Intercooler Pump you didn't know about
Rating: Thread Rating: 4 votes, 5.00 average.
Old 05-14-2012, 01:27 PM
  #76
04chase's Avatar
2006 E55 AMG
Does anyone have a mb part # for the -10 Bosch
Old 12-27-2012, 05:24 PM
  #77
RNSL65's Avatar
SL65 AMG, X5-4.8i M-Sport, 530D, 528i
@MBH motorsports
So how did you eventually wire it up to connect to the cars wire/electronics?
Rolf
Old 12-31-2012, 11:56 AM
  #78
Blown_V8s's Avatar
C5 LS6 and CLS55
Originally Posted by shardul
Meziere WP136s has been tested and tried. Flows at 20 gpm work very will with a larger heat exchanger and cost is 199.
So many pumps to choose from.............
I've read good things about the Meziere and Bosch 010...
Old 12-31-2012, 11:57 AM
  #79
99lightning's Avatar
99 ford lightning
keep it simple.
Old 01-02-2013, 05:14 PM
  #80
RNSL65's Avatar
How did you end up connecting the wires, as the pump seems to be a PWM type motor?
Thanks.
Rolf
Old 01-03-2013, 05:22 PM
  #81
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Originally Posted by MBH motorsports
Wired it up and that was it. Works great to this day.
Very interesting, that SLS pump sure pulls a lot of Amps @ 13.5
Did your "wire up" use the voltage from the ECU or did you install a standalone circuit for the pump?
I recall the draw of the OEM pump @ 4 amps, and Meziere @ 6 amps
Old 01-04-2013, 10:16 AM
  #82
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Still nice to see more pump options but I have run the Mez WP 136 on stock system, stock with H/E and now being feed with 2000 GPH rule pump and trunk tank. I have tested Johnson pumps (yuck) stock and bosch HD and none come close to what the Mez can flow.
Can you flow to much on stock system? Not with any of the pumps that are listed above , as rated flow with Zero head pressure is waaaaaay different than real time flow. Even with all these big pumps, you wopuld be lucky to measure real time flow of over 6GPM. That gives your stock system about "one circulation" of water on a 1/4 mile run. That is still low IMO and most of you will only be seeing 2-3 GPM real time with your set ups that I see posted. So, I would not worry about to much flow and start working on getting more flow. I spent a lot of hours with a stop watch, gallon jug and testing flow of each set up and hose diameter size. That the only way to really know.
Mez pump specs.
http://www.meziere.com/ps-892-860-wp136s.aspx
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 01-13-2013, 02:55 PM
  #83
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Hi, what do you think about the EWP 80 Water Pump?
https://mbworld.org/forums/cl55-amg-...erms-flow.html
Old 04-09-2013, 04:29 PM
  #84
rockthemullet's Avatar
2005 Mercedes E55 AMG
I'm a new w211 owner and I was researching intercooler upgrades when I came across this thread. I'm an engineer and I actually work for Pierburg Pump Technology... so if any of you have any more in depth questions about our products, just give me a shout and I'll see what I can rustle up.
Dale Andersen (11-06-2019)
Old 04-09-2013, 04:44 PM
  #85
Toadster's Avatar
2005 E55 AMG
why not killer chiller at a little more? who cares what ambient temps are then
Old 04-09-2013, 05:17 PM
  #86
TheOtherDodge's Avatar
2005 E55 AMG
I didn't read all the posts, but is there a concern that for use with someone that has the stock location HE and stock sized HE (and even possibly a bigger HE) that it will flow too fast through the cores not allow enough time for the fluid to cool?
