E55 with Speedshift, Paddles, M Mode and other Mods
Old 06-27-2014, 12:29 PM
  #276
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Excellent Fabian,
what's the Bosch # of those SLR's, we can surely know the Exact cc..
ZAYED,,
Old 06-28-2014, 06:37 AM
  #277
kaype's Avatar
W109 300SEL6.3, W123 280TE, W123 200T, W210 E55
#0280156148 is the Number
How much cc they do ... i dont know. I tried to get information directly from Bosch but they wont give me any because it is a restricted part, no information, no selling ... nothing.
As far as i knew they make 482ml/min ... the original ones make 443ml/min ... so aprox. 10% more.
greetings, Fabian
Old 06-28-2014, 07:19 AM
  #278
cm60k's Avatar
Bosch #: "0280 156 148"
41.6 lb/hr = 437.2cc
ZAYED,,
Old 07-13-2014, 12:31 AM
  #279
Jersey Phil's Avatar
ML320
Very nice write up on your build. I dropped a m113k engine into my 99 ML320. Its still a work in progress and am running the ME 2.8.1 wiring to the vehicle. I have a quick question on your start signal. How did you overcome that, being that you came from ME 2.0 with DAS2 where the starter signal goes to the ME via analog and the ME 2.8.1 requires a digital signal from the CAN? My workaround will be the analog signal to a separate relay to the starter. I will lose the tip start function though.
I like what you did with the radiator fan. How stable is the temp with the fan without shroud? I like you, lost space and only have about 2 inches between radiator and s/c pulley. I am removing my radiator support and moving the radiator forward more and will be losing the 2 extra aux fans the older w163's come with. The extra room will allow me to fit the later model w163 cooling fan.
Don't mean to steal your thread, I have been following it and am now at a point of my build where I have a few questions.
Phil
Old 07-13-2014, 07:45 AM
  #280
kaype's Avatar
W210 as of 1999 allways had FBS3 Keylock system, the Starter Signal allways was via CAN over the SAM. The Starterwire is connected to the SAM and from the SAM to the ME. I had no problem with the starter as i switched from ME2.0 to 2.8 and then to 2.8.1. Also my Automatic Start works absolutly fine...
I´ll never came over 95°C with my fan setup, while testdriving i also hat a traffic jam and stand for around 30 Minutes on the highway at 27°C Temepratur, Sun shining and Car running with A/C. No Problems so far. I would not drive to the sahara with this setup but for europe it is absolutly fine
between my Pulley and the Fan is around 2cm space, thats enough ... the pulley never touched the fan motor so far.
greetings, Fabian
Old 07-13-2014, 11:01 AM
  #281
Fabio D's Avatar
210 55
Phil
You start any new thread in the ML forum? love to see your project / pics man! i'm planing to do the same with my ml320 sport 2002 but i'm planning to use the C32 kompressor engine
Fabio Daniel
AMG_55_cruiser (02-02-2017)
Old 07-31-2014, 04:52 AM
  #282
kaype's Avatar
Old 07-31-2014, 05:34 AM
  #283
cm60k's Avatar
Hey Fabian, you killing me MaaaaaaaaaaN....
WaaaaaaaaaaaaaaaaaaaaW...>>>>>
ZAYED,,
Old 07-31-2014, 11:28 AM
  #284
4515's Avatar
W210 E200 Kompressor Wagon , FORD Mustang Coupe 1965
Old 08-22-2014, 03:28 AM
  #285
kaype's Avatar
so far so good ...
a little bit smaller s/c pulley will be coming soon, about 4mm smaller then the original. hopefully i will hit the 600hp then
greetings, Fabian
Old 08-23-2014, 04:50 AM
  #286
4515's Avatar
Old 09-04-2014, 04:35 AM
  #287
kaype's Avatar
Today i installed 3 new idlers bought from shardul
Nice work and a looooott cheaper then the original plastic idlers from Mercedes!
greetings, Fabian
Attached Thumbnails E55 with Speedshift, Paddles, M Mode and other Mods-foto-1.jpg   E55 with Speedshift, Paddles, M Mode and other Mods-foto-2.jpg   E55 with Speedshift, Paddles, M Mode and other Mods-foto-3.jpg   E55 with Speedshift, Paddles, M Mode and other Mods-foto-4.jpg   E55 with Speedshift, Paddles, M Mode and other Mods-foto-5.jpg
Old 09-04-2014, 07:40 AM
  #288
e55phil's Avatar
2021 e All Terrain, 2001 e55
What an amazing automobile!
