507 hood question
507 hood question
Just got my 507 hood in
I wanted to know if anyone could send me a picture of the underside of the hood
I just want to make sure I have all the parts
Thank you
Thank you
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
+1 on that. I'm going to cut holes in my OEM hood, so the underside of the vents would be particularly helpful to see thanks :Y
I would like to see as well. I think I'm going to retrofit the 507 Vents and tray to the PFL hood.
Was considering retro-fitting the entire FL 507 hood to my PFL. But too much work and I like the FL hood bulges.
Kriston (08-12-2016)
Could you take a detailed close-up picture of the back where the vents are?
2014 C63 Edition 507
photos...
Let me know what else you might need and I'll take larger ones. I think the hood liner and plastic bracket underneath the vent is going to obstruct the view you may be seeking. If you want, I'll pull the bracket and take some more, but i don't think i want to mess with the liner.
Check out this thread too - there are some good photos here: https://mbworld.org/forums/c63-amg-w...correctly.html
Thanks so much,
Does anyone know if the Mode Carbon vents for the 507/BS include the diverter trays as pictured under the hood?
They are difficult to track down but I luckily I had the part # saved for anyone else interested. They are $87 a piece.
2048850041 Left
2048850141 Right
I think Im going to do some cut and paste in the next few weeks on the hood.
Here is a list of the part numbers for the complete swap.
Item | Part Number
-10 204-880-12-57 -- Standard Hood
+10 204-880-13-57 ** 507 Hood
+15 204-750-01-44-9040 ** 507 Air Inlet Grill L
+15 204-750-01-44-9999 ** 507 Air Inlet Grill L
+15 204-750-02-44-9040 ** 507 Air Inlet Grill R
+15 204-750-02-44-9999 ** 507 Air Inlet Grill R
+25 003-991-02-70 ** 507 Mounting Clamp (qty 3)
+27 204-885-00-41 ** 507 Bracket L
01-41 ** 507 Bracket R
+29 000-990-54-92-9051 ** 507 Expansion Rivet Fastening Bracket Left 6MM (qty 4)
+29 000-990-54-92-9051 ** 507 Expansion Rivet Fastening Bracket Right 6mm (qty 4)
30 204-880-07-28 -- Hinge L
08-28 -- Hinge R
40 019-990-12-01 -- Bolt w Flange
50 015-990-21-01 -- Bolt for hinge to engine hood
90 204-817-06-16 -- Badge
100 204-880-00-29 -- Gas Operated Spring L
100 212 980 05 64 -- Gas pressure strut R
110 204-880-01-27 -- Spring Element for engine hood
120 169-889-12-95 -- Intermediate Layer for spring element
130 204-880-08-59 -- Hood Cable front
140 204-880-07-59 -- Engine hood release cable rear
150 204-880-01-20 -- Release Handle for engine hood cable, clipped
160 001-995-35 77 -- Line Holder
170 212-880-00-60 -- Engine Hood Catch
180 N910105 006023 -- Hexagon Head Bolt
190 204-880-00-64 -- Safety hook
200 N910105 006023 -- Hexagon Head Bolt
210 204-682-06-26 -- Sound Proofing
+210 204-682-12-26 ** 507 Insulation Engine Hood
220 001-988-03-25 -- Plug-in Mounting
240 000-988-44-40 -- Stop Buffer
250 N910112006001 -- Hexagon Nut
Item | Part Number
08-28 -- Hinge R
Or:
Saw / Cutting Wheel
Paint
Vents
Beer
Saw / Cutting Wheel
Paint
Vents
Beer
The following 4 users liked this post by BLKROKT:
