is this bluetooth compatible to an 09 C63?
06 CTT-S
is this compatible to an 09 C63?
any special install or just plug/play? i have the white wire adapter in the compartment if this info helps.. thanks in advance
*by the way, this was previously used/installed in an 07 E63
I don't have an answer to your specific questions, but what is that thing? Is it the BT module that hooks up to the COMAND, or is it a stand alone unit?
06 CTT-S
not really sure.. an amg group member posted this in FB.. local in my area so if this works i would take this.. as far as other things to hook up for install im not sure
It plugs into the Centre console.
Yes it should work.
But doesnt your 09 have BT Built in anyway? I thought all C63 had it built into the head unit?
Yes it should work.
Until 2012 the Bluetooth only functions for phone. There's no functionality for music. My 2010 is a frustration because the system will fully function including steering wheel controls and display if you hook up with a media interface cable, or use something like Tune-2-Air. Even then the system functions will not work on anything but the phone's music library. Streaming works but with no control on the car's controls except volume.
Regards,
Joe
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
The 6131 is a VPC item only (see this post here - https://mbworld.org/forums/audio-ele...ml#post3629198). It may not work unless your vehicle was prepped for it at the port of entry, so I'd probably refrain from buying it unless you have a chance to test it out first.
