LSD for a C43....Almost
#101
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
so a small sidetrack here. I'm talking to a dealer in Delaware about a trade for a C43 for my C36 (plus some dough, of course) and in the description of the car he put that one of the options was a "locking differential".
Just to make sure before I question the validity of this sale, mb definetely never offered a locking diff for the 43 right? What on earth could that ever be used for on a rwd sport sedan.
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
#102
00 C200 & 00 C55 & 06 SLK55
I finally came into an ETC for a 1998 SLK230 and put the monster together and was ready to roll
But as luck would have it she still didnt work
After a little thinking and speaking with my Shop Foreman it came to my understanding that the engine size also has a bearing on the ETC module. Which makes sense why 2PHAST has had no problems with his ETC swap (SLK320 module).
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![mercy](https://mbworld.org/forums/images/smilies/mecry.gif)
may means nothing to do with a size of the Engine..!, it needs a knowledgeable person or company to match & reprogramme the
TCU.........!?!
ZAYED,,
#104
C43/2jz, Ml63, C32
A rear diff from a 1980's car housing/internals can work without question or problems in a 2003 diff. Provided that you replace bearings or transplant the originals to the unit you intend to work with.
The frankenstein one that I created was great in my C43 with the 55 N/a swap. It had no issues when it was subjected to the 55 S/c up until I actually punched it and she popped from all that torque. I disassembled it and installed it in my C230 not even questioning its integrity/reliability. Worked beautifully and the car felt so planted after that. Then I sold it to a forum member and I have not heard of any problems from him. His only issue was that his RPMs were too high because he was still using the 3.27 ratio.
To answer your question no it made no noise.
#105
Sounds good to me. I put a LSD in my friends 211 E55 and that had noises either.
I'm about to start my differential swap on my car. I got a 210 E55 diff, tiptronic shifter from a 208 CLK 55, and a trans module from the same CLK. I'm going to start to piece together a harness and see if I can get the tiptronic to work. If I can get everything working properly then it'll be time for an LSD.
#106
That’s a good project,, if you put 2.82, you well loose some tenth,, if you not care about this, it well be fine with you,,:-
do you have an EGS51 or EGS52, cause the early 98-99 & late 01-02 version are different........
ZAYED,,
ZAYED,,
#107
1995 C36 AMG, 1998 C43 AMG
#108
As we know guys,, all tuner companies can modify the EGS52,, Did anyone know, if they can also change or chose the ratio and saved it to the
TCU memory.....!?!?
The 2001-2004 SLK32 got Exactly the same our "C43" diff., and a reprogrammable EGS52,, why we not put EGS52 from the SLK32, with a
Tip-tronic shifter, then recalibration it with the ECU......??!!
ZAYED,,
TCU memory.....!?!?
ZAYED,,
#110
I went to the dealer today, i asked "3" professional supervisors(which working almost 16 years in the dealer),, why the W210 E430 special Edition
has 3.27 diff. with EGS51(which we all know CAN’T BE PROGRAMMABLE),, and how they did a calibration with an ME2.0...!!!,,
1) First one: sorry i need to go to see a new cars arrived now......![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2) Second one: my wife messaged me about some problem with my sun in school.....![slap](https://mbworld.org/forums/images/smilies/slap.gif)
3) Third one: ahhhh you have a strange ques., look, i need to go to GERMANY to see a football match between "AUDI racing team VS Human rise
Authorization",, if Audi wins, i well go to work in Nissan dealer, if Human wins, i well come back & kill my self in front of your HOME........
ZAYED,,
![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
ZAYED,,
#112
Made a simple Primitive Bracket for a cooler, its not that much good looking, but its do the joooooooooob.......![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Attachment 246034Attachment 246035Attachment 246036Attachment 246038Attachment 246039Attachment 246040
ZAYED,,
ZAYED,,
#113
There's some discussion about the diff cooler on the 203 AMG forums. I believe the cooler Zayed used is the stock one off the C55. Some C32 guys had brackets fabbed up to fit the cooler to their cars too.
I love the fact that its on my car, but I do miss being able to use the diff as a jacking point! As an aside, my stock diff on my S2000 has fins on it too, not as many as the add on heat seak on the C55, but it has them.
#120
Not sure about W123,, according to EPC,; 3.46 can be found with "R107 & R129 & W126 & W210 & W140",
But NOT sure which one uses 210mm Housing....?!?
ZAYED,,
ZAYED,,
