LSD for a C43....Almost
Rating: Thread Rating: 4 votes, 4.00 average.
Old 02-15-2009, 09:11 AM
  #51
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Good stuff and interesting. The stck diff seems to be pretty stout so I could imagine how nice the LSD diff from the 190E 16 v would hold up. Again nice work there. This is something I would'nt mind considering doing with my beast.
So to sum things up you r using for the diff itself are:
1.300CE housing (W124)
2.190E 16v LSD
3.gearing from your stck diff (C43 3.07) to convert the (190E 3.27) ratio back to 3.07
4. 190E 16V yoke and flanges
Correct?
Old 02-15-2009, 12:58 PM
  #52
money-one's Avatar
C43/2jz, Ml63, C32
piertek... If you were to just get an LSD like the one I purchased, it would just bolt in with the exception to the rear cover which you would have to change. Other than that it would work fine even with the different ratios. It would only alter your rpm depending on if you went higher or lower than your stock diff. Actually if that is a problem I think you would be able to transplant the Lsd into yours so it wouldnt change.
All the parts used are factory nothing out of the ordinary aside from the grinding I had to do to the rear cover and the Axle flanges. Part numbers are listed above. Nothing from my stock differential was used.
ProjectC55...Sort of right
1. 300CE diff. housing W124 with ring and pinion (It had the 3.07, the stock diff. from the C43 had nothing that would fit in the smaller diff
2. 190e 16v LSD internals and axle flanges
3. Slk 320 (170) yoke and rear cover
4. C280 w202 (2000) rear driveshaft and flex disc
Old 02-16-2009, 08:25 AM
  #53
ProjectC55's Avatar
Basically I would keep my (stck diff housing and 3.07 gears) and just add the LSD internals from the 190E 16v.
I'd also have to chg the rear cover but I could keep my driveshaft and everything else (stck yolk,flanges ,axles or am I way off)?
Or would I still have to chg the flanges,driveshaft and yolk on top of everything else included?
Old 02-16-2009, 07:53 PM
  #54
money-one's Avatar
C43/2jz, Ml63, C32
PROJECTC55....Your stock diff. once removed is more or less a paper weight, because NOTHING is used from it along with the rear driveshaft.
You are frankensteining the diff from the 300ce,190e,slk320,and the c280
Sick430...I got a chance to look at CLK430 today and you are going to have to do the exact same thing I did. The rear driveshaft should work but I'm not a 100% more like 85%
Old 02-17-2009, 08:15 AM
  #55
ProjectC55's Avatar
Gotcha! Guess my main concern was the gearing. I'd have to find a 300CE diff with the 3.07 gearing and just follow the list you have of replacement parts. You r using the C43 axles, you just chgd the flanges correct? The driveshaft part and diff rear cover,I fully understand.
Old 02-17-2009, 10:10 AM
  #56
money-one's Avatar
C43/2jz, Ml63, C32
Correct the C43 axles are retained. If you are trying to do this the open diff. with the 3.07 ratio can also be sourced from the C220
Old 02-18-2009, 11:40 AM
  #57
ProjectC55's Avatar
Well what is the difference between using the 3.07 ratio open diff from a C220 and using the open 3.07 ratio open diff from the C43?
That's where u start to confuse me.
Sorry.
Old 02-18-2009, 07:23 PM
  #58
money-one's Avatar
C43/2jz, Ml63, C32
Here is an illustration with paintshop
As you can see the 190e 16v internals wil not fit in the c43 housing. The 3.07 ratios are the same between c43, 300ce, c220 but thats it. I hope that helps
Old 02-18-2009, 10:06 PM
  #59
ProjectC55's Avatar
The LSD from the 190 will only fit in the 300ce diff which also has 3.07 gearing. Same could be said for the C220 diff housing if I choose to go that way. Correct? Is it alot smaller than the C43 diff DAMN! I want you to really beat that thing so that I see how it holds up. Thanx for clearing it up for me.
Old 02-19-2009, 10:51 PM
  #60
money-one's Avatar
C43/2jz, Ml63, C32
Absolutely correct I'm glad you understand. I will be going to MIR's track the first of march for a few runs. I'm sure it will hold up fine
Old 03-06-2009, 06:55 AM
  #61
jeemu's Avatar
w124
Hello. What size springs are those self made Kleemann style lsd?
Old 03-06-2009, 11:50 AM
  #62
trinitony's Avatar
E55 C43 993C2S
Not to hijack, but good to see another in Merryland...nice pics on ur album.
Old 03-06-2009, 01:52 PM
  #63
NitrogenBalance's Avatar
none
True Gearhead work!
Maybe it's just me but a job like this shows a true MB fan more so than the guy with a multi car stable. I love the idea of using mis matched OEM parts that already exsist in junkyards. I miss that from my GM 454 days. True definition of hotroding what your doing. Although some of the other forums have mods out the **** they all seem to go by who has the most complete list of a vendor's products and parts. This thing I like to see, not 5 posts a week in the same forum showing someones same old overpriced IC, headers, pulleys,80mmTB, HRE's, etc....nothing new...just writing checks like the next guy...Rant done.
Its nice to see your thinking outside of the box along with some very solid looking work to get things back on topic.
What are your next plans? engine? suspension/drivetrain? Your just about 5psi shy of the baddest W202.
