What Engine Oil?
C63
What Engine Oil?
Just about to change mine again. Wanted to get an update and see what everyone else is running currently. Oil Brand and weight. Thanks!
C63
Same thing I'm currently running. Heard of some people running Mobil 1 0-20w as recommended in the SLS. Was wondering if anyone was running anything besides the 0-40w European blend?
There are other manufacturers oils you could run, as long as it meets Mercedes Spec.
Castrol comes to mind. I personally stick with Mobil 1
Some guys are running MOTUL 8100 5W-40. Oils that are Mercedes 229.5 approved are ok to run in the C63.
I say stick with Mobil 1.
I am on my last fill of ESP 5W-40...the dealer is now using 0W-40 which makes more sense and I am happy about that. Hopefully I'm going to strike a deal with my SA so I can begin using this oil though:
http://www.pennzoil.com/#/motor-oil/pennzoil-ultra-euro
2006 E55
Another oil question...lol! This subject has been discussed on about every motor powered vehicle forum.
Here is what I know without getting into the MSDS sheets to determine "Group". The important items to look for are Viscosity Index and flash point. Pour point is also important but since I live in California its not that critical.
SLS(229.5) calls for;
Mobil 1 SuperSyn 5/50... / VI-153/ Flash Point -236/ Ash1.2
Other MB's
Mobil 1- 0/40.... VI-185 / Flash Point -230/ Ash1.3
Mobil 1- 15/50.... VI-160 / Flash Point -232/ Ash1.21
In a nutshell....The higher Flash Point is important to reduce burn off while Viscosity Index is indicative of viscosity change with temperature. Obviously the higher the better. These are the numbers I look for.......so currently I have switched to Mobil1 15/50 simply for the slightly higher weight and flash point. However the 0/40 has the highest VI.
Other MB's
Alright thanks
But I don't understand, when I check on their website, they're saying that 5w-40 is for diesel trucks: http://www.mobiloil.com/USA-English/...uck_5W-40.aspx
I didn't keep the empty bottles of the oil but I'm pretty sure it was 5W-40.. and it was a green bottle
Alright thanks
