Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
- Mercedes-Benz C-Class: How to Jump Start Mercedes-Benz
Step by step instructions for do-it-yourself repairs
Won't start
2009 Iridium Silver C63
Won't start
I was getting ready to head to work this morning and I go into the garage and I click the unlock button on the key fob and nothing. Tried it again and nothing. I figured my fob battery may have died so I retrieved my 2nd key fob and tried that one and nothing either. At that point I figured my battery drained overnight (how? I don't know since I am 99.99% positive nothing was left on). So I tried jump starting it with my pickup truck and as soon as I hooked up the cables the alarm system starts going off. Wailing siren and mirror lights were blinking on and off so i figured that if there was enough juice in the battery to flash those lights that bright, there must have been enough to at least unlock the doors but nothing. I tried removing the battery to go get it tested but as soon as I removed the terminal, the alarm went off again and wouldn't turn off with the key fob. Only way I could get it to turn off is to reconnect the battery and let it cycle through a few times. WTF? How am I supposed to remove the battery to get it tested/replaced if the alarm is going to be going off as soon as I remove the battery (neighbors wouldn't be too happy with all the noise). Plus I'm sure the local parts store won't have a replacement for it so Im stuck having to go to the MB dealer 50 miles away. Any ideas of what might be going on? I seriously don't think its the battery but have any you experienced anything similar adn turned out it was the battery?
Have you forgotten about the key blade that is integrated into tht key fob. You could have used that to unlock your doors, the alarm would have triggered, then insert your key fob into the ignition slot. You can have your battery tested without pulling in out of the car at any autozone, pep boys or advance auto parts.
I went out to the car this morning, unlocked the doors with the fob, closed the door and put the key in the ignition. Turned it all the way to the right and nothing. No radio, no start. Pulled it out, tried it again- same result. I thought perhaps there's something wrong with the fob so I pulled out the spare and tried it with the same results. I know there wasnt anything in the car left on overnight that could have drained the battery and the dash displays the mileage and it's standard menu. But the radio (pop up display) never opens or turns on. I ended up hitching a ride with someone to work today. But I can hardly wait for the alarm to start going off today when I try and jump start it. The only thing I can think is that for some strange reason the battery died overnight.
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I had the exact same problem as you.. however my car had been sitting for 5 days at an airport parking lot.
I to made sure I had nothing left turned on before I departed (have had problems forgetting to turn off lights in the past on other vehicles, so I make it a procedure now to check everything is off).
Couple of things I noted.. most new cars have a protection circuit to prevent the battery from draining to the point you cannot start it it (usually should be enough to get 1 or 2 good cranks to start the car)... Does the C63 have this, and if so.. why did it fail.
I called the parking lot emergency phone and they sent a pickup... a V6 (I did mention that I had a V8), connected the jumpers, same deal as you, alarm went off, fob still would not open the door, lights turned on very dimly...
I used the key to manually open to the door, tried to start the car.. nothing, not even a click... tried this a couple of times every 5 or so minutes.. nothing, after about 15 min, the car almost tried to turn over.. after 30 minutes attached to the pickup, the pickup driver floored his gas and held his engine at redline, I turned the key.. and the car barely turned over, it struggled, and I managed to get the car started....
I believe that the pickups electrical and battery did not produce enough juice for our cars to start via a normal jump start...
This happened to me once in August (I had just returned from DEFCON in Vegas), has not happened since... I'm curious what caused it..
Someone in my office that has the same car, a year older, asked me first thing this morning "did you jiggle the steering wheel?". I thought to myself, it's locked.... isn't it? Guess that's an additional thing to try when I get home tonight.
But can you reference another post about the steering column issue that you mentioned? Not sure that I've heard much about that one.
General rule of thumb.. a similar sized engine (with similar sized battery and alternator) are what you want to use to jump start a car. This is not always 100% the case, but a good rule of thumb.
Specifically when it comes to batteries, they way they work and how electrons move (getting slightly nerdy/geeky now), 2 different size batteries connected to each other will try to equalize (when there is no load, ie a light bulb, or an engine..etc), essentially splitting the power evenly across both batteries, unless the battery has fault protection built in. The larger battery trying to shuffle a charge into a smaller battery that is no longer capable of accepting a charge can result in bad things happening (from as simple as messing the battery up, to potential explosions).
This is one reason why you never connect battery to battery, rather 1 of the negative terminals should be connected to a ground lug somewhere in the vehicles engine bay).
Car is still dead. I did open the doors with the mechanical key placed the fob key in the ignition to try to "reset" it but still nothing. The car is in my garage and doesn't start so obviously I can't drive to Autozone to get it checked without removing the battery. The alarm still goes off as soon as I try to disconnect the battery and won't turn off unless i reconnect the battery. I'd hate to call MB to have them come tow it 50 miles and then turn out it is indeed the battery (which isn't covered under warranty or is it?) and be stuck with a $300 towing bill hence why I would like to take the battery to get checked first. Anyone know how to disconnect the battery without having the alarm activate or how to turn it off once it does?
You have 2 batteries.. disconnect them both. I am not sure what the consequences would be, call MB first to check.
There is one in the Engine bay, and one in the trunk, passenger side behind a flap cover.
If you are in the uSA you have Life time Roadside Asst. with FREE Sign and Drive services which include free jump start, tire changing and bringing you a few gal of gas should you run out. Have them come out, jump start you and drive to the dealer, especially if you are under warranty
good luck
good luck
went home last night, tried to jump it with the second car. No dice. I on a whim called MB Roadside and they sent a guy out in minutes to jump start me (free). Which I was completely surprised about. Unfortunately the guy recognized almost immediately when I got in the car that the issue was not related to needing a jump. He called for a flatbed truck to tow it to the dealership (also free), sent me up to the local MB dealership to pick up a loaner (free?!) and now I await the phone call with the quote on repair.
I did get a call saying that the car was checked in this morning and that I'd hear from them today about how much the repair would cost, and what was wrong. But the service writer pretty much eluded that he thought it was the ignition/steering issues as well. Guess we will have to wait and see.
Yes, was in MD.. the Deloitte corporate mandated community service thing we have to do every year in June... but I am guessing you would have remember since we discussed the C63 abit during, so I may have the wrong person in mind (she is a forum member as well and has a C300, just cannot remember what her forum name was)
i can't start my vehicle, Help
Had the same experience and doesn't start. What should I do?
