Diesel #2?
Old 06-11-2014, 04:31 PM
giffie's Avatar
2011 GL 350-Lighting Pkg-P2-Parktronic-Blind spot assist-Heated everything-Running brds ,etc
Diesel #2?
I noticed that some pumps carry "Diesel #2" ..
Anyone know what is the difference between regular Diesel and "Diesel #2" ?
Is "#2" the same as fossil Diesel, and recommended for the GL-350?
Old 06-11-2014, 04:55 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
If it is marked ULSD, then it is good (or better, as it is not Bio)
If it is not marked ULSD, then it is not for your GL at all.
Old 06-11-2014, 06:42 PM
giffie's Avatar
Thanks N_Jay.. actually, even 5%-20% Bio diesel blends are also marked as USLD (at least in Illinois).
I think MB stopped selling diesels in IL, specifically because people were wrecking engines by adding 5%-20% bio diesel blends there..
Googling #2 Diesel -they say it is the same as fossil diesel, but more 'concentrated'. So, it does appear that #2 Diesel is OK for MBs
Old 06-11-2014, 06:45 PM
N_Jay's Avatar
All "road Diesel" is ULSD, both bio and non-bio.
Even the non-bio still has to be Ultra Low Sulfur Diesel (ULSD) to be OK in your MB (No farm fuel)
Bio is not marked "D2".
MB is now selling diesels ion IL.
My dealer (in IL) said he has never seen a problem with a well maintained car, but has seen a few marginally maintained cars with issues.
Old 06-14-2014, 01:51 PM
drgeeforce's Avatar
2010 GL350, 2005 BMW X5 4.8is, 2015 BMW 328d
Most stations offer fossil-derived #2 diesel or some type of blend of #1 and #2 in winter. Any diesel fuel derived from non-petroleum sources are required to be labeled as Bio-Diesel. Commonly, most diesel found in gas station pumps is #2 Diesel. #2 diesel has the highest energy content and lubricity, it runs great in warm weather. #1 Diesel Fuel has a lower energy content (about 5%) than #2 diesel and lower lubricity because the paraffin (wax) has been removed from the fuel, as this runs better in cold climates.
The newer designation is ULSD as mandated by the EPA has 15ppm maximum of sulfur to reduce emissions. http://www.epa.gov/otaq/fuels/dieselfuels/index.htm
MB has recognized that most states are moving towards biofuels. http://www.mbusa.com/vcm/MB/DigitalA..._Brochure5.pdf
Ultra Low Sulfur Diesel (ULSD) fuel meeting ASTM D975 can contain Biodiesel up to 5 % and certain states have moved over to %5 biodiesel. http://www.scribd.com/doc/96086473/Washington-Plan and here http://www.ct.gov/deep/lib/deep/air/...sel/ulsdfs.pdf
EPA has proposed a mandate to B20 for heavy trucks:
http://www.sidley.com/files/Represen...t%20III%29.pdf
Old 06-25-2014, 01:41 PM
a2j
a2j's Avatar
2008 GL320CDI (265k) & 2017 GLS450 (120k)
Diesel #2 is the one you want to be using unless its below 20F outside.
Old 06-25-2014, 02:18 PM
N_Jay's Avatar
"Highway Diesel" 2 (ULSD), not just any D2
Old 06-25-2014, 02:29 PM
a2j
a2j's Avatar
Don't remember last time I've seen a pump with a non-highway diesel, other than red diesel witch is illegal to use on the roads for any vehicle. So, I'm pretty sure OP was asking about highway diesel #2.
Old 06-25-2014, 02:50 PM
N_Jay's Avatar
Probably true, but we don't know where he is.
Better safe than sorry.
Old 06-26-2014, 01:27 PM
drgeeforce's Avatar
While traveling in Minnesota, I did happen upon "B" 2 diesel. I think it is statewide.
Old 06-26-2014, 09:04 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Different context: B2 is 2% biodiesel, D2 is the long time designation for the 'weight' of diesel fuel.
The 'D' weights are D1, D2, or D3. D1 is lighter weight, more volatile, lower pour point (aka "coal oil" or "stove oil" for a really old timer), D2 is for typical on and off road use in engines up to 500 hp. D3 is usually found in marine applications, it tends to be thick and has very high heating values and must sometimes be heated to flow properly in the fuel system. Engines using D3 are NOT designed for frequent starting and stopping. The next heavier grade of fuel oil after D3 is bunker oil for ships. It is almost as thick as tar and flows about as well.
Old 06-26-2014, 09:41 PM
N_Jay's Avatar
Originally Posted by Fourdiesel
Different context: B2 is 2%biodiesel, D2 is the long time designation for the 'weight' of diesel fuel.
The 'D' weights are D1, D2, or D3. D1 is lighter weight, more volatile, lower pour point (aka "coal oil" for a really old timer), D2 is for typical on and off road use in engines up to 500 hp. D3 is usually found in marine applications, it tends to be thick and has very high heating values and must sometimes be heated to flow properly in the fuel system. Engines using D3 are NOT designed for frequent starting and stopping. The next heavier grade of fuel oil after D3 is bunker oil for ships. It is almost as thick as tar and flows about as well.
I have never seen B2, just B5
Thinking "B" 2, may be shorthand for D2 with some Bio. (Probably B5)
EDIT:
Looks like I guessed wrong;
http://www.afdc.energy.gov/fuels/biodiesel_blends.html
There is a B2 fuel.
Quick Reply: Diesel #2?
