Replaced Front Control Arms
Old 05-04-2015, 11:45 PM
  #51
megacrazy's Avatar
CLK55 W209, CL63 W216
Originally Posted by Rudeney
Did you install new control arms, or just replace the bushings? There is no way to remove the upper control arm's ball joint for the hub without removing the shock from the hub.
Yup. Upper control arm/thrust arm whatever you want to call it. The strut stayed in the car. All you have to do is remove the lower 2 bolts that attach the strut to the knuckle. Maybe that's where the confusion was.
Old 05-06-2015, 10:09 PM
  #52
MBworld Guru
Rudeney's Avatar
Received 1,002 Likes on 870 Posts
NO LONGER ACTIVE
Oh, yes, you're correct - you must disconnect the struct from the hub, but the top of the strut remains attached to the shock tower. I thought you were saying that you did not have to remove the strut from the hub at all.
Old 05-07-2015, 10:33 AM
  #53
megacrazy's Avatar
State of the bushings at 50k miles:
Old 05-08-2015, 11:04 PM
  #54
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yep, they are gone - time to replace!
Old 06-03-2015, 09:17 PM
  #55
AMG_Adon's Avatar
05 E55
hopefully someone who ordered from partsgeeks can help me out i ordered the for control arms seems the one of the upper control arms came with 2 washer like nuts and the other upper control arm didnt am i missing anything?
Old 06-03-2015, 11:18 PM
  #56
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Each of mine came with a new nut. It is recommended to use a new one on the ball joint attachments to the hub.
Old 06-04-2015, 06:20 AM
  #57
AMG_Adon's Avatar
05 E55
Each upper control arm came with 2 nuts ? So that means I'm def missing 2 nuts from one of my upper control arm then
Old 06-04-2015, 10:04 PM
  #58
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Actually, I think maybe only two of the set of four came with new nuts. I can't remember now if it was the "upper" or "lowers" that had them.
Old 06-05-2015, 06:12 AM
  #59
AMG_Adon's Avatar
05 E55
It's the upper .one of the set is missing new nuts the lower set doesn't come wit any at all
Old 06-05-2015, 09:38 AM
  #60
megacrazy's Avatar
That's correct. The "upper" aluminum ones come with nuts. The black "lower" ones don't.
Old 06-07-2015, 01:51 PM
  #61
AMG_Adon's Avatar
05 E55
would it hurt to reuse the 2 old nuts from the old upper control arm?
Old 06-08-2015, 12:21 AM
  #62
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Probably not. Generally, aluminum or other soft metal nuts or bolts need to be replaced, but steel is fine to reuse. I suspect that they extra nuts are included in case one used the nut as a "hammer point" to separate the ball joins from the hub, but using a proper tool, that would not be the case.
Old 07-26-2015, 01:07 PM
  #63
NickLouis's Avatar
CLK 500
I plan on tackling this project sometime next week, I have new upper and lower control arms ordered. I replaced the tie rods myself and it was a nightmare to remove the two ball joint ends. This project requires removing four, so wondering if anyone has any helpful tips for popping them. I have a pickle fork, ball joint separator which did NOT WORK last time. Should the wheel hub be jacked up in its normal position when removing them?
Old 07-26-2015, 10:31 PM
  #64
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
A pickle fork probably won't work. I used this tool for the ball joints and it worked very well:
http://shop.advanceautoparts.com/p/o...all+joint+tool
There is no need to jack the hub while removing anything YoOu only need vehicle weight on the hub when torquing the bolts for the control arm bushing at the frame.
Old 08-03-2015, 10:06 PM
  #65
NickLouis's Avatar
CLK 500
Athe torque specs for the "upper" control arm same as the "lower" control arms?
50nm plus 60 degrees at ball joint and 80nm plus 120 degrees at frame.
Old 08-03-2015, 11:57 PM
  #66
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, those are the correct torques and same for both upper (torque strut) and lower (cross strut) control arms.
Old 06-15-2016, 04:16 AM
  #67
Khan 55's Avatar
2004 CLK55 AMG W209
Great post. Will help me soon on repairing mine. So the shock never unload after you removed it from the steering knuckle? I thought one would have to compress the spring a bit.
Old 06-15-2016, 09:49 PM
  #68
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
No, the spring is trapped within the shock "cartridge". It just hangs from the top mounts while you do the work. In fact, you can easily the entire shock/spring assembly as one unit without and special tools.
Old 07-03-2016, 02:59 PM
  #69
Yidney's Avatar
2008 CLK550 Cab
Rodney,
Changed my oil today and had the black oil coming from one bushing, so time to do all four. Two questions: What are the torque specs for the strut? Second, I note the numbers stamped on my arms are not even close to the numbers you gave, so I just want confirm they are all the same regardless of sport suspension, etc. My four numbers are:
Lower left: 188 203 10
Upper Left: 203 04 L (why are these such short numbers?)
Lower Right: 184 203 11 (I thought it would be 188 as well)
Upper Right: 203 05 R
Thanks.
Old 07-03-2016, 03:15 PM
  #70
Yidney's Avatar
2008 CLK550 Cab
Also, I just went to Parts Geek where you got your parts, and for an '08 550 the first 8 parts listed are each arm with 2 different part numbers - all Lemforder - with slightly different prices. Any idea what the difference is? Looks they are stocked in different warehouses, but I can't see why somebody would pay $8 more for that.
Old 07-04-2016, 12:19 AM
  #71
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I have no clue why partsgeek has those different prices/parts. Maybe they drop ship some? As for torque, its 50nm plus 60 degrees at ball joint and 80nm plus 120 degrees at frame.
Old 07-04-2016, 08:53 AM
  #72
Yidney's Avatar
2008 CLK550 Cab
Rodney, do you have the torque specs for the 3 bolts holding the strut/shock tower to the hub?
Old 07-04-2016, 11:10 AM
  #73
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Strut to steering knuckle is 110Nm.
Old 07-06-2016, 05:58 PM
  #74
clydem's Avatar
2005 320CLK Cab
http://shop.advanceautoparts.com/p/o...ll+joint+tool.
I second the vote on this tool. Sometimes you have to go quite far & the joint will let go more with a loud bang than a pop. Scares the bejeezes out of me.
So I have a very steep driveway, the suspension usually goes from compressed to fully extended a lot and consequently, bushings rip. It's time to replace the arms/bushings.
Anybody have a link to the strut bearings & sway bar bushings procedure that is as good as this write-up? Since I'm in there anyway. (and time to replace the rotors too)
Thanks in advance,
Clyde M.
Old 07-06-2016, 06:32 PM
  #75
sailorben's Avatar
CLK W209
On my version of the tool ball joint separator, it's quite a bit chunkier than the one in that link. But it's served us well. Well when I was changing over the track rod ends, on the one side, the ball joint just wouldn't budge. It even ended up shearing the pin that the tool pivots on. That was a nasty surprise.
I'm always cautious of the force that can be built up; with tools like these, so I try to keep a nice distance between any of me and the tool or joint!
Quick Reply: Replaced Front Control Arms
