Stall speed of converter?
Old 08-04-2016, 11:39 AM
VinnyT's Avatar
2006 S65
I notice when I take off from a dead stop, it seems to struggle until the engine revs to a certain RPM. I was told that these cars have a high stall speed because of the torque it produces. I guess this a nuance we have to live with?
Old 08-05-2016, 07:11 PM
Welwynnick's Avatar
2006 S600
Perverse, isn't it? These are the torquiest car engines of all, but that's wasted on loose torque converters that need lots of revs just to set off.
I needed 2000 rpm just to do hill start today.
It seems to be normal.
Nick
Old 08-05-2016, 07:47 PM
ItalianJoe1's Avatar
2003 CL 600
Are you in C mode or S? C starts the car in 2nd gear, which makes it feel like the trans is slipping. I drive around in S mode all the time just for that. I hate the starts in 2nd gear.
Old 08-08-2016, 09:27 AM
VinnyT's Avatar
2006 S65
I'm always S mode. Still sluggish as hell. It does seem better once everything warms up.
That is my only complaint about the car. I love freeway ramps!
Old 08-08-2016, 05:40 PM
2003 CL 600
Shouldn't feel like that. Yes it's a heavy car and yes the pedal is ramped very slowly, but my car will pull smoothly from low rpms if throttled.
Recent trans service? If the fluid is getting dodgy it might not be helping the situation.
Old 08-08-2016, 05:53 PM
Quadrobenz's Avatar
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
There could be something wrong. My 2006 S65 would launch hard and quickly with just a small amount of throttle. I got a lot of complaints from passengers on the neck snapping starts. No way it felt sluggish from a stop. By the way, the flash stall of the torque converter seems to be between 2,000 and 2,200 RPM.
Old 08-10-2016, 08:27 AM
VinnyT's Avatar
2006 S65
I have a feeling it could be me. My last few cars were not a drive-by-wire. The bottom of the accelerator pedal was not affixed like this one is. I was always pressing on the bottom of the pedal with my other vehicles. I think I may be doing the same with this car. I'll try a new foot position when I get off from work.
Old 08-10-2016, 06:22 PM
2003 CL 600
Yeah I've compared my CL to many other cars and the throttle tuning is very linear, almost to a fault. It takes a fairly large pedal opening to get the engine to actually open the throttle a lot. Most newer cars are the opposite, to provide a more "sporty" response.
If you change your normal driving habits and apply what seems like too much throttle from the start, the car moves off like a normal car. It makes the car "drive heavy" as my wife would say, I assume it was done for a more luxurious and less neck snapping take off.
Old 08-11-2016, 08:27 AM
VinnyT's Avatar
2006 S65
I agree.
I changed my foot position and it is a whole new car. Yeah, sounds stupid but I was so used to just tapping the bottom of the pedal with my previous cars to accelerate. Can't do that with these as the pedal is affixed to the floor. So, keeping my heal on the pedal pivot point and using my whole foot on the pedal, it is night and day.
Old 08-12-2016, 06:33 PM
Welwynnick's Avatar
2006 S600
Throttle progression (load vs pedal position) is one thing, but TQ characteristics (load vs revs) are another.
I'm happy with ramped throttle opening, using a significant amount of travel just to set off normally from rest.
However, it seems like 2000rpm is needed to do that. That's max torque revs, which is a terrible waste.
Am I missing something? For years I felt like my torque convertor was only half full of oil or something like that, or that the stator clutch was broken and I wasn't getting any torque multiplication.
Seems it is normal though, apart from comments like Quadrobenz's. I don't know what the stall speed on my cars is, but it feels like it's 3000 rather than 2000rpm.
Perhaps I should use older, more viscous ATF like MB 236.12 / ATF 3353 ?
Nick
Old 08-12-2016, 07:27 PM
Quadrobenz's Avatar
Nick, I certainly agree with you first statement. Your second point is what I am experiencing with the new W222. But there is a difference between just needing more throttle movement and what the pre-tuned W220 felt like. That was more like a car with excessively retarded ignition timing. The tuner mod does add more part throttle ignition timing. All the stock V12TT's I have driven take more RPM's to get moving than the V8 counterparts, but the V8's I drove all had 7spd transmissions, not 5spd's.
The Flash stall is hard to read on a car as fast as the S65 but mine was nowhere near 3k on any of the three V12TT's with a 5spd we had. The old R129 SL600 with the NA V12 had a flash stall of 1700, it was a noticeably tighter torque converter.
Old 04-09-2017, 08:39 PM
cmpcpro's Avatar
1956 Oldsmobile 98 Holiday, 2006 AMG S55, 2016 Toyota Camry Hybrid XLE
I know my S55 will snap your head back at a stop when trying to go slow. I had to learn how to really feather the throttle because it would pull hard at a light barely getting on it.
Old 04-14-2017, 05:17 PM
auburn2's Avatar
S-65 AMG
Stall speed in a torque converter is really a misnomer, it is only accurate at a specific engine torque. For example if you have a 2000 RPM stall behind a 300lb ft torque engine, that same torque converter is going to have a much higher stall speed behind a 700 lb-ft torque engine.
That said I believe the 722.6 transmissions all use a PWM lock-up circuit which means the stall is not constant but rather varied by the TCM on the fly.
Old 04-15-2017, 12:52 AM
2003 CL 600
Stall speed is inherent in the mechanical build of the torque converter, not electronic. The clutch is used to remove all slip once you're rolling for max efficiency, but the design of the turbine and stator internally affects how much torque will spin it up, as you said a given stall is only accurate at a given torque production, but on a stock engine the stall speed should be very consistent from one car to another. The TCC isn't doing anything with the vehicle at low speeds, or at all in 1st gear I believe.
Quick Reply: Stall speed of converter?
