CL-Class (W215) 2000-2006: CL 500, CL 600
Problem with suspension i think... help
Old 05-09-2010, 03:53 PM
YamanKaro's Avatar
Cl500
Exclamation Problem with suspension i think... help
I've been experiencing a problem, that when i go into small bumps or even if the road is slightly uneven or wavy the back of the car starts fishtailing or swaying... i took it to the dealer they were not able to find out what the problem was, i took to a independent mercedes technician and they couldn't locate the problem, so i need help...
Old 05-09-2010, 06:04 PM
Ifari's Avatar
2000 CL500 1992 300SE
Top up your ABC fluid reservoir.
Old 05-09-2010, 06:15 PM
YamanKaro's Avatar
Cl500
I have already done that, doesn't help, it's really bad and on the highway it gets dangerous
Old 05-09-2010, 07:49 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
What condition are the tires in?? How many miles on the car??
Old 05-09-2010, 07:53 PM
YamanKaro's Avatar
Cl500
the car has 66,000 miles, the tires are all brand new, has about 100 miles on them.... i changed the rear shocks and the problem also occured again..
Old 05-11-2010, 03:08 PM
duhdenmark's Avatar
CL600
Have you had a abc fluid and filter change recently, if not maybe you should start there?
David
Old 05-31-2010, 12:26 PM
mheglin's Avatar
2002 CL500
Exact same suspension issue with our CL?
We are having the same issue. Over small bumps, rumblestrips, manhole covers, it fishtails. Dealer aligned and said could find anything else.
Now looking for answer at independent repair facility. Any feedback would be appreciated. Mike
Old 06-01-2010, 12:13 PM
Gondon's Avatar
02 S500 Sport
What a scary issue. Maybe your Tire PSI, but I'm sure that's the first thing they checkout. Frame Damage from an accident?
Old 06-01-2010, 12:20 PM
ivanj's Avatar
Yugos only
Ideas - you assume liability for these if you choose to drive the car to self diagnose. Understood?
Has your car had all the Bulletin repairs and is completely up to date? The dealer ca tell you this.
Try another dealer.
Has the Comand or other electronics been flashed or lost their flash because the battery was disconnected for service? Is all the firmware up to date? You need both the Comand and the OBD-II codes.
Try driving the car with the ESP off; change the ABC to Comfort Mode (C) if you have one.
Sometimes the ESP units go wacky and overcompensate for driving.
Do your wheels have the correct offset for the car? I had a similar problem when I changed to Mandrus wheels for winter tires. They are built for the non-AMG offset (3x vs 44m) and caused no end of issues like yours until I bought some used AMG wheels with the proper offset.
Have the dealer do the "rodeo test" on the ABC suspension - required after they do any "rear shock" work - this may diagnose the problem.
Call your local MB or AMG Zone rep.
Old 03-13-2015, 09:13 AM
Danillano's Avatar
CL500
Sorry I know this is old but did you ever figure out what the problem was?
Old 03-13-2015, 09:26 AM
mheglin's Avatar
2002 CL500
[QUOTE=Danillano;6362962]Sorry I know this is old but did you ever figure out what the problem was?[/QUOTE
Dealer was never able to diagnois. Had in 5-6 times and had abs issue, replaced rear tires, etc. Last tires we tried were nitto's and were cheaper and had best drive.. better than the michelins.
Awsome car but lot of mechanical issues. Should have never parted with mine as i had fixed everything.. Good luck.
Old 03-15-2015, 08:19 AM
Welwynnick's Avatar
2006 S600
This sort of thing can be caused by the rear strut top bushes becoming detached from the bush mountings. You can see the effect very easily by jacking up the rear of the car so the wheel hangs free. See if the wheel is solidly located, or is it able to move up and down a small amount.
Nick
Old 03-23-2015, 06:40 PM
fireman685's Avatar
2005 CL55
Originally Posted by Welwynnick
This sort of thing can be caused by the rear strut top bushes becoming detached from the bush mountings. You can see the effect very easily by jacking up the rear of the car so the wheel hangs free. See if the wheel is solidly located, or is it able to move up and down a small amount. Nick
I'll have to check this out as my car does not feel as stable as it should going over bumps. I just replaced all the front lower control arms and ball joints. The mounts on my front look like hell being all cracked looking. I'm sure the rears don't look any better. After work I'll try driving home with the ESP off and see what happens.
Old 04-06-2015, 04:28 PM
rediahad's Avatar
magLipVE
did anyone ever figure this out?? im having the same issue and i also noticed that after i turn off the car the side that feels sluggish immediately bottoms out
Old 04-06-2015, 09:50 PM
fireman685's Avatar
2005 CL55
Turning the ESP off did not make any difference for me. I've got other irons in the fire so I will not worry about this for now.
You have a bad valve block allowing the pressure to immediately bleed off. Options are to buy are new or good used one or have yours rebuilt. Depending in mileage, if the car still has its original nitrogen spheres, I'd replace all four of those as well.
Old 04-15-2015, 04:09 AM
fireman685's Avatar
2005 CL55
I'm beginning to suspect rear control arm bushings. As soon as I'm physically able to, I'm going to jack up the rear and get a pry bar and check my bushings. If you can easily wiggle the control arm with a pry bar then the bushing is bad. I've already replaced the front ones.
Quick Reply: Problem with suspension i think... help
