E350 2010 bumper type and LED drl cover grille question
Old 11-12-2013, 04:09 PM
  #101
timurik's Avatar
e350
Originally Posted by dmighty
did no one consider this option or is there something about it I am not aware of?
Why would you spend $300 on this type of led if you can get straight led for $200 (which will give you more elegant look, imo). You can totally install those, but you will still have to buy the grilles, etc.
Old 12-03-2013, 11:24 AM
  #102
Hfdafhx's Avatar
Pinto
Originally Posted by kalt
If you prefer not to solder or tap into the original harness you can use the cables below. You can also use a spdt relay on each side of the car to flip between the fog and drl cable. This way the LEDs come on durring the day, when you unlock the car or manually turn on the fogs. This method will also prevent bulb out warnings.
DRL CABLE
http://www.ebay.com/itm/130915483298...84.m1423.l2649
FOG CABLE
Amazon.com: Halo Automotive WHH11 Plug and Play Upgrade Wire Harness for H11 Bulb - Twin Pack: Automotive
Subaru? Do you need both of these? for a 2010 e350 sport conversion 4 rounds to one straight?
Also What spdt relay do you recommend ?
would be great if DRL and fogs work property with out SAM error
Old 12-03-2013, 01:02 PM
  #103
timurik's Avatar
e350
Why do you need a relay anyways? I think if you connect both drl wires and fog wires into led, it will work without a relay.
Old 12-04-2013, 01:43 PM
  #104
liftmys10's Avatar
2001 CLK 320 & 2010 E350 Coupe
the key word is "without solder or tap" Can you connect both of those wires into the led without soldering using your method of not using the relay?
Old 12-04-2013, 03:54 PM
  #105
timurik's Avatar
e350
I can't say for sure. It really depends.
Why soldering throws you off? I mean it's not difficult at all. If you haven't done it, just watch a video on youtube, I'm sure there are plenty of those. The tools for soldering are inexpensive. Plus, you'll learn something new
Old 12-05-2013, 04:29 AM
  #106
Hfdafhx's Avatar
Pinto
Are you sure? sending 2 signals to one light?
Has anyone tried this?
Old 12-05-2013, 11:25 AM
  #107
timurik's Avatar
e350
Yeah, but if you think of it, it's just one signal at a time (your fog light and drl don't light up simultaneously...). So, I think it should work, though I haven't tried it myself.
Old 12-13-2013, 01:59 PM
  #108
WebOs's Avatar
E350
Anyone tried this....
http://www.newegg.com/Product/Produc...9SIA1J30H00090
I have installed the LEDs but I haven't connected them yet I wasn't sure if I was gunna get an error. How ever I did get a message stating check fog light left and right.
Old 12-13-2013, 02:23 PM
  #109
WebOs's Avatar
E350
I also found these on ebay and it says plug n play. They are not at bright as the original MB LEDs.
http://bit.ly/1cGHxz8
Old 12-16-2013, 10:58 PM
  #110
dmighty's Avatar
2010 E350 Sport
Where?
Old 12-17-2013, 02:06 AM
  #111
whyycharles's Avatar
2010 Mercedes Benz E350 P1 Sport
I have an pair of oem Benz straight leds if someone wants them. I brought them brand new but never got the chance to use them. So if anyone wants them, I'll sell them for what I paid for it, pm me
Old 12-17-2013, 11:42 AM
  #112
WebOs's Avatar
E350
Question for the folks who has installed the straight LEDs... Did you guy get an error code or did check engine light came on? I haven't connected my LEDs but I do get check DRL warning every time I start the car.
Someone please answer.
Thank y'all
Old 12-17-2013, 11:47 AM
  #113
WebOs's Avatar
E350
Did u get any error code when u installed the LEDs? I've installed the straight LEDs but I haven't connected them cus the shoppe told me it will turn on the check engine light since they are not the same voltage. Wires are disconnected but I get message saying check DRL.
Help
Thank you
Old 12-18-2013, 10:11 AM
  #114
dardevil117's Avatar
mercedes e350
So have you tried connecting both cables to led. Just wondring if it wont throw any error. Curentlly got spdt releys but something wrong goes with them and when i activate fog, led starts blinking and releys starts ticking. Any way to got drl on during night with lights on without turning fog knob.
Old 12-19-2013, 07:37 AM
  #115
ales.lukez's Avatar
508 GT
Old 12-19-2013, 12:36 PM
  #116
Barca93's Avatar
C63 S Cab, Previous Maserati Granturismo Sport and E550 Cab
Need some help with this if anyone could please chime in. I have a 2011 E class with the L shaped LED lights and want to convert to the straight bar lights on the 12/13 models. I have found some on Ebay that are much cheaper than the dealership. Only problem is I don't know if the straight bar LED lights will fit on the connector of my L shaped LED lights? Thanks in advance.
Old 12-19-2013, 09:15 PM
  #117
WebOs's Avatar
E350
The one on ebay is not as bright as the original MB LEDs but either way u need to modify the wires and u need buy the grill that's holding the LEDs. You can also ask the seller. They seem to know what they're talking about. I've asked them few questions before.
Old 12-19-2013, 09:22 PM
  #118
Barca93's Avatar
Ok thanks for response. But I actually found the OEM mercedes lights on ebay by searching the part number. I will be buying the grill that holds the LED's from the dealership. Also I have tried to contact the sellers but they have no Idea if it will work (Which I know it will work, just don't know how. Since I have seen a member here do the exact same conversion I want to do). They also do not know if I need the version without wires or the version with wires.
Old 12-19-2013, 09:51 PM
  #119
WebOs's Avatar
E350
I have 2010 with round lights. not sure how your LEDs function but the new straight LEDs dims out when the low beams come on. With mine it stays unless I switch to fog.
They're also not the same voltage. It will ask to check DRL every time u turn on the vehicle.
Old 12-21-2013, 09:02 AM
  #120
jerome8283's Avatar
GLS450
Where?
To go from round fogs to straight you'll need the following..
Parts.com (the parts are for a 2012 which will work on the 2010) $178
2128851753
2128851853
2128852174
2128852274
The straight LED DRL's 2049068900, 2049069000 you have to email ales.lukez@gmail.com and ask for the LED lights with the wires attached. That was $200.00 with shipping. He's from Slovenia. It only took 5 days once he shipped them to me in NY. $200.00 with shipping
I had mine installed at a local dealer in NY. $80.00
Old 12-21-2013, 09:09 AM
  #121
Hfdafhx's Avatar
Pinto
2128851753
2128851853
2128852174
2128852274
HOW ARE THEY EXACTLY CONNECTED SO THAT YOU DONT GET A ERROR?
Old 12-21-2013, 09:19 AM
  #122
jerome8283's Avatar
GLS450
"I had mine installed at a local dealer in NY"
I DID NOT INSTALL THEM!
Old 12-21-2013, 09:20 AM
  #123
Hfdafhx's Avatar
Pinto
HOW DO THEY FUNCTION/WORK, DO YOU TURN ON YOUR FOGS? OR AS DRL? OR OTHER
Old 12-21-2013, 10:51 AM
  #124
Barca93's Avatar
2128851753
2128851853
2128852174
2128852274
What about going from the L shaped LED lights to the straight bar ones? Is it the same process?
Old 12-21-2013, 11:44 AM
  #125
WebOs's Avatar
E350
Dealers won't touch any of that. They said it will cost 3-4k for them to work like the new
Quick Reply: E350 2010 bumper type and LED drl cover grille question