Old 04-21-2013, 08:49 AM
  #87
Welwynnick's Avatar
2006 S600
How the Pierburg pumps compare with others by pressure and flow
Hi All, I've been getting interested in uprated IC pumps for my V12TT, and I've written a lonely mini-blog in the M275 V12 Bi-Turbo Platform forum for a while. I've been scooping up all the information I can find out about pumps, and put it in one place where each pump can be compared on a comparable basis. I've just added the Pierburg pumps to that comparison, and I thought anyone reading this thread might be interested - well, more than the M275 regulars, at any rate. This is what I just wrote over there:
https://mbworld.org/forums/m275-v12-...ion-pumps.html
These are probably best know as "The BMW pump", but its actually a range of pumps for different applications. They range from the 15W WCP circulation pump (for heating and cooling when the engine is off) to a 1100W monster to replace the biggest mechanical pumps. An electric pump is still a bit of a novelty, but following BMW's lead, I think they're likely to become commonplace. There are probably four of interest:
CWA 50 . Circulation pump, 50W , 6000 rpm, 24 lpm @ 0.60 bar
CWA 100 Circulation pump, 100W, 7200 rpm, 30 lpm @ 0.85 bar
CWA 200 Coolant pump, 200W, 4500 rpm, 120 lpm @ 0.45 bar
CWA 400 Coolant pump, 400W, 10000 rpm, 150 lpm @ 0.80 bar
The CWA 50 is used as a charge cooler pump on the recent BMW V8TT engine, and the CWA 200 is used as the coolant pump on a wide range of recent BM's. The circulation pumps have relatively low flow and high pressure, while the coolant pumps are obviously high flow. Like all good pumps, they're specified by their flow rate under pressure, so we know what their installed performance is going to be. Contrast that with the Meziere WP136S, which simply claims 20 gpm/76 lpm open pipe. I don't have much information about how the WP136 performs in an IC system, so I used what I could find. Like the Meziere, the big Johnson and Davies Craig pumps also claim high open pipe flow, but when I put the Pierburgs onto my Flow Characteristics chart, an interesting picture emerges.
For the purposes of charge cooling, these pumps rock. If you look at the Charge Cooler Resistance curve, which gives an indication of the pressure/flow characteristics for a typically constricted charge cooler system, you can see which pumps will give good installed performance. The CWA 50 beats all-comers so far, and the 100 is better still, even achieving one bar pressure differential at low flow rates. For charge cooler systems, these are two meaty pumps. I believe the CWA 100 is what Renntech use for their new IC pump, and it seems to be exactly what's needed. Shame about the silly price.
The CWA 200 & 400 coolant pumps are off the chart, flowing over 100 lpm, and I didn't even try to plot them. They're huge, but you can see they meet different requirements. Where the 50 & 100 (like the Bosch pumps) fit the Charge Cooler Resistance curve pretty well, the 200 & 400 are closer to the Engine Resistance characteristic. In fact, the Pierburg stats tend to back up what I've supposed are the installed characteristics for IC and engine cooling, with a big difference in the pressure/flow curves. If anything, I think the differences should be even greater, with an even steeper IC curve and a shallow coolant curve.
The other thing that's interesting about the Pierburg pumps is that they facilitate electronic variable speed control. They can be slowed down almost to a stop, for fast warm-up and to save electrical power. In theory, they can control water flow well enough to avoid the need for a thermostat. That might not avoid hot spots in the engine during warm-up, so I don't believe anybody has actually implemented that yet, but it sounds ideal for a charge cooler.
There's lots of interesting discussion, brochures and information about the Pierburg pumps here:
http://north.america.kspg-ag.com/index.php?fid=2195&lang=2
http://www.pierburgspa.it/pdfdoc/kspg_produktbroschueren/2007/pb04_elec_coolant_pump.pdf
http://www.kspg.com/fileadmin/media/Broschueren/Poduktbroschueren/Pierburg_Pump_Technology/Wasserumwaelz-_und_Kuehlmittelpumpen/ppt_elek_kuehlmittelp_e.pdf
https://mbworld.org/forums/w211-amg/411058-intercooler-pump-you-didnt-know-about.html
https://mbworld.org/forums/w211-amg/408651-renntech-ic-pump-vs-bmw-pump.html
https://picasaweb.google.com/renntechmercedes/RENNtechIntercoolerPumpVsBMWPumpData?authuser=0&au thkey=Gv1sRgCPDr6e2ogLq-Tg&feat=embedwebsite#5631550086765057074
And here's my updated spreadsheet - note that the scales have been expanded since last time, and I've added imperial flow and pressure scales. I've been meaning to do that for weeks; its frustrating when manufactuers quote specs in so many different units; its difficult to make fair comparisons otherwise, so here they are.
Intercooler Pump you didn't know about-pumpcharacteristics130421-page-2_zps9500e15f.jpg
Nick
NH_E63 (08-09-2022)
Old 04-21-2013, 09:44 AM
  #88
superstar's Avatar
03 R230 SL55 / 94 W124 E500
Great work! Thanks for the up.
Old 04-21-2013, 10:57 AM
  #89
Crissus's Avatar
So, if this: https://mbworld.org/forums/w211-amg/...-vs-wp136.html
is true, we have a very low resistance in our system???
Do i get that right?
