C63 AMG (W204) 2008 - 2015
Head Bolt Affected VIN - 2010 & older, & early 2011s
Old 01-28-2015, 06:46 PM
  #301
realjones88's Avatar
2012 C63 P31 sedan
Originally Posted by ArmoE55
I wanted to ask you for some VIN runs to check if the 2011s I'm interested in are affected or not.
I added this in another thread, but I'll put it here because I think it will help your search, at least if you decide to go 2011:
The head bolt switchover occurred at engine engine 60658, which corresponds to a c63 build date during 6/2010. The build date is on the plaque inside the driver's side door.
Any C63 built before or during 6/2010 and last six digits of the VIN lower than 528000, came with the older style headbolts from the factory.
Any C63 built after 8/2010 and VIN higher than 545000 should have come from the factory with the newer headbolts.
The actual switch occurred right around car 534000, but I have seen one car built in 7/2010 that had old headbolts. I would say 528-545 is a grey area and lookup to confirm. I have never seen a car over 545000 with the old headbolts.
You can lookup a VIN yourself here:
http://carinfo.kiev.ua/cars/vin/mercedes/vin_check
Of course you can pull datacards to confirm, but looking at the last six of the VIN will give you a very good idea of how close to the switchover the car is. At some point in 2013 the C63 vins went over 999999 and are coming back around again so I am only talking about 2011 and earlier cars here. All of the facelifted cars have the newer headbolts.
Old 01-28-2015, 06:56 PM
  #302
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Hey man-
If you don't mind, I will be starting my quest for a C63 sometime in the next few months. I'm looking at 2012+ because I like the facelifted look more than the previous look, but I may consider a late build 2011.
Also, can you run the data cards on vehicles as well? Options that come with the car and showing any warranty or repair work done with the dealers?
Thank you, I would really appreciate this and do not mind compensating for your time with helping me.
I can provide you whatever you like related to engine number and datacards. I have no access to dealer service records. Send requests via this forum, as I cannot add attachments to PMs.
Regards,
Joe
Old 01-30-2015, 09:19 AM
  #303
ArmoE55's Avatar
2006 E55
Thank you both for the help. For me, I think the dilemma now lies if I can go with the pre-facelift car because I truly want a facelifted car. I just need to see if the price difference can justify the newer models (taken into consideration if I go with an '11, I'll look for a car with the newer headbolts).
Thanks again, guys..
Old 01-30-2015, 03:48 PM
  #304
Valvestud's Avatar
FYI, Not sure what you're into in terms audio needs, but there were significant changes in the 2012 that make bluetooth functionality work for audio. Previous years do not work for audio without a media interface cable or something like a Tune-2-Air. But these do not allow the steering wheel controls or screen to display properly on anything but the phone's installed music ap. No BT functionality for streaming except volume.
Regards,
Joe
Old 01-31-2015, 10:10 PM
  #305
ArmoE55's Avatar
2006 E55
Joe - thank you for the post. Audio is important, but wouldn't be a deal breaker for me in just about every case.
The more research I've done and read, the more I want a 2012+ as they have upgrades and looks that I truly want and would regret if I went with an earlier year build C.
Thanks again, I appreciate it.
Old 02-14-2015, 09:46 PM
  #306
Jrw63's Avatar
C63
Please check vin #
WDDGF7HB3AF481748
Please check this vin .. About to purchase .
Old 02-14-2015, 10:10 PM
  #307
Valvestud's Avatar
Originally Posted by Jrw63
WDDGF7HB3AF481748
The title of the the thread gives you the answer.
Regards,
Joe
Old 02-14-2015, 10:16 PM
  #308
Jrw63's Avatar
C63
Got it .. Thanks but ...
Regards,
Joe
The car is spotless low miles 2010 .. So if I change all head bolts am I ok ??
Old 02-14-2015, 10:27 PM
  #309
Valvestud's Avatar
You can certainly change them. I would read all the threads related to options and costs. I have a 2010 and I'm not gonna worry about it unless the issue arises.
Old 02-18-2015, 03:02 PM
  #310
fiat lux's Avatar
2012 C63 AMG
I've been perusing mbworld for quite some time now, this really is quite an informative and supportive community. Now that i'll be making the jump into a C63 (preferably a MY 2012+) I decided to join the forum! I do have my sights on a 2011 with the p31 package, and was wondering if its engine was built after 60,658. Any help is appreciated! WDDGF7HB5BF582744
Old 02-18-2015, 03:15 PM
  #311
Valvestud's Avatar
Not affected.
Regards,
Joe
Old 02-18-2015, 04:43 PM
  #312
fiat lux's Avatar
2012 C63 AMG
Not affected.
Regards,
Joe
Appreciate the help.
Old 02-20-2015, 05:18 PM
  #313
kingmiller82's Avatar
E63 W212
Joe could you check mine please.
VIN
WDDHF7HB9AA194657
Old 02-20-2015, 05:37 PM
  #314
Jrw63's Avatar
C63
Cost to replace ??
does anyone have a ballpark number to replace all head lots ..stronger bolts or is the block the problem
Old 02-20-2015, 06:04 PM
  #315
Valvestud's Avatar
VIN
WDDHF7HB9AA194657
The title of the thread gives you your anaswer.
Old 02-21-2015, 12:39 AM
  #316
E63 W212
Good question.
Bump
Old 02-21-2015, 12:45 AM
  #317
E63 W212
Thanks. I guess I'll get them replaced. Will pick up the car Wednesday.
Old 02-25-2015, 12:37 PM
  #318
63xx's Avatar
c63 mct
can u check mine ? WDD2040772A639191
thanks
Old 02-26-2015, 09:06 AM
  #319
Valvestud's Avatar
thanks
Not affected.
Regards,
Joe
Old 02-26-2015, 08:18 PM
  #320
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
Can you check vin for one Im looking into purchasing: WDDGF7HB6BF551809
also any background info I would be able to get on it?
Old 03-02-2015, 10:42 AM
  #321
Grant Hay's Avatar
2010 C63
Hi Joe,
Would it be possible for you to check whether my car is in the affected range please.
the vin no is WDD2040772F606366
Grant
Old 03-02-2015, 07:55 PM
  #322
Valvestud's Avatar
Originally Posted by Grant Hay
Hi Joe,
Grant
Not affected.
Regards,
Joe
Old 03-02-2015, 08:11 PM
  #323
2012 C63 P31 sedan
Grant
To avoid confusion it's worth pointing out that this car is a UK car built well after the changeover (11/2010 and VIN over 600000), but is listed as 2010 because of how Europe labels cars - by manufacture date, not model year (like the US).
The title of thread refers to US Model years. A car with a similar build date would be a 2011 in the US.
Old 03-03-2015, 04:19 AM
  #324
Grant Hay's Avatar
2010 C63
Sorry guys , I should have stated that the car is a Uk vehicle
Old 03-06-2015, 03:46 PM
  #325
scola888's Avatar
07 E63 AMG
WDBUF77X97B128469
Thx Joe!
Quick Reply: Head Bolt Affected VIN - 2010 & older, & early 2011s
