C63 AMG (W204) 2008 - 2015
Fuel Pump Issue? Tune Issue? Trans?
Old 11-07-2016, 07:19 PM
JordanSpaceJam's Avatar
2012 C63 Coupe
Hi Everyone,
For the past few months, my 2012 C63 has been more delicate than usual.
It has a Eurocharged tune and x pipe with 153,400kms and the tach is sputtering under acceleration. Stomp on it at it'll start to rev up then drop down then back up normally. I only drive in M mode.
Any ideas?
Recently did an oil change, spark plugs and O2 sensors.
Thanks in advance
Old 11-07-2016, 07:32 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
No codes?
What are your fuel trims?
Old 11-07-2016, 07:42 PM
2012 C63 Coupe
No codes.
Not sure about the fuel trims. I've never messed with those unless they're involved in the tune?
Old 11-07-2016, 09:19 PM
Jasonoff's Avatar
2010 C63 AMG
It hesitates under load which could be a number of potential issues.
Plug in a scanner and share your STFT/LTFT data for a starting point.
Otherwise we're just throwing darts in the dark...
Old 11-07-2016, 10:11 PM
mr747's Avatar
c63
log the car and post up logs so we can see
Old 11-07-2016, 10:13 PM
2012 C63 Coupe
Ok thanks. Will do.
When I did the last oil change, spark plugs and o2 sensors, the scanner didn't produce anything and the car would not replicate the issue at that time.
Please stay tuned.
Old 11-07-2016, 10:18 PM
mr747's Avatar
c63
Its not trans cause trans will slip or will put car in limp mode
a tune will not just stop it has to be either air or fuel issue could be a bad maf
If there is a issue there should be a code
Old 11-07-2016, 11:17 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Sounds like a bad MAF sensor, but strange that there are no codes.
Old 11-08-2016, 10:57 AM
Vladds's Avatar
2010 C63 2019 GLA45
So here's something that I saw years ago in my Alfa Romeo:
You drive around, you floor the accelerator, the rpm climb then there's a sputter and the tach drops dead incredibly quick, then picks up again.
If this is similar, look into grounding.
At the time, I noticed that the top portion of the manifold did not have a clear grounding path, and several of the sensors were positioned there.
Grounding problems don't throw codes either.
I looked at the M156 and the manifold grounds to the rest of the engine through the aluminum bolts, that fasten it to the heads
I wonder if the heads ground to the rest of the engine .......... Through the head bolts.
Anyway, as the mileage climbs, grounding issues can appear. Try to run a simple ground strap from the manifold to a ground point on the chassis.
Old 11-09-2016, 06:24 PM
604 C63's Avatar
2012 E550 Cabrio
Fuel issue. Seen it before in my buddy's E63S.
Now, are you sure no codes, or are you just referring to no CELs? Cos he never had anything that indicated a code but when we ran my bluedriver we pulled up code P0087 re fuel rail/system pressure. I think it ended up being a glazed fuel sock or something like that.
Old 11-20-2016, 08:32 PM
2012 C63 Coupe
Thanks everyone.
Test Report from the scan shows P0013 - "Continuous camshaft adjustment (RIGHT): Incorrect position of the exhaust camshaft (P0013)"
I don't know what to make of this.
Old 11-20-2016, 08:52 PM
Jasonoff's Avatar
2010 C63 AMG
Something wrong with the adjuster. It may need to be replaced, or re-leanred.
Old 11-20-2016, 09:09 PM
2012 C63 Coupe
Thanks Jasonoff. Any idea how something like this might happen? What kind of repair bill am I looking at?
Old 11-27-2016, 03:21 AM
2012 C63 Coupe
Does anyone else have any insight?
Old 11-27-2016, 08:06 AM
Vladds's Avatar
2010 C63 2019 GLA45
Are you going to do this yourself?
Old 11-30-2016, 08:25 AM
2012 C63 Coupe
No I am not going to be doing this myself. Is this a major job?
Old 11-30-2016, 08:51 AM
Jasonoff's Avatar
2010 C63 AMG
No, but I believe a cam adjuster is ~$5-600 for the part if it needs to be replaced.
Old 11-30-2016, 10:43 AM
Vladds's Avatar
2010 C63 2019 GLA45
If you are going to have a shop do this, your bill will depend on how much they want to mark up the parts and what they want to charge you for the labor.
A shop other than the dealer would need to have a set of M156 cam hold down tools and a tester capable of re initializing the cams. I'm not sure that the snap-on that many shops have could do this.
The adjusters appear to me to be sold in sets. Also i noticed that there is a new part number, there probably was an update to the design.
When these are replaced, I would replace the special washer that retains the assemblies too, if it's not in the set.
Old 12-04-2016, 10:19 AM
2012 C63 Coupe
Thanks everyone. I'll keep you posted.
Took the car to the local dealer for a B3 service and they said nothing was wrong...
