C63 AMG (W204) 2008 - 2015
Old 06-04-2015, 07:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
How to: Replace Brake Pads
Old 04-22-2013, 02:43 PM
Mort's Avatar
Originally Posted by intence
besides that passenger rear corner, which other corners contain brake pad sensors?
Passenger side outboard pads front and rear.
Old 04-22-2013, 03:11 PM
intence's Avatar
CLK63 AMG Black Series
perfect thanks!
Old 09-28-2013, 04:25 AM
tfthach13's Avatar
'09 C63
Just purchased some Porterfield R4-S for my rears. With this DIY, the installation was quite simple...I had a few friends help out since it was my first time changing pads, and they've done it before. Took about two hours, but we were taking our time. It should take about an hour next time.
The Porterfields feel good, but I haven't pushed them hard yet. However, the initial bite from the oem pads isn't quite there. It feels like I have to push a little bit farther on the brake pedal with the Porterfields before you feel the car braking. But once they do, it stops.
Hopefully, these will last me a while since I mainly do highway/street driving; never on a track.
Old 08-07-2014, 03:56 PM
MikeHoncho3's Avatar
2009 C63 AMG
Great DIY. Looks pretty simple to do. I'll probably have to be doing this soon so glad I stumbled across this.
Old 08-08-2014, 04:37 AM
tdk930s's Avatar
2011 C63 P31 LSD
+1
Old 10-02-2014, 01:57 AM
jsumida's Avatar
2009 C63
I'm looking into Akebono's or Ebc Red's but the pads I see don't have the eyelets for the pins to slide through, am I looking at the right pads? they all say compatible for a 2009 c63. Is there something that I'm missing?
Old 10-02-2014, 10:40 PM
  #32
snowmuch's Avatar
C63 AMG
Do you have the part number for the pads?
Old 01-20-2015, 02:38 PM
  #33
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
Out of curosity, are folks in this thread not removing their rotors to get machined when replacing pads?
Old 01-21-2015, 08:56 PM
  #34
skytow's Avatar
2013 C63, 2015 C63 507, 2020 C63s
....or measuring for Min Thickness of the rotors to make sure they are still in spec?
Old 01-21-2015, 09:54 PM
  #35
ToXicXxX's Avatar
2011 C63 AMG P31
Personally, I'd use a centre punch to knock the pins out and ceramic anti-squeal instead of that copper stuff (which you DO NOT want on your hands). That's how I do it on customer cars.
But, good writeup!
Old 01-22-2015, 12:43 AM
  #36
bhamg's Avatar
C63 AMG
But, good writeup!
Yup...an (ideally 12") 5/32 punch is a must have tool...use it to center the farthest pad when reinstalling the pin. In between, use the handle side to depress a piston and keep it there.
Old 01-22-2015, 09:56 AM
  #37
AMG893's Avatar
2010 C63 Estate
this should be a sticky.
great writeup.
Old 01-22-2015, 09:38 PM
  #38
ToXicXxX's Avatar
2011 C63 AMG P31
Every man should have a set of Mac punches So useful.
Old 01-25-2015, 03:38 AM
  #39
L8brker's Avatar
09 C63 P30/05 S4
Originally Posted by BFNYM156
U did well on the rotors, Did you track at mosport? Moport is very flowing, doesn't harm brakes too bad, I installed a new set of oem front rotors and endless MX72 with only 2000km hwy driving plus one day at Mosport and Mid-Ohio. After last Mid-ohio, my front brakes are completely destroyed by Mid-ohio. Front rotors are cracked along the drilled holes and warped. But I was pushing hard and ******* with F430 race car and C5Z06, trailbraking alot. I just ordered XP10 for front today and racing brakes rotors, hope they can do better
Very nice track set up . Can I see some pics of your car with ccw's , I've never seen anybody with a set up that wide before!
Old 02-08-2015, 08:40 PM
  #40
screw991le's Avatar
2010 E63 AMG
Sub'd
Old 04-23-2015, 08:46 PM
  #41
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
I just replaced my front pads today. Amazingly simple - about 30 min for both sides (507 with performance package). I got stock pads for about 210$ online. I even splurged and picked up a new wear indicator from the dealership on the way home from work today - 15$.
Pedal feel improved right away, I felt it immediately.
No reason whatsoever to have this done by a mechanic. Between buying parts online at wholesale and doing the work myself, I just saved 200$ in 30 min....
Old 04-23-2015, 09:30 PM
  #42
aussie e55's Avatar
2009 C 63
Smile
hi
do you have part number for akebono pads there agent in australia claims they do not have pads fo C63 sedan. i have used akebono pads on my prev. amg cars & very happy with them thanks
Old 04-23-2015, 11:55 PM
  #43
D3-AMG's Avatar
1993 Competition Yellow Mica Mazda RX-7 and 2009 C63
In my experience, measuring the min thickness is important so you know if it is time to replace them. But machining the rotors doesn't typically need to be done, it takes away more heat sink material (leading to more chance of warping), has to be smoothed out by the new pads, and in the case of our cross-drilled and slotted rotors is a huge pain for the shop to do correctly. On my RX-7 (my C63 is too new to me to state anything about it directly) I prefer to run the rotors through 2 sets of pads including track days and then replace them as consumable items.
Old 04-25-2015, 11:04 AM
  #44
Wobble64's Avatar
Performance package rotors are 36 mm thick new and need to be replaced when found to be below 34 mm during a service, but no later than at 33.4 mm.
Old 06-23-2016, 12:35 PM
  #45
ENV˛'s Avatar
2001 Porsche 911 Turbo (heavily modified)
I will be doing this the weekend after this one. On the fence between ordering Porterfield pads or OEM. I hate the amount of dust from OEM but I heard Porterfield lose initial bite. Endless MX are too expensive for only going to one or two HPDE events.
Old 06-23-2016, 01:04 PM
  #46
AMG3.2's Avatar
C63 AMG, P30
It's always a toss up with these things. The Endless are expensive, but I just didn't want dust nor could I live with less feel, bite etc. You can get some good deals emailing vendors though. My buddy owns a shop called Speedfreaks and I'm sure if you emailed them, he could hook you up. No promises though, but could be worth a shot.
I've never used Porterfield so can't advise you on the initial bite loss.
Old 06-23-2016, 01:07 PM
  #47
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Porterfield are just fine on the street. You won't notice any difference. And they won't eat your rotors.
Old 06-23-2016, 01:42 PM
  #48
AMG3.2's Avatar
C63 AMG, P30
Rokt, in all honestly, do they lose any feel compared to OE pads? I'm sure all pads we can buy are totally acceptable on the street.
I'm just always curious on the difference in characteristics with brakes, tires, etc.
Thanks.
Old 06-23-2016, 01:49 PM
  #49
BLKROKT's Avatar
I didn't feel any difference whatsoever. Less dust and equal feel for all intents and purposes. They suck on track though.
Old 06-23-2016, 10:09 PM
  #50
QWKSNKE's Avatar
I ended buying the front kit from FCPEuro. Came in today and is one of my chores for next week while I am off
FCPEuro (06-24-2016)
Quick Reply: How to: Replace Brake Pads
