Custom Carbon Fiber Intake Scoops on my G...
Old 11-16-2016, 06:15 PM
aerG500's Avatar
I tackled a new mod and made custom intake scoops for the side intake vents... I had always read about the TTM style scoops the E55/63 and CLS55 guys where installing (their intakes are hidden behind the grill) and wanted some. They always claimed it makes a noticeable performance difference on the highway etc.... Nobody makes them for the G so I went about it myself. First made them out of blocks of wood, then fiberglass and then carbon... Once complete (couple of week process thru lots of trial and error), I attached them using the original vent's screw point and some 3M VHB on the contact points (just with a longer stainless screw countersunk thru the scoop and to the body' existing vent mounting spot for solid strength.) Finally finished it off with a standard 1/4" black nylon plug from Ace Hardware to cover the screw head and give it a finished look. Once mounted, I was pleasantly surprised at what a difference they really do make! Who knew? The E55 guys were right! . Plus I thought they look good on my G, a subtle custom touch.... Hope you guys like the addition.
Old 11-16-2016, 06:25 PM
NYCBenz's Avatar
6x6 | 4x4
Wow, that's a cool addition!
Looks like you did a great job, too.
Old 11-16-2016, 06:28 PM
aerG500's Avatar
another pic in natural light...
Old 11-16-2016, 06:29 PM
aerG500's Avatar
Thank you! my wife thinks I'm nuts and calls the G my mistress...
Old 11-16-2016, 09:39 PM
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
That's a nice little touch, looks good!
aerG500 (11-16-2016)
Old 11-16-2016, 09:42 PM
W109 W211 6.2L's Avatar
2008 W463 G500, 2003 Terminator Cobra (710RWHP), 2012 S350 Bluetec, 2010 911 C4S, 2007 VRSCDX
Looks great, nice fab work. I wonder if it actually works? In theory it is setup correctly for more air flow.
Old 11-16-2016, 10:01 PM
aerG500's Avatar
Im guessing its probably even a more noticeable change with the G over the E for instance, since the E55/63 even stock, at least has the intakes in the front of the car and benefits from some forced flow at speed. where as the G trucks have their intakes on the sides and normally only get still air. Just a guess, but I was truly surprised at the improvement in throttle response and it seems to pull a bit better at freeway speeds going up hill etc. It's no additional turbo charger worth of power, but definitely noticeable immediately.
Old 11-16-2016, 10:06 PM
aerG500's Avatar
When making the molds, I filled the back end with resin and used a drum sander to round the inside back end to help get a more fluid air flow rather than a dead square box.
Quick Reply: Custom Carbon Fiber Intake Scoops on my G...
