Remove coating on new rotors?
Old 08-29-2014, 05:18 PM
ss3964spd's Avatar
2011 E550 (RIP), 2014 CLS 550C4
Received my new OE/MB front rotors and pads.
The rotors are coated with a grey, paint like substance - presumably for corrosion protection. Does anyone know it that coating needs to be removed prior to installing the rotors (and pads)?
Thanks much,
Dan
Old 08-29-2014, 05:36 PM
Live Oak's Avatar
E550
GOOD QUESTION!
Hope you get an answer. <G>
Old 08-30-2014, 02:37 PM
J.Raymond's Avatar
'15 E400 Sedan '08 BMW 335i Coupe
Did a quick search ...
https://mbworld.org/forums/c32-amg-c...ew-rotors.html
https://mbworld.org/forums/c32-amg-c...n-coating.html
Some conflicting views. No expert - would personally be tempted to remove the coating from the friction surfaces before install.
Interesting to hear from the mechanics.
J.
Old 08-31-2014, 09:57 AM
ss3964spd's Avatar
Thanks for the search results, J, much appreciated. I, too, think it needs to be removed from the sweep area - thus preventing the pads from being loaded up with the stuff. Some fine grit sand paper ought to do the trick.
Off to the garage!
Dan
Old 08-31-2014, 12:34 PM
Quadcammer's Avatar
96 and 08 911 turbos
not necessary at all. the pads will burn it off without issue.
there will be no loading up of anything.
Old 09-02-2014, 09:55 AM
ss3964spd's Avatar
I dunno, QC, judging from how badly the sand paper got loaded up with the stuff I have to imagine the pads would too. Maybe it would burn off quickly but I wasn't willing to risk it.
Old 09-02-2014, 03:29 PM
Former Vendor of MBWorld
AutohausAZ-Mike's Avatar
That is correct.
Just install the pads and rotors and let the pads remove the coating. There is nothing that you need to do to get that coating remove, other than to just drive.
Old 09-02-2014, 03:52 PM
instantfob's Avatar
'19 MBZ E450 Wagon, '19 BMW 530e
I also let the pads rub off the coating. You'll see those rubbery flakes on the edge of new pads.
Also I like having the coating stay on the exposed area around the hub.
Old 09-02-2014, 05:15 PM
ss3964spd's Avatar
I left the coating on everywhere except the pad sweep area and the wheel mating surface of the hat.
Quick Reply: Remove coating on new rotors?
