CL-Class (W215) 2000-2006: CL 500, CL 600
misfire after hot restart (solved)
Old 02-12-2017, 02:35 PM
Shiv Sikand's Avatar
2005 CL65
I was getting a serious misfire after a hot restart. Car would run terribly, and then throw misfire codes on multiple cylinders on both banks. Shut off and restart would solve it, and no misfire at speed or WOT. Started to do it more often. Bought 2 coil packs wholesale from the dealer for around 1K each, plus the plugs and car is like new again. Good color on plugs
New coil packs installed
Drivers side was harder than passenger side
biker349 (10-23-2019)
Old 02-12-2017, 02:38 PM
2005 CL65
My codes from STAR
Old 02-13-2017, 05:11 AM
tusabes's Avatar
Mercedes
Awesome pictures , thanks for posting this !
Did you consider changing the ignition transformer too ?
Old 02-15-2017, 11:23 AM
2005 CL65
From what I've read, the ignition module failure causes a misfire on every cylinder in a bank. It also throws a specifc code. So at this time I'm not going to replace it unless I get additional misfire issues.
Old 02-15-2017, 11:33 AM
g60wall's Avatar
2014 E63s
I had same issue, replaced coil packs and plugs. Still misfired on hot start, changed voltage converter everything has been perfect since. I'm looking at retrofitting heat sinks to voltage converter
Old 02-15-2017, 11:34 AM
g60wall's Avatar
2014 E63s
The build date on my voltage converter was 37w11, my new one from amazon 47w16
Old 02-15-2017, 12:23 PM
2005 CL65
Thanks for that info. I will report back if the misfire returns.
Old 02-15-2017, 12:27 PM
2005 CL65
What did your misfire codes look like?
biker349 (11-01-2019)
Old 02-26-2017, 07:45 PM
g60wall's Avatar
2014 E63s
Well
i continued down this rabbit hole. My hot start misfire would only happen on cylinder 1 and 7 sometimes 9 or 8. The voltage converter didn't solve it. It seems to be a vapor lock issue in the fuel rail. Some early bi-turbo cars have a 4 bar fuel pump control unit this isn't strong enough to fill the fuel rail up when then the ethanol has boiled off and vapor locking the fuel rail. I orderd the 5 bAr control unit and will be swapping on asap.
Old 02-27-2017, 03:19 PM
tusabes's Avatar
Mercedes
Please let us know if the 5 bar fixes it
Old 02-27-2017, 03:33 PM
g60wall's Avatar
2014 E63s
Yea I will report back asap
Old 05-06-2017, 11:34 AM
2005 CL65
Car is running perfectly.
Old 05-06-2017, 05:16 PM
g60wall's Avatar
2014 E63s
100 percent fixed my issue!
Old 10-22-2019, 09:26 PM
mskimd's Avatar
2014 GL450
Range of defective m278 engine #’s?
Sorry. Posted on the wrong thread and I can’t find how to delete. I don’t mean to hijack this thread.
Does any one know if there is known range of defective engine #’s to look up? If so where can I find those?
thanks,
Martin
Old 11-01-2019, 12:35 AM
MrTracy's Avatar
2007 S550 & 2009 CL63 AMG & 2009 BMW 328i Convertible
Tell me more about this "Some early bi-turbo cars have a 4 bar fuel pump control unit" I seem to get this random cylinder misfires; its happened twice. I shut off the car and clear the codes and I'm off again with no problem. It just happened twice so far. Do you have an item number or pic?
Old 11-03-2019, 07:13 PM
tusabes's Avatar
Mercedes
Yes I’m interested in the 5 bar part number too
