Replaced Front Control Arms
Old 07-06-2016, 08:18 PM
  #76
Yidney's Avatar
2008 CLK550 Cab
Originally Posted by clydem
I second the vote on this tool. Sometimes you have to go quite far & the joint will let go more with a loud bang than a pop. Scares the bejeezes out of me.
So I have a very steep driveway, the suspension usually goes from compressed to fully extended a lot and consequently, bushings rip. It's time to replace the arms/bushings.
Anybody have a link to the strut bearings & sway bar bushings procedure that is as good as this write-up? Since I'm in there anyway. (and time to replace the rotors too)
Thanks in advance,
Clyde M.
Regarding the sway bar bushings, you need to figure out if you have the replaceable kind or the ones that are part of the bar. If the former, the method to replace them is self-evident. Remove clamps and put new bushings on. As easy as any repair can get. Are your strut bearings bad? I don't know that I'd do those if they are still good.
Old 07-06-2016, 10:57 PM
  #77
ambit's Avatar
09 CLK550
Thanks in advance,
Clyde M.
I did the strut bearings here:
https://mbworld.org/forums/clk55-amg...ml#post6527401
I do not enjoy compressing the front springs on the W209. My old CL203 was 10x easier.
The sway bar bushing are super easy, like 30 mins total.
Put car on ramps. Remove belly pan.
Loosen 2x inverted torx bolts over each bushing. Swing sway bar down and swap them out.
Old 07-07-2016, 02:28 PM
  #78
clydem's Avatar
2005 320CLK Cab
thanks very much for posting the link.
Old 07-23-2016, 03:07 PM
  #79
Yidney's Avatar
2008 CLK550 Cab
Ambit,
I just did my right side today, and I have a question for you since you reported that the car did not drive straight after you were done. You mentioned fluted bolts. By fluted, do you mean the bolts had two grooves along their length, and the two grooves were not quite opposite each other on the bolt shaft? And were the bolts on the other arms just smooth bolts? And was your "oops" picture one of the fluted bolts or smooth bolts? Because I think if that oops pic was a fluted bolt, you may have installed it wrong. You used sharpie marks to pay attention to having the bolt head in the same location, but the much more important part of the fluted bolts is how they go in the arm. Once they are in the arm right, the head will automatically be in the right location, so if that opps was a fluted bolt rotated a few degrees, then it is not where it is supposed to be. Anyway, I won't explain more in case I'm wrong about what you meant by fluted.
Old 07-23-2016, 09:40 PM
  #80
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
Fluted bolts on the control arms are used to adjust camber. If you use those, then you need an alignment (using a shop that knows how to use these special bolts!) But, new control arms should negate the need for a camber adjustment, so you need to go back to standard bolts.
Old 07-23-2016, 11:15 PM
  #81
Yidney's Avatar
2008 CLK550 Cab
Yeah, I know what they are for. But why do you need a special alignment shop once installed? There's no adjustment to them. They are a very crude technology. They just yank your arm in about 1/4". Also, why would new arms fix negative camber? Seem like it would make it worse if anything because fresh bushings will push the bottom of your knuckle out some.
Old 07-24-2016, 01:09 AM
  #82
ambit's Avatar
09 CLK550
Originally Posted by Yidney
Ambit,
I just did my right side today, and I have a question for you since you reported that the car did not drive straight after you were done. You mentioned fluted bolts. By fluted, do you mean the bolts had two grooves along their length, and the two grooves were not quite opposite each other on the bolt shaft? .....
Uhh I'm trying to remember, it was over a year ago
Yes there was 2 grooves down the side of the bolt shaft. It put it all back together with the suspension under load, aligned with the ink marks.
I ended up taking the car to MB for a 4 wheel alignment anyway. They used the OEM bolts to set it straight. I recall them mentioning if they can't adjust it enough with the existing bolts that there is a 'bolt kit' they would use @ $30/side.
I think just the toe needed to be set. The camber that these bolts control was fine.
I've done 4 other cars front suspension since then and I can get alignment almost perfect by sight now
Old 07-24-2016, 02:04 AM
  #83
Yidney's Avatar
2008 CLK550 Cab
Rodney,
The more I think about it I guess new bushings would pull the bottom in a bit, but unless the bushings were really bad the difference would be small compared to how much the camber bolts move the arm in. My car has had them since just after I bought it at 25K miles. I'll post some pics after I do the left side tomorrow.
Old 07-24-2016, 10:38 AM
  #84
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The fluted bolts don't offer just a single position camber adjustment. They offer a range of adjustment as you rotate them. That's why you need an alignment - you set the car in the rig, then rotate the bolts until camber meets the desired angle.
