Fuse box wiring
I regret that I was unable to determine(via EWANET WIS) the wiring diagram for the W124.052 fuse and relay box and therefore not able to help.
Another correct way to locate the wiring diagram is to find a friendly dealer who has WISNET SERVER application he should be able to locate the diagram for you!!
1995 E320 w124
Well there is another very interesting point,I visited a local MB where I have some friends and used you VIN to do a search---we found the fuse box and the relay box and we could determine based on VIN, for example what system/option was fused in F1-1 and F1-B, but at that level we could not determine wire color because there was no diagram---however when we looked at the system in F1-1 and F1-B it did have a wiring diagram and of course we could determine the wire color and bla bla-----
Therefore, based on my short review to meet your objective you will need a VIN specific fuse and relay box diagram with what is fused---then you will have to go to each fused system wiring diagram to define the wire colors----that process will take loads of dedicated time and expensive for a garage with WIS.
You and your girlfriend may want to visit a junk yard, locate a compoable car, order in some bangers an mashed and carefully locate the wire colors!!Good Luck
1995 E320 w124
from a mercedes recycling centre, This gives me reference to most of the correct wiring, Im nearly there 90% is now working , Im missing a feed for my Hazard ~ Interior forward light and
indicators . Should sort it today sometime ,
Thanks again Sakhon
1995 E320 w124
fusebox Diagram
Cheers Sakhon
W124 E320 convertible 1995
Sakhon hello,
I think that if you could make a color picture of the back of the used box you bought with all the wires clearly apparent that would be very helpful for all of us. Many thanks in advance.
1995 E320 w124
An important thing to know is the new MB fuse box was faulty , The buzz bars or multi connector links in the fuse box were not attached to the posts properly giving me an intermittant feed problem ,
all the best Sakhon
