2001 ml320 Headlight in-line fuse?
Old 11-22-2010, 08:37 PM
HockeyPop98's Avatar
Last year, my passenger side headlamp went out. I replaced the bulb twice b4 I realized there was no problem with the bulb. Checking the fuse panel, I found the headlight fuse to be fine. I ended up believing I had a wiring problem, and took the car to a garage, where I was charged a $50 diagnostic fee to change a passenger side headlight fuse. The guy at the shop when I picked up my car claimed to have no idea where the fuse mentioned on the work order was, and I just wanted to get home, so I gave up on learning where this fuse was (should it need replacing in the future).
It's now one year later, and I have the same problem on the driver's side. The only fuse I see in the panel for headlights is fine. Can anyone help me figure this out? The auxillary fog light on that side that I can normally turn on with the low beams went out at the same time, and I'm betting they share a ground wire. Is there an in-line fuse on each side?
I'd rather not pay another $50 to have the mechanics laugh at me again!
Old 04-27-2011, 05:58 PM
Famercedes's Avatar
2005 E320 CDI, 2001 ML 320
how did you solve it? I'm having the same issue with my low beam on the driver's side?
Old 04-01-2012, 03:17 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Same problem here...
Passenger side low beam stopped working. Swapped bulbs & did not help. Opened fuse panel. The low beam fuse looks just fine. (F3 & F5 are the fuses I believe for the 2 sides).
Now I am confused...anyone?
Old 04-02-2012, 03:24 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are confused because fuses 3 & 5 are for the high beams. Fuses 34 & 35 operate the low beams.
Old 04-04-2012, 11:26 AM
mihir_d's Avatar
34 & 35 are fine too...
Driver side low beam still doesn't want to work. High beam works fine. Driver side fog lamp had taken a knock through a car wash around the same time the low beam stopped working, but the fog lamp is restored and back up.
Wondering if it has something to do with that...
Old 04-04-2012, 03:45 PM
Remove the connector to the headlight. With the headlight switch on, check for battery voltage at the pink wire and then check for ground at the tan wire with a volt meter.
If you are getting both voltage and ground then there is something wrong with one of the pins in the connector.
Attached Thumbnails 2001 ml320 Headlight in-line fuse?-2012-04-02_031845.jpg
Old 06-15-2013, 02:20 AM
Glenn Polner's Avatar
2001 Ml 320
Hi Maj.
I have same problem, right head lamp not working.
High beam works
Parker light works
Fog light works
Low beam is not working
Conducted following.
Volt tested at fuse 35 result 12 volts
Volt tested at lamp connector pink wire result 12 volts
Checked continuity of earth result perfect
Took left head lamp unit and plugged into right headlamp unit loom and everything worked.
Tested right unit with left unit globe result low beam did not work
Thanking you in advance
Kind regards
Old 06-17-2013, 06:53 AM
If you switched the bulbs and it works, then it has to be the bulb on the right side. But always replace them as pairs because the left on won't be too far behind.
Old 06-17-2013, 08:56 PM
2001 Ml 320
Yep I am a dumbass, replaced again all good
Thanks Maj
Old 10-18-2021, 08:44 PM
convicted's Avatar
1998 CLK 320
I know I'm digging up an old thread, but my high beam indicator stays on, even though I can turn on the fogs. I've noticed that I can switch from high to low if I hold the stalk just right, but the projectors seem to be the only headlights that operate.
Any ideas?
Thanks,
Old 10-20-2021, 02:35 PM
Your problem is solely with the Combination Switch and it must be replaced.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 10-21-2021, 12:45 PM
convicted's Avatar
1998 CLK 320
I was worried about that. Do I have to replace the entire assembly, or can I replace the lighting stalk alone?
Thanks again!
Old 10-22-2021, 05:28 AM
It's a one piece item. Buy new from M/B or take your pick on ebay.
https://www.ebay.com/sch/i.html?_fro...07645&_sacat=0
Old 10-23-2021, 01:00 PM
convicted's Avatar
1998 CLK 320
Thank you.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: 2001 ml320 Headlight in-line fuse?
