E55 with Speedshift, Paddles, M Mode and other Mods
Old 02-02-2017, 08:01 PM
  #526
AMG_55_cruiser's Avatar
2004 CL55, 2003 SL55 and 2009 G55
[QUOTE=kaype;6240721]Several Updates...
I threw out the SL55 722.643 Transmission and installed a SL65 722.649 instead. Shifting is nicer in some kind i cant really explain
722.649 Electrohydraulic Unit
torqueconverter from the 649
torqueconverter from the 643
What are the internal differences and external differences between .643 and .649? Or is it just the board? Can you retro fit between the 2 or just easier to swap out trans? Any other work required that you can think of to swap out in w215 CL55 kompressor?
Mick
Old 02-02-2017, 08:10 PM
  #527
Originally Posted by cm60k
Always Welcome Fabian..,
you are good photographer MaaaaaN...
ZAYED,,
Zayed - do the heat spacers make a big difference? Do you offer them for sale?
Thank you,
Mick
Old 02-02-2017, 08:30 PM
  #528
Originally Posted by kaype
a few updates...
last month i started the upgrade of my S/C IC System.
I threw out the small W220 S55 Cooler and replaced it with one from a C32, after that i installed a 2nd CWA50 Pump and a additional cooler from a S400CDI. So now i got 2 Pumps, 3 Intercoolers and WAY cooler IAT!
Here you go:
Old vs New
... to be continued ...
can pump be upgrade to the CWA100 without any other mods? Do you happen to know part# on the C32 HE as I would love to use this on my CL55k instead of aftermarket. Thanks Mick
Old 02-02-2017, 08:39 PM
  #529
Depends on the modelyear.
the chargers ending with part number 0580 and 0080 are nearly 5% faster then the ones with 0280 number.
greetings, Fabian
I wonder what the SC off the SLR is making?
Old 02-03-2017, 03:12 AM
  #530
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
Originally Posted by AMG_55_cruiser
Fabian,
Are your 390 rotors from Black series or aftermarket? Notice big different between 360 and 390's?
Mick
R230 SL65 Black Series Rotors on the CLK63 Rotorhats. No chance to fit thme otherwise. But for a W215 the Original Setup used on the S65 should do the trick if you want to upgrade ;-)
Hope they never let that one go...
You can be sure ... they never will unless i take the car :-D
Would love my inner headlights to look that bright...what bulbs are you using? Been wanting to do pre-facelift lens on my 2004 W215 Cl55
I use LEDs
Is the W220 S55 BB/BC the same as the W215 CL55 kompressor?
Thanks,
Mick
Yes.
Mick
The Transmission is different, larger bearings, larger clutches, larger torque converter ... its almost 3cm longer.
You cant fit an SLR Charger plug n play ... it wont fit. As far as i knew the turbine of the SLR Charger is teflon coated and it has lower tolerances in the production but the gears are the same ... but i am not sure 100%.
yes.
Dude, you really need to learn how to quote ;-)
greetings, Fabian
Old 02-03-2017, 03:33 PM
  #531
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Thank you,
Mick
Hey Mike,
Yeah, phenolic spacers are soo cool, they really insulate the heat range from intake manifold..!,
my friend got some of them in his shop here,,
i can ask him if you interested..!!
-;ZAYED;-
Old 03-28-2017, 10:40 AM
  #532
2001e55wagon's Avatar
2001 W210 E55 & 1998 Lexus LS400
A question for Fabian
Hi Fabian,
I have a question about the first video you posted of your wagon with the 722.643 tranny. I have a 2001 e55 wagon VIN WDB2102741B142933, I have had it for a year now (its a Japanese import) and it initially came in with a defective tranny which wouldn't shift beyond 2nd gear, I had it repaired.
In your video while manual shifting I see it reflecting 5 in the transmission display on the dash but mine only goes from 1, 2, 3, 4 & D. Is something wrong with mine or is yours that way cause of the tranny change.
Rgds,
Al.
Old 03-28-2017, 10:52 AM
  #533
kaype's Avatar
Hey Al,
yours i original, you dont have M Mode, so you cant have a "5" in the Cluster Display. So dont worry, everything is fine :-)
greetings, Fabian
Old 03-28-2017, 11:35 AM
  #534
Hey Al,
greetings, Fabian
Thanks, what is M mode, the transmission does shift when I move the shifter left or right, I also cannot get the digital speedo to display.
What parts did u change to get M mode, just the tranny and TCU ?, and what is an EGS. This is my 3rd w210, I had a 1997 e320 with the straight 6 and a 1998 e320 with a V6.
Thanks for your help,
Al.
Old 03-28-2017, 12:53 PM
  #535
kaype's Avatar
W210 has no M-Mode. That what you think is only the normal shifting any Mercedes has.
