I Need to know...please help
The pulley for my AC compressor is making noise and metal shavings are seen...what I want to know after releasing tension from belt..it was discovered the pulley was wobbly so needs replacing...can I just replaced just the pulley or does this mean the whole compressor needs to be replaced?
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
It's hard to answer your questions without trying to pull on the the AC compressor shaft. I would get the AC compressor pulley first, mount it and hope that your AC compressor is fine.
Hi Vic, here is the document that I have that describes how to swap the AC Pulley on the W203 model with a 112 engine. This may be yet another option although if you are working with a used AC compressor unit, it may be less effort to just replace the entire unit rather than swapping the pulleys.
c32used (09-22-2016)
My friends I haven't had a chance to get into this yet....I am hoping to atleast figure out IF the pulley on AC compressor can be taken off because I feel that it may be in way even if I get a shorter belt. I am looking at the pulley pdf Lenin provided and it appears as though it can be removed.
yes u can remove the pulley without taking the ac kompressor off. its 1 bolt in the center then u can remove the wheeel after that its a locking ring u have to remove then u can pill the bearing unit off. probably is it that bering u have to shange.
i have done this on my c 32 2001. its good to have a mirror so u can se.not much space down there....
