C43 differential substitutable with other models?
I recently blew up my C43 differential and am looking for a replacement. I can not source one at all! I've looked all over the Internet and have had no luck. What differential can I substitute in from another model to make my car run again? I'm thinking maybe the cl430 or any other 430 since it's the same engine basically?
TL;DR: What differentials can the W202 C43 use from other models
00 C200 & 00 C55 & 06 SLK55
The only one which plug & play with "W202 C43" is "R170 Slk32" diff.,,
but if you want to replace the gear & pinion, you can go with "W208 Clk320/W211 E320/W220 S350-S430 4matic-S500 4-matic"...
,,ZAYED,,
,,ZAYED,,
Damn so only the SLK32 will bolt right up? It has the 3.07 gear ratio?
good q. my car is also standing still waiting for a new diff.
today unbolted it.. oil looked like metallic paint and smelled like it was burned.
refreshed it like 20k km's ago....
mine is fixxed
burning rubber again
kept the old/broken one.
i might rebuild it if good info on " how to and where to find" is being posted here.
