300CE WITH 2JZ TWIN TURBO MOTOR SWAP
Old 01-10-2014, 05:19 PM
  #101
hookmyster's Avatar
e300 mossalman twin turbo
Originally Posted by RBYCC
hello mate hope you could help me i own a 300e mossalman twin turbo 1989 i have ASD but i am looking for slip diff can you help kind regards jason
Old 01-10-2014, 08:45 PM
  #102
jason3977's Avatar
04 E500 20in brabus monoblocks 1 serious 500E & 91 300CE 2JZ 2005 CL65
Sorry man I know of nothing regarding a diff for these cars! I had 2 other parts cars so if one broke i had spares!!!
Old 01-10-2014, 10:19 PM
  #103
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The ASD should be more then enough.
I still run a stock open 3.07 and with a balanced suspension seem to hook up both tires evenly.
Are you n the U.K. and did you recently purchase the car?
Ed A.
Old 01-31-2014, 10:49 AM
  #104
jeffrey.g's Avatar
C124 230 auto.
Ed A.
Hi,
What suspension upgrade's did you do?
Im planning to build a 2jz in my ce.
next week saterday i will pick up a complete rear subframe from a 300ce
It will get a complete overhaul(sandblasting and powdercoating All new bushings.) Do u have any tips for me what upgrade's i should do.
I'm planning to do this:
Bilstein b8 with Eibach springs
Sportline rear subframe bushing( 202 350 34 08 number for the kit)
500e or w210 e420 e500 or e55 amg rear sway baybar.
with the 2jz i wont go for 700hp only for 430hp that makes 400rwhp i think.It will be my daily, no crazy stuf only some burning tires sometime
Jeffrey
Cheer from holland
Sorry if the english is bad, I do my best
Old 01-31-2014, 12:45 PM
  #105
RBYCC's Avatar
Jeffery
Your English is excellent
New bushings are most important as they maintain factory spec in the suspension.
I'm running H&R Sport springs with about a 40MM +/- drop
Bilstein HD struts and shocks as I want more travel but same valving as the Bilstein Sport for street use and weight transfer.
Front and rear Sportline swaybars.
Front and rear upper strut/shock braces.
A suspension that is too stiff with limited travel tends not to maintain a good tire contact patch on typical rough street surfaces.
Ed A.
Old 01-31-2014, 01:01 PM
  #106
jeffrey.g's Avatar
C124 230 auto.
Jeffery
Ed A.
Thanks,
I almost lost my mind on the bushing part, i see alot of people use PU bushings(its much stiffer) but i think it will lose a lot of comfort with it, i want it stiffer than stock, but no track car...there are a lot of speedbumps in holland so u dont want a very stiff suspension here.
How does the car handle in a corner about 60mph(100km/h??) the rear sportline swar bar is 16.5mm right? do u think a 18mm rear sway bar will be beter or will it be overkill?
How much horse power do you make?
Old 07-09-2014, 09:11 PM
  #107
marques's Avatar
1990 300ce
I just got my engine,(jzx 100) 1jzgte vvti). I'll have access to it 2 month and depending how much time my 2 toddlers and 1 baby give me. Just purchase a radiator, engine mounts. Trying to figure out if i should keep the hydro fan waterpump.
Attached Thumbnails 300CE WITH 2JZ TWIN TURBO MOTOR SWAP-2014-07-09-17.57.40.jpg   300CE WITH 2JZ TWIN TURBO MOTOR SWAP-2014-07-09-17.58.10.jpg
Old 07-09-2014, 09:13 PM
  #108
marques's Avatar
1990 300ce
I just got my engine,(jzx 100) 1jzgte vvti). I'll have access to it 2x month and depending how much time my 2 toddlers and 1 baby give me. Just purchase a radiator, engine mounts. Trying to figure out if i should keep the hydro fan waterpump.
Old 10-02-2017, 12:07 AM
  #109
Ggo
Ggo's Avatar
91 300CE W124
Originally Posted by jason3977
TO wire up engine is easy it just 6 wires to start the motor! i have the whole pin out diagram for 300ce and 2jz turbo motor! not the difficult!
Hey man, I saw your old posts when I started to search this specific swap, can you help me out with some info? I am doing this same swap now and I would love to know if you still have the wiring diagrams? Also why did you drop this project?
Old 10-27-2018, 11:43 AM
  #110
AMGAZING's Avatar
SEC600 V8 AMG HAMMER, SL60 AMG, SL560, SEC560, W124 AMG Coupe
Wanted a 3.0 or 3.2 Mercedes twin turbo engine
Hi Guys
im looking at options to give my e220 coupe more power and the simplest seems the twin turbo conversion that Hughes of beconsfield Done years ago. Does anyone know of a complete car or engine with the twin turbo set up. ??
Im open to any ideas and would appreciate some help.
Thanks AMGAZING.
Quick Reply: 300CE WITH 2JZ TWIN TURBO MOTOR SWAP