Old 07-24-2016, 01:17 PM
  #85
Yidney's Avatar
2008 CLK550 Cab
I'll post up same pics later, but no, they do not offer a range - just three positions, only of which matters. And they cannot be rotated at all.
Old 07-24-2016, 02:44 PM
  #86
ALFAitalia's Avatar
Alfa 159
Looking at the manual it looks like only two position. 4mm apart?? And yes they cannot rotate when inserted. The flutes job is to stop rotation....ridges slide into those flutes.
Old 07-24-2016, 04:53 PM
  #87
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
If the bolt has two flutes on opposite sides, then it can only be used in one of two positions. There is another style with a single flute that works like a cam. As you rotate the bolt, it moves the control arm mount in and out. That's the style my local shop uses to fine-tune the alignment. But, with new control arms, unless there is some frame damage, camber adjustment should not be needed.
Old 07-24-2016, 06:37 PM
  #88
Yidney's Avatar
2008 CLK550 Cab
I just started a new thread called "How front camber bolts work" with pics.
Old 07-24-2016, 06:38 PM
  #89
Yidney's Avatar
2008 CLK550 Cab
I cannot picture how this would work given where the metal nibs are.
Old 07-24-2016, 08:12 PM
  #90
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Ironically, I did not realize the OEM bolts were made like that. The bolt I am familiar with is this below. I'm not sure this is for the W203/209, but it's the cam lob bolt that is granularly adjustable.
Old 02-04-2017, 11:56 PM
  #91
jwb007's Avatar
2005 CLK500
ESP Warning after replacing front control arms
Happy New Year. I subscribe to this tread for the sake of replacing all(4)front control/thrust arms and sway bar end links. I purchased all the parts from importpartsdepot on eBay. There pricing beats partsgeek by substantial margin.
The job was completed today by an indy shop, 4 Guys Auto center in tampa fl. My hats of to the owners and team at this shop. The respect, courtesy, quality work and transparency from this shop, are steps above many in the area.
Anyways, i noticed ESP malfunction warning on my way home. I will have to wait till monday to have issue resolved.
I am hoping that members here can shed some variation of light on this issue. This will assist and aide me in having this resolved.
Thanks in advance.
Old 02-05-2017, 02:04 AM
  #92
Yidney's Avatar
2008 CLK550 Cab
Probably your "step above " guys either forgot to put a speed sensor back on or broke the wire to one.
Old 02-06-2017, 08:33 AM
  #93
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Or they disconnected the battery and did not reset the esp
Old 02-06-2017, 09:29 AM
  #94
Yidney's Avatar
2008 CLK550 Cab
Don't think any reset is required. I've disconnected my battery several times - for up to two weeks, and never had to reset anything but windows.
Old 02-06-2017, 12:57 PM
  #95
sailorben's Avatar
CLK W209
Ditto. I've not had to reset anything other than windows either.
Old 02-06-2017, 01:01 PM
  #96
insame1's Avatar
You have never had to turn your steering wheel from lock to lock 3 times so the abs and esp error would go away?
Old 02-06-2017, 03:21 PM
  #97
Yidney's Avatar
2008 CLK550 Cab
Nope. I recall reading about that procedure in a number of threads, but can't recall now what supposedly triggers the need to do it. If it is just disconnecting the battery, then it must be one of those weird mysteries why only some people have to do it.
Old 02-06-2017, 10:14 PM
  #98
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I am no sure what triggers the need for the reset, but it's not always needed after the battery is disconnected. My C240 seems to never need it, the CLK was about 50/50 and the SL is, so far, 100% needing the steering calibration reset with a battery disconnect.
Old 02-14-2017, 01:10 PM
  #99
jwb007's Avatar
2005 CLK500
I took heed to your suggestion. The vehicle was returned to shop for an inspection. Neither sensors/wires were disconnected.
However, warning "ESP Unavailable See Manual" is still on.
Battery was not disconnected to during the replacement of the front control arms.
However; when driving, the steering wheel has to be in slight tilt/turn position when going straight.
Would resetting the steering angle sensor correct both ESP Warning and the Steering wheel position? Or do i need an alignment?
Thanks again
Old 02-14-2017, 01:55 PM
  #100
Yidney's Avatar
2008 CLK550 Cab
You need two things. You need to get the car scanned by somebody with MB's Star system so you don't have to guess why your ESP is on. Second you need an alignment. New bushing can change things quite a bit. Steering wheel position is a physical thing and not controlled a sensor.
But to edit this - try the steering reset procedure and see if that works for the ESP. It may.
Quick Reply: Replaced Front Control Arms
