S600/S500/S430 with paddle shift steering wheel ?
Old 09-04-2016, 03:12 PM
Andrew Pempek's Avatar
2006 S65 AMG
Old 09-04-2016, 03:17 PM
2006 S65 AMG
I PM you back DrDoe. You're in Vegas or thinking of taking a trip?
Old 09-04-2016, 04:01 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
Ok. Put me down for Oct 1st. I was planning to fly down for a wedding but I might as well drive down for the DRL.
It will be on 05 S600. I will start doing some 8k LED swap to make sure you have enough time.
I won't need the whole package so let work out the details later.
Old 09-04-2016, 04:21 PM
2006 S65 AMG
Ok, so just the DRL's? I could give you my Benz to use while I work on yours too. When you have a sec, call me so I can ask a few questions too please
Old 09-08-2016, 02:18 PM
trustz's Avatar
2010 W204, 2014 W212, 2015 W222, 07 SAAB 9-3, 2016 AMG GTS
If I also get the S63 silver paddle shifter like this, can you try to replace it with stock one ? since the S63's looks a lot better :
Old 09-08-2016, 02:36 PM
2006 S65 AMG
I'm not following you here....what are you asking? If I can put the silver paddles from a S63 in a stock S600 wheel? Yes
Old 09-08-2016, 02:39 PM
  #32
2006 S65 AMG
That's also the EXACT wheel and paddles I want in my own car!
Old 09-08-2016, 04:04 PM
  #33
trustz's Avatar
The stock S65 or S55 steering wheel with paddle shifter come with one plug and two wires, but the S63 paddle shifter come with a plug with two wires on each "+" and "-" shifter like this, I don't know if you need to do any modification:
Old 09-08-2016, 08:25 PM
  #34
2006 S65 AMG
I will be able to use either style. The plugs themselves are removed in the installation process
Old 09-08-2016, 08:26 PM
  #35
2006 S65 AMG
The pictured paddles are easy, yes, no problem
Old 09-19-2016, 10:53 AM
  #36
trustz's Avatar
Here is a picture for the 05 S55 steering wheel and I just installed a pair of 63's paddle shifter:
Old 09-23-2016, 11:05 AM
  #37
trustz's Avatar
I am coming to see you tomorrow morning, please text me your address !
Old 09-26-2016, 02:10 PM
  #38
trustz's Avatar
Finally drove all the way from L.A. to Las Vegas to get the paddle shifter modification done by Andrew Pempek ! Andy is a really cool guy and the most important : he know what he is doing !! The paddle shifter control is done by a wireless transmission and receiver. I just use them like any other S55 or S65, my original console gear shifter still work like usual. I bought a used 05 S55 steering wheel with stock button paddle shifter from eBay and get a new C63 peddle shifter from dealer. I just replace the stock button paddle with new C63 paddle shifter. I can not stop to play with it when I drove back to L.A. !! If you are close the Las Vegas and want to do this modification, I am highly recommend Andy !! Andy even let me drive his S class around the town when he is working on my car !! What a cool guy to meet ! I am going to send my headlight to him soon for the headlights mod !! Thanks a lot Andy !!
Old 09-26-2016, 03:08 PM
  #39
2006 S65 AMG
Thank you for the kind words and nice review! It was a pleasure to meet you as well and have the opportunity to work on your immaculate S600! The carbon fiber front splitter had me drooling! The power of that car is just amazing and being able to command and even hold gears of your choice at will without taking your hands off the steering wheel just makes it all the more enjoyable! I look forward to a road trip in mine to LA...maybe I'll hand deliver the headlights back to you! Let me know what your carbon guy says about the handles too. If he can use any handle as a platform to carbon fiber, I would love to get yours and send you mine to use for the carbon fiber process with a check as well.
Old 01-16-2017, 10:20 PM
  #40
shooffnyc's Avatar
2001 S600 Lorinser Body Kit & W215 Front-End Conversion
Hey Andrew, is the paddle shifter doable on a 01 S600? I am not sure if there any difference between the +05 w220 models and the ones below. Wondering if you knew.
Since I'm getting some exhaust work done on mine, the paddle shifter will really be useful in my case.
Old 01-17-2017, 12:40 PM
  #41
trustz's Avatar
I believe all you need is a 2003 and up S55 or S65 steering wheel and get the aluminum paddle shifter if you don't like the stock one on S55 or S65.
Andrew's w220 is from 01 or 02 , so your 01 S600 should be ok without any problem.
The following 2 users liked this post by trustz:
Ebromercury (09-18-2021), shooffnyc (01-17-2017)
Old 01-17-2017, 01:09 PM
  #42
ItalianJoe1's Avatar
2003 CL 600
Very cool, I have a friend with an S600 who would love this.
Old 01-17-2017, 01:25 PM
  #43
shooffnyc's Avatar
Sweet! Good to know. Thanks alot!
Old 01-17-2017, 04:07 PM
  #44
tusabes's Avatar
Mercedes
Andrew can you install the paddies on a regular steering wheel without the paddles ? Same $220 price ?
Old 01-28-2017, 02:43 AM
  #45
2006 S65 AMG
Yes, ANY W220 chassis car, no problem. To be clear...2000 to 2006 models S430, S500, S600 are all capable of being retrofitted. You can buy a S55 or S65 wheel with paddles already installed, but it's also simple to modify the wheel you have now and put paddles in that one too. Buying a wheel with factory paddles will NOT be the way to get it to work....not at all. It would require refreshing the ECU and TCU and a ton of other parts too. It is not plug and play....not by a long shot. If it was, everyone would just buy a wheel and swap it. Yes, the price is to install both modules and retrofit paddles you would supply in your existing wheel. Same costs, regardless of what model....they all have the same controller system. Private message me for more info or questions....I will gladly text members photos and videos too.
The following 3 users liked this post by Andrew Pempek:
biker349 (04-23-2020), shooffnyc (01-30-2017), William Tan (03-29-2020)
Old 01-04-2020, 12:40 AM
  #46
turbonos7's Avatar
'05 S430, '05 S600
Hello all and Happy New Year! Is this service still available or am I too late?
The following 2 users liked this post by turbonos7:
Rokassw (08-15-2021), William Tan (03-30-2020)
Old 03-30-2020, 08:19 AM
  #47
William Tan's Avatar
w220
Hi, mind to drop me an email to how to manage those wiring?
williamta86@gmail.com
Old 07-26-2020, 01:20 PM
  #48
Silvi Smakaj's Avatar
2002 s500 and 2000 c280
Does this guy andrew has any contact info
he still doing the paddle shift retrofit?
Old 07-26-2020, 06:45 PM
  #49
tusabes's Avatar
Mercedes
did you try Andrew phone number from post 18
708-691-3672
Old 08-14-2021, 01:33 PM
  #50
Rokassw's Avatar
Mercedes Benz S500 W220
Can you text me on Facebook (Rokas Yzf) for help ? I'm from Lithuania so i can't bring it to you..
I recently figured out how to command up and downshift control via a wireless 2 channel receiver that talks to the optic switch assembly inside the shifter of my W220. It receives signals sent from two paddles I installed in the factory steering wheel that are connected to a 2 channel transmitter behind the airbag module. As best I can tell, I am the first one to ever do this on a 220 chassis, as doing so was a challenge because the + and - detents do not activate a contact switch, but rather an optic beam is used! I can't find photos or even discussion anywhere of anyone else having done paddles on these. Instant shifts with no delay either. I'm in Las Vegas if you need help with your own car, just say the word!
Quick Reply: S600/S500/S430 with paddle shift steering wheel ?
