02 S430 Tail light problem
I have a 02 S430. I had 2 malfuction code come up:
Right tail light
Rear fog light
I replace the bulbs myself and now I have two 3 malfuction codes
Right tail light
Left tail light
Rear fog light.
Can someone give me additional direction on what to check next before I have to take my care to the stealership for something really simple?
Right tail light
Rear fog light
Right tail light
Left tail light
Rear fog light.
2005 S500 4-Matic, 1978 450SL
And did you use they type of bulb called for, or its U.S. equivalent? Your tail, parking and rear driver side fog lamps call for P 21/4W. You can find U.S. equivalents at http://www.eautoworks.com/html/bulbS...CEDES~BENZ.htm.
have exact same problem . Did u find solution?
[QUOTE=Ms.S430;4013533]I have a 02 S430. I had 2 malfuction code come up:
Right tail light
Rear fog light
Right tail light
Left tail light
Rear fog light.
Right tail light
Rear fog light
Right tail light
Left tail light
Rear fog light.
I have the same problem and the dealer said it was corroded cables not sending the correct voltage, he recommended replacing the rear tail lights 500.00 a piece I am thinking of replacing them with http://www.ebay.com/itm/192105629631...%3AMEBIDX%3AIT
I had this happen on my left tail light and decided to clean the contacts in it which fixed the issue.