Old 09-04-2014, 08:12 AM
  #289
cm60k's Avatar
+1,
Good job & Excellent choice Fabian..
ZAYED,,
Old 09-04-2014, 12:12 PM
  #290
1986CJ7's Avatar
'99 E320 Wagon
I'm still green with envy and my wagon keeps budging me all day towards an overhaul like this. I'm just hunting for the donor.
Old 09-04-2014, 03:09 PM
  #291
Pagz's Avatar
C43 w/clk55 Organs
Very impressive Fabian!!
Old 09-05-2014, 04:34 PM
  #292
Quant's Avatar
2002 CLK55
can I get trans on my w208 amg to shift like slr/dtm as well? I'm thinking of getting blue solenoids(4?), slr/dtm tcu flash, along with changing rear diff to 3.07/3.06 to match new flash. is this enough or need to do more?
Old 09-05-2014, 07:21 PM
  #293
benzokirk's Avatar
'08 E63 AMG
Old 09-06-2014, 08:26 AM
  #294
kaype's Avatar
only if you have ME2.8 ECU in your car, with ME2.0 you cant use EGS52 TCU´s ... depends on what modelyear your CLK ist, ME2.8 is used from Modelyear 2001.
greetings, Fabian
Old 09-07-2014, 10:19 PM
  #295
Quant's Avatar
2002 CLK55
thanks Fabian, appreciate response! I have 2002 clk55, this should hopefully be able to work.
are blue solenoids the only hardware that needs to be changed to match dtm/slr trans? on software side, can I set my S to slr/dtm sport mode and W to most aggressive/race manual mode? How about rev limiter? will that change?
Old 09-08-2014, 09:29 AM
  #296
kaype's Avatar
hi...
In my case S is Standard and W ist M-Mode. CLK-DTM only has this 2 options and they are NOT switch via CAN bus, they are switched via 12V potential on 2 inputs of the EGS!
If you want to use the same software like me you´ll will have a serious problem with your rev limiter, the 55 N/A Engine only revs to 6300rpm, the CLK-DTM shifts at 7000rpm at kick down. Dont know if there is any solution to this.
The Solenoids are the only difference ... but only if you have a 722.643 Transmission, speedshift with 722.636 isnt possible.
greetings, Fabian
Old 09-08-2014, 03:28 PM
  #297
Quant's Avatar
2002 CLK55
hmm I see, I guess even though my car is amg since it was earlier ones it came with only "touch shift" and not speedshift?
Old 09-08-2014, 03:31 PM
  #298
benzokirk's Avatar
'08 E63 AMG
https://mbworld.org/forums/c-class-w...peedshift.html
Old 09-08-2014, 05:06 PM
  #299
kaype's Avatar
i dont know "touchshift" but speedshift wasent present in w208/w210 models. it came with the W203 / W211 / W220 / W215 Models ... all the Engines with Superchargers where the first ones with speedshift. the transmission of the speedshift is different, it is not only software related.
greetings, fabian
Old 09-10-2014, 07:26 PM
  #300
Quant's Avatar
2002 CLK55
that's disappointing but at least now I know it can shift faster with some work. I need to do more research but it looks like diff between 722.636 amg trans and newer ones are torque converter, Tcu software upgrade, and maybe valve body. Anyone have more info on this? Maybe speedshift is possible with these?
Quick Reply: E55 with Speedshift, Paddles, M Mode and other Mods
