C63 AMG (W204) 2008 - 2015
Shift Question in C, S, S+
Old 04-10-2014, 03:22 PM
ParkerK's Avatar
C63 507, 911 Carrera, Range Rover, Disco
So lets say you are in any of these modes - essentially anything but manual mode and you have the accelerator floored, does it ignore your paddle inputs?
I was in 2nd in S+, accelerator to the floor and tried to shift to third (since I had no traction anyway) and it ignored the input, tried it twice and it never shifted, went right to redline, then shifted to third. I think I remember this happening as well in C a few times...?
Just curious, is that normal?
This was in a 14, 507 btw.
Thanks -
Old 04-10-2014, 03:59 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
Yes it's normal. In C, S, and S+ it will downshift when you floor it and hold it pretty much to redline as long as it's floored. Pulling the upshift paddle woln't do anything in this scenerio.
Old 04-10-2014, 04:26 PM
Autosport7's Avatar
C63 AMG
507 doesn't give a damn about what you want, wants to drink 93 and breath O2!
AMG = ( . Y . )
Last edited by Autosport7; 04-10-2014 at 04:37 PM. Reason: My dumbass put H20 instead of O2 or oxygen (air)
Old 04-10-2014, 04:56 PM
ParkerK's Avatar
AMG = ( . Y . )
That is definitely a true statement...a strong pull in second to third and it feels like the car is trying to suck all of the air out of my ears...all the while the *** is shaking like Beyoncé, then you look down and realize you are doing triple digit speeds.
Old 04-10-2014, 05:57 PM
CMC-63's Avatar
C63 P31
Haha, know exactly where your coming from. Love hearing the car redline, but by the time I make it to third gear I'm already going much faster than I'm comfortable with in traffic
Old 04-10-2014, 06:06 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Thanks -
If you are in C, S, or S+ putting the car into any numbered gear means that is the maximum gear it will shift to. For instance, putting it in D3 in S+ and going from a standstill, the car is going to go through, 1, 2, then 3 and hold at three.
Assuming you do that from a standstill and are flooring it, if you decide to upshift in the middle of 3, to D4, the car is still going to go all the way to redline of 3 then shift to 4.
If you want it to shift when you want how you want, M mode is your friend.
Old 04-10-2014, 06:08 PM
507AX's Avatar
Black C63 507 Coupe
haha this is fantastic.
Old 04-10-2014, 11:46 PM
goatfarmer1970's Avatar
C63 Coupe 507, CLK55 Convertible, X1 35i, 70 GTO convertible, motorcycles
I personally drive around town in C and then use the left paddle to limit it to 2nd or 3rd or 4th as needed...not nearly as performance oriented as M mode, but a great real-world way to drive the car.
Old 04-11-2014, 07:28 AM
Stefj's Avatar
Mercedes c63 amg
Thanks -
I got the same problem the shift delay is also a big factor for the w204 amg. I go to euro barge and pay for the mod chip and they also improve the shift delay like a formula 1 well not the same but you shift the paddle and boom it's change faster and more accurate
Old 04-11-2014, 07:47 AM
estrellajon's Avatar
C63 ///AMG P30
AMG transmissions just shifts slow. Even in M mode.
Old 04-11-2014, 08:11 AM
rediesel's Avatar
The OP question was not related to shift speed. OP was not in M mode. Pulling the upshift paddle in any mode other than M will not cause the car to upshift - unless you were holding it in a lower gear at less than full throttle. In C, S, and S+ when floored the car will rev to the limit and shift just like any automatic - even when its spinning tires.
Old 04-11-2014, 09:47 AM
ParkerK's Avatar
Thanks for the info - is there a mod for faster shifts?
Old 04-11-2014, 10:34 AM
tfthach13's Avatar
'09 C63
Not a mod per se, but have you tried shifting with the gear stick (a la tip tronic)? It shifts more faster than the paddles.
Quick Reply: Shift Question in C, S, S+
