took apart the intake manifold...
When I took my intake apart to clean the hardest part was taking it out of the car. I also replaced the fuel injectors seals while i was at it. To seal the top portion of the intake I used Permatex Ultra Grey RTV Gasket Maker (9.5 oz). Had no problems whatsoever. The key is to clean very well, and after sealing it let it dry dry dry. Once this stuff dries it aint coming off easy.
Before doing this job I had air leaks I couldn't find and engine would shake a little. After the job no more air leaks and engine was very steady. Whichever sealer you use just let it dry and you will not have any problems at all.
If you decide you need to open it up, ill rummage through my old photos and see if I can post anything that would be helpful to you.
Let me know.
Edit: to prove that it can be done without a spare manifold, I didnt order one. but did have to machine a new component since I was impatient when opening it and snapped a fork that controls the air pathway to the cylinders. But it most certainly can be done!
Personally I think it was a lot of work. I cleaned it all out and used a boat load of RTV to fill everything again since just about every surface you can imagine needs RTV where it contacts another piece. If you dont have any major vacuum issues or an awful rough idle I would hold off on opening it up. Its obviously do-able, but not something you do just for fun.
Let me know.
Let me know.
Figured I'd share.
Recently needed to get my intake apart and fiddled with heat for a few minutes unsuccessfully.
I found some "dip" for cleaning parts. Can be purchased at any parts store, comes in a gallon paint can. High powered solvent highly corrosive towards soft rubbers aka the gaskets that hold that thing firmly in place.
after drizzling some of this stuff on it was apart in less than 5 minutes.
Why does nobody ever mention re applying any glue when re assembling these manifolds?
its very clear there is not just sealant inside the top half, there’s also gluein some places too. Surely everybody didn’t just glue it back together with RTV sealant...dig through 5 threads on this subject and nobody mentions the glue?
ChrisVannoy (09-26-2022)
