UPD intake, anybody?
Anybody here with experience of this intake mod/system?
http://ultimatepd.com/2003-2007-merc...boost-kit.html
I'm tempted to make this my next mod on the car (whenever that may be) and I can see the logic behind it...seems like it should help. Wondering if this design is the reason why the Renntech intake seems to make hp and increase trap speed, whereas the carbonio etc doesn't.
Just curious to see any independent reviews before tossing it up between this and the Agency Power crank pulley.
Increasing the open air space in the filter housing is unlikely to make a significant difference since most of the pressure drop there is the filter itself. Going ROW airbox(eliminate the charcoal filter) and a high flow filter, will give you at least the same if not better result.
In case of doubt ask for the results from their CFD Analysis (Computational Fluid Dynamics) showing the pressure drop reduction. I would LOVE to see that response......
Why would a high flow filter give the same/better result (mated with a ROW airbox), if the restriction in the tube is still in place?
FWIW I'm assuming that the filter they're supplying is already higher flowing than stock.
FWIW x 2 my car is a euro model so it has ROW airboxes already.
Agreed, you're looking for increase in flow not volume. Your engine doesn't care how much volume resides in the filter housing. Aluminum also conducts heat very well, so chances are that metal spacer will warm the air inside the housing. Chances are the benefits you get from their "high flow" filter are negatively impacted by that stupid spacer they put around the housing.
CFD analysis is expensive and I really doubt a company like UPD would even do something like this.
CFD analysis is expensive and I really doubt a company like UPD would even do something like this.[/QUOTE]
That is my point.
CFD is a staple nowadays though. Any company can go to the next college and have some of their students do that for very little money. The students get a grade, the school is happy to have a real life example, and the parts manufacturer has a properly engineered part. The reason it is not done is not money. It is usually lack of understanding of the task or dedication to doing things correctly.
OP: If you want to do it, great. Do you know a dyno near you? It would be great to get a baseline, then swap out the filter in the orig. housing and do a run, then add the spacer and see what each change brought.
That is my point.
That is my point.
Anyhow, I totally agree that CFD should be a requirement on any automotive component that involves movement of air/fluids.
They are claiming over 20hp with this mod. That is quite a bit.
I can't see it gaining that much, but please do a before and after run if you do fit it.
Interesting comments guys.
The way I see it, there is some hp to be gained from the intake system because the Renntech one consistently makes power. I guess it's never been discussed before as to why it makes power, ie where the bottleneck has been opened.
Nearest dyno to me is a Eurocharged franchise, but I'm not overly keen on taking my car there. Maybe there's another one that I don't know about.
What I will say is that from what I've gathered in my reasonably long time I've been on this message board is that Shardul and Brooke are smart guys and they know their stuff. While 20hp does seem a bit on the optimistic side to me, I'm still hopeful that their product is a good one. Maybe I'll message them nearer the time and see if they're willing to cut me a special deal on the product so that I can get this dyno proven.
20 hp gain is not on the high side, it is totally not credible. But please try to get factual info if you can or this will never go beyond I think vs he thinks.
The way I see it, the only potential bottleneck would be at the MAF's and I think this has been dyno proven of around 10 whp as that is one of the main differences between the US spec air boxes and the ROW boxes.
Since you have them already, it's a moot point
Fair enough then guys, I'll let this thread die.
If I do move forward with this, I'll keep you all posted. Either that, or I'll just get the under-drive crank pulley from Agency Power.