I have a SL65 Transmission and CLK-DTM TCU Software. EGS = TCU
EGS = Elektronische Getriebe Steuerung
TCU = Transmission Control Unit
greetings, Fabian
Old 04-16-2017, 07:40 PM
  #536
rallycar's Avatar
e55
greetings, Fabian
if if I wanted to do a slightly budget build accessorywise on trans, what paddle shifters, tcu tune etc would you recommend. Remember it's a stock 2002 in great shape! Just want paddles but a little performance helps as long as install isn't crazy and looks oem'ish
Old 04-18-2017, 04:17 AM
  #537
kaype's Avatar
Keep it OEM. Paddles without M-Mode are useless, M-Mode without transmission change is not possible ... so, keep it as it is :-)
Old 04-18-2017, 10:21 PM
  #538
rallycar's Avatar
e55
i hear ya, I mostly wanted gear paddle shifters, just so I could keep hands on the wheel and change vs the gear lever.
Old 04-19-2017, 03:07 AM
  #539
kaype's Avatar
that is what i say, you dont shift gears over the lever, you just limit the top gear the transmission is shifting in. if your transmission is in 2nd gear and you push minus your gear is limited to the 4th gear ... the transmission dont shifts in 1st gear!
So paddles with OEM transmission and TCU is useless. If you want paddles and use them like they are supposed to be used you also need to change your transmission to a W211 E55 Transmission and also to a modified TCU Software that supports the old W210 electronics (switch instead of button to change driving programm) with modified Diff ratio (2.82 instead of 2.65!)
Otherwise paddles make no sense.
greetings, Fabian
Old 04-20-2017, 06:45 AM
  #540
rallycar's Avatar
e55
greetings, Fabian
thanks for the thorough explanation. Will stay stock happy for this piece :-p
Old 07-30-2017, 08:34 AM
  #541
Jonas Blomfeldt's Avatar
3 W210 E55 98,00,01 and 300ce- 90
greetings, Fabian
Do you use a TCU from a w211 E55?
Old 07-30-2017, 01:09 PM
  #542
kaype's Avatar
As i wrote, CLK-DTM TCU. But i used W211 E55 TCUs as well, original with 2.65 ratio and modified to 2.82 ratio ... both worked but it needs to have an old version on the TCU on it, otherwise you cant change the drivingprogramm as the w211 has s button for S/C/M and the w210 only has a switch to switch between S and W.
Old 07-30-2017, 02:40 PM
  #543
Ok good to know. i rebuild my tranny but like you say it's bit slow must be fantastic with a speed shift
Old 10-22-2017, 11:31 AM
  #544
6spd's Avatar
00 ML55, 00' E55, 03' CLK55
Good point Fabian, but my friend has W202 C55 with tiptronic with ME2.0 and EGS52, and its working perfectly,
i put his EGS52 in my non tiptronic C43, its fire-up, and gear is shifting 1>>2 only, cause his EGS52 programmed with 2.82 diff...
ZAYED,,
Does he still own the c55 with egs52? I'd be willing to pay you guys to make a copy of the TCU for my car. I could mail an egs52 out!
I've been working on this for years. W210. 55 me2.0. Bought 3.06 diff from c32.
Bought new blank egs51 TCU but need a 2000 c43 owner with tiptronic to make a copy of their tcu as both cars use 021-545-8832.
But if I got the c55 coding from his egs52 the this would be the answers to my prayers lol. I would have 2.82 ratio but egs52 is easy enough to change ratio. What part number is the EGS?
Old 10-22-2017, 01:06 PM
  #545
kaype's Avatar
afaik EGS52 wont work with ME2.0. I dont think that is what you are praying for? :-)
i tried it in a '99 E44 4matic (probably this is exactly the TCU you want ... W210 E55 with 3.06) and it wont work. I dont know what TCU/ECU Combination Zayeds friend used...
Old 10-22-2017, 03:10 PM
  #546
6spd's Avatar
No worries. I thought that particular C55 came from the factory with egs52? That's how I read it anyway. I was hoping it was factory and what combination of TCU coding. Because that means me2.0 people may have hope!
Old 10-22-2017, 06:54 PM
  #547
kaype's Avatar
i wont believe that until i´ve seen this work ... as i tried it for myself -> EGS52 with ME2.0 is KNEW that it will not work, the ME2.0 even does not recognize the EGS52 at all... i wish i could install a EGS52 in our W210 E55 4matic Station :-(
#021 Partnumber is not a EGS52!
Old 11-09-2017, 10:06 PM
  #548
Former Vendor of MBWorld
ecmexchange's Avatar
na
Looking good, glad you got it rocked out.
Old 04-22-2018, 05:53 PM
  #549
LimitedHansen's Avatar
W210 E200 Kompressor
Been sitting here for 4 hours reading this thread, watching all videos and pictures, astonishing and some mind blowing modifications to this Station wagon. Absolutely Insane.
Old 04-22-2018, 05:54 PM
  #550
kaype's Avatar
thanks mate :-)
Quick Reply: E55 with Speedshift, Paddles, M Mode and other Mods