Old 03-06-2009, 02:52 PM
  #64
trinitony's Avatar
E55 C43 993C2S
Originally Posted by NitrogenBalance
True Gearhead work!
lol...luv the stance of ur car - wat pad/spring/shock/combo ur running? TIA
Old 03-06-2009, 03:00 PM
  #65
none
Thanks bud, H&R springs with #2 up front and #4 out back. Slight rake but fender gap is dead even front and back. I also like the slight rake.
Old 03-06-2009, 07:49 PM
  #66
c280_nz's Avatar
yea this is true mb modding! these are real mods, none of that out of the box shyte.
i have personally tried so hard to make this work in my country about a year ago but i just cant track down a lsd(190e) from a scrap yard locally (New Zealand), so itd need to come in from overseas :-( so i gave up because scrap yards are dodgy enough as it is let alone dealing from another country
i even looked into getting a 300ce diff with that ice road hydrolically lockable diff (asd) but cant get any of those diffs at all!
u may be able to get them in america did you think about one of those?
but as nitro said, you money-one are a legend for it!
Old 03-06-2009, 08:00 PM
  #67
money-one's Avatar
C43/2jz, Ml63, C32
jeemu... what are you refering to???
trinitony...It's always good to find another rider in the state. Keep it clean, Keep it simple, and Make it Blindingly FAST!!!!!
NitrogenBalance...I just finished the suspension (KW variant 2). I'm letting the suspension settle before I adjust ride height. Holy S*** what a difference
There has been a thought that is floating around in my head and it sort of looks like this Idea is courtesy of mbenzman and pic too. But im thinking of a full engine swap not just the kompressor. This will be a very tough job but where there is a will there is a way. Any suggestions with tuning and install would be helpfull. PM please
Old 03-07-2009, 07:18 AM
  #68
jeemu's Avatar
w124
money-one: I gonna make that style lsd my self and it would be easier find springs if someone is do that kind lsd and know what size springs used.
Old 03-07-2009, 08:20 AM
  #69
ProjectC55's Avatar
Mbenzman says that to install the kompressor motor into our cars will be hell.
That's why he installed the charger instead.
By the way,it's pretty difficult to find the 190 16v LSD right now. I've been on the hunt.
Old 03-07-2009, 03:48 PM
  #70
c280_nz's Avatar
its not just the spring block, the diff also needs to have machining for the clutch packs between the output gears and carrier. and to make your own just use the stiffest valve springs you can to fit in each corner of the block
Old 06-12-2009, 11:54 AM
  #71
piertek's Avatar
C36AMG
HELLO MONEY! I DID ON A 3.92 FROM AN W201036 EVO, THE SWAP WORKED, ALMOST PLUG AND PLAY, BUT AT THE FREEWAY GOING AT 70MPH ON 4TH GEAR THE RPMS WHERE AT 4000!!!!!!!!!! TOOOOOOOOO SHORT. WHAT I DID NEXT WAS TO TRY TO PUT THE GUTS INTO MINE A 2.85 C36 REAR END.......... AGGGGGGGGRRRRRRRRRR WONT FIT DAMMM IT....
NOW IM RUNNING THE LSD 3.92 IS LIKE HAVING A BIKE, HANDLES GREAT!! BUT WAY TOO HIGH RPMīS. I WILL TELL YOU ALL GUYS MORE NEWS...
Old 06-12-2009, 09:52 PM
  #72
money-one's Avatar
C43/2jz, Ml63, C32
Jeez!!!! That is some high RPMs. Can't be good on fuel consumption. Hope you get it worked out soon. Once my engine swap is complete I will be returning to the LSD and do a Quaife.
Old 06-14-2009, 03:14 PM
  #73
sick430's Avatar
CLK Cabrio
dibs on old lsd, if your going to sell it
and thanks for the update on the driveshaft
Old 07-08-2009, 04:05 PM
  #74
piertek's Avatar
C36AMG
IM BACK MONEY! I BOUGHT A BRAND NEW DIFF FROM A W202 A C220 WITH ASD, TOOK OFF THE YOOKE, THE ASD FLANGES AND SWAPED THE ONES FROM MY C36, IT WORKS, ONLY ONE PROBLM, THE DIFF IS A 3.07 AND MINE IS A 2.86 THE TRANNY DOESNT START IN FIRST AND WHEN YOU ARE GOING OVER 120 MPH AND PUSH THE GAS PEDAL TO THE FLOOR THE CAR CUTS GAS, THE STAR DIAGNOSIS TELLS ME THAT MY ABS REAR SENSOR HAS A MEMORIZED ERROR...... DAMMMMMIT, QUESTION.. WOULD THE RING AND PINNION FIT FROM MY AMG 2.86 FIT INTO THE 3.07, KEEPING THE LSD DIFF, JUST SWAPING THOSE TWO THINGS??? REMEMBER THAT GOING FROM 2.86 TO 3.92 WONT WORK, I DID IT AND DOES NOT FIT. HELP ME PLEASE.THANXXX A LOT
Old 07-08-2009, 09:21 PM
  #75
money-one's Avatar
C43/2jz, Ml63, C32
Hey buddy glad to hear you almost got it worked out.
If the two housings you have are similar in size it more than likely will fit. I think that the housings you got start with the part #124 *** ** ** and probably are not different. This is casted in the side of the diff. housing. If they are not diff. eveything SHOULD be interchangeable. If they are close it still couldnt hurt to take a peak.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
Quick Reply: LSD for a C43....Almost
