w124 Offset for 18" 8J+9J or 8.5J+9.5J
Old 03-27-2010, 11:01 PM
kereon's Avatar
w124 e220
Hi! I'm the new W124 owner. May I know what's the best offset for the 124? I'm going to have a set of 18" rim on it. They may be 8J+9J or 8.5J+9.5J. Any advise and about the offset of it? I'm afraid of rubing on it. I want to have the set of rims like these. Thanks!
Attached Thumbnails w124 Offset for 18" 8J+9J or 8.5J+9.5J-111167-1489680.jpg   w124 Offset for 18" 8J+9J or 8.5J+9.5J-111167-1489679.jpg
Old 03-28-2010, 08:56 AM
Declan's Avatar
230E-M102
i had Carlsson evo 19x8,5/10 with offset 40/5, it feels good with 5 people onboard and no touch the upper limit of the body
Old 03-29-2010, 07:05 AM
kereon's Avatar
w124 e220
Thanks Declan! So, what do you think about 18"? Will the same offset will be good too?
Old 03-30-2010, 09:49 AM
Declan's Avatar
230E-M102
18 is cool, the most important is that fitted precisely inside the fender
by the way, what was the 18'? brabus monoblock III, AMG SL, Carlsson 3/6 3pc was a stunning rims with different width
Old 03-30-2010, 11:05 AM
kereon's Avatar
w124 e220
Do you means even I get the exactly same size and offset as your 19" setup. If the wheel brand differ from yours, the result will not be the same. Right?
Old 03-30-2010, 01:11 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
The wheels you pictured are RIAL Daytona Race in 19" x 8.5" and 10".
Old 03-30-2010, 04:21 PM
YNVDIZW124's Avatar
lots of cars
You can run anything from a +35 to a +42 offset on the front with the correct tire. On the rear you can run higher offsets with wider wheels. Lowest offset you can do on the rear is probably +30 and highest is +45. That's a 500e so it has different fender dimensions and offsets. On a 300e you can run 18x9 +40 rear and 18x8 +35 front.
Old 03-31-2010, 03:59 AM
Declan's Avatar
230E-M102
right, because i also did :
- roll rear fender : this might be different result
- additional front stopper bilstein
- setting to 0.1/3 minus rear chamber
Old 04-02-2010, 05:07 AM
kereon's Avatar
w124 e220
Thanks all BIG BROTHER!!!!!
Old 04-02-2010, 12:14 PM
Declan, I'm amazed you got those carlssons to fit your 230e. I'm running the same wheels on my 500e and I still get rubbing in back! What size tires are you using? I have 275/30 in back.
The rubbing is on the inner wheel well, so I may be able to adjust the toe and fix it. My 285 tires would rub inside and out. :-/
Old 04-03-2010, 07:09 AM
kereon's Avatar
w124 e220
Oh! It really make me confusing all the time!!!! Anybody knows the right size, width and the offset on E320 as the picture on E500???? Pls help! I prefer have a 19" on my E320. But I accept having change down to 18" if there is no choice. ANYBODY HELP??
Old 04-04-2010, 03:09 AM
Declan's Avatar
230E-M102
i using 265/30, it will fitted by Pirelli Dragon/Yokohama Sport, but it'll give u a "square looks", not like Toyo/Falken
i'll think it will amazed to having Carlsson 1/6 Evo different wide inside 500E, not significant lose of power, isn't it?
Old 04-04-2010, 03:14 AM
Declan's Avatar
230E-M102
@kereon:
to had a smooth drive 18" will be great, but if the road of ur daily route was always flat & support then go for 19", others factor is the cost of the tire price it self
Old 04-04-2010, 12:24 PM
kereon's Avatar
w124 e220
@kereon:
Thanks Declan. I wanna go for 19". But I'm not really sure if I got 8.5J+9.5J, ET35 at front and ET40 at Rear. Is it workable? I don't mind roll the fender.
Old 04-30-2015, 06:47 AM
zk124's Avatar
w124, w203 , w204
MAE CROWN JEWELS 18" W124
Old 03-19-2017, 06:32 PM
autowiz's Avatar
94 E320 Coupe Sportline
What kind of muffler is that, looks great!
Quick Reply: w124 Offset for 18" 8J+9J or 8.5J+9.5J
