avatar
I'm Just saying if my car consumed 1qt every 1000 miles I would be concerned.
Old 01-20-2018, 08:51 PM
  #36
PJmak's Avatar
Im gonna revive this thread instead of creating a new one.
im thinking about switching to 5/40 instead of 0/40. I am located in northern california and it gets hot here during the summer and dips to 40-60s during this time of the year.
would that be ok to use?
Old 01-21-2018, 10:51 AM
  #37
insame1's Avatar
either is fine as long as the are spec. When I lived there I ran 0-40 with no issues.
Old 01-21-2018, 08:21 PM
  #38
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
I too live in No.CA.
I am a fanatic about changing it every 5k, and my OCD has paid off.
Been using 0-40 Mobil 1 in my C55 with great success and zero consumption issues.
Just make sure whatever brand of 5-40 you use meets MB specs and you should be fine.
The weather here is pretty consistent so it easy to plan in advance regardless of the season.
Old 01-21-2018, 09:38 PM
  #39
kjb55's Avatar
The (for multi-weight oils) low number is cold weight / high number is hot weight. The zero is better for cold starts (regardless of temperature) and the high number is the same - so switching to 5w-40 won't change anything for you.
Quick Reply: Oil usage?