Old 04-21-2013, 02:43 PM
  #90
Welwynnick's Avatar
2006 S600
I've been thinking about that thread for some time. There are lots of variables, and its difficult to know how equal the comparison is. I don't know so much about the W211 intercooler, but doesn't it run off the engine coolant? Did this particular car have a split cooling system? What's the pump control algorithm? Was the pump actually running at the same time in each test? Was the system bled correctly every time the pump was changed, or was there air in the system sometimes?
It could be that the WP136 just isn't very good as an IC pump. I believe Meziere make engine coolant pumps, and maybe its only Bosch and Pierburg that make proper IC pumps, that can generate the pressure needed for IC systems. My view is that the charge cooler is a high resistance system, largely because the heat exchanger is long, thin and narrow - all the things that increase circulation resistance.
The other approach is that IC coolant circulation is not the bottle-neck in the overall system, as the heat-moving capacity of the coolant is greater than the heat exchangers. I've been doing some more sums on that today. Therefore uprated pumps might not make that much difference at all.
I think your idea was that an over-powered circulation pump might be heating up the coolant itself, but I don't think that's an explanation. Even the best are only putting 10 - 20W of hydraulic power into the system. Granted, that energy has to go somewhere as heat, but its not a great deal of energy - certainly not when there's a big heat exchanger in the circuit, as there is here.
Hydraulic power is easy to work out - its pressure in kPa times flow in litres/sec. When you look at current draw, these pumps are only 20 - 30% efficient, so cooling the pump itself may be more of a factor. None of this puts me off using a bigger pump to increase IC performance, but I think there are potentially more benefits from the HE and the pump control algorith.
regards, Nick
Old 05-05-2013, 11:02 AM
  #91
Welwynnick's Avatar
2006 S600
I think that many charge-cooled turbo cars use continuous-running circulation pumps - Lotus Carlton, Jaguar XJR & XKR etc, and the force-fed Mercs seem to me to be at a disadvantage with their temp-controlled pumps. When looking for other pump options, like many others I found the Davies Craig pumps, especailly the EWP 80 and 115. What was particularly interesting about Davies Craig was the pump controller. This implemented thermostatic control not only of the big DC water pumps, but any EWP in principle, and allowed you to modulate the pump output and adjust the target temperature in a fairly crude way.
The BMW circulation and cooling pumps discussed here are more effective and controlable, but the only way to control them is with a BMW ECU. That is (as they say on Top Gear) until now.... Last year a small German company called Tecomotive developed an electric pump controller (the tinyCWA) specifically for the Pierburg circulation and cooling pumps used by BMW: the CWA 50, 100, 200 & 400. With a suitable temperature sender, this enables thermostatic control of the BMW pumps, so that any car can benefit from the lower power loss and flexible location. Like the Davies Craig controller, you can adjust the target coolant temperature, but it has much more flexible controls. Here is the web page and here is the users manual. The pump can set to run continuously at variable speeds, it can be run manually, and the controller can display the coolant temp or the pump speed. This seems to be intended for engine cooling, but I believe it can be used with the 50W and 100W circulation pumps as well.
Engine speed independent cooling
Integrated cooling fan controller
No more overheating at engine idle
No thermostat necessary
Quick and predictive control algorithm
Delayed shutdown
An automotive controller for Pierburg’s (BMW) electric water pumps CWA200
The Tecomotive “tinyCWA” is able to control the CWA200 electric water pump (eWP) in the appropriate manner.
It is suitable for cars or any other thing where smart cooling is required.
When activated the controller is measuring the current coolant temperature and the rate of increase with the connected temperature sensor.
With this data it then calculates the appropriate water flow and sends a signal to the pump where the internal pump electronics then set it to the right speed.
This way you will always have the right pump speed for any circumstances.
We developed this product with very special attention to quality, operational safety, ease of use and a very nice appearance.
The compact and anodized aluminum case measures only 51x51x13mm. (2x2x1/2inches)
You can find more precise information about the operation, installation and use in the manual
Features:
  • Simple to set up with only one rotary switch
  • Choose your favorite target temperature in six steps from 75°C to 100°C (167°F to 212°F)
  • LED display shows the current pump speed or rough coolant temperature
  • Compact and robust anodized aluminum case
  • Relay output for the radiator fan (recommend to use)
  • Delayed shutdown of the pump and the fan after ignition turned off
  • Manually control the pump speed (e.g. for bleeding or testing)
Old 09-21-2013, 12:10 PM
  #92
Welwynnick's Avatar
2006 S600
More Intercooler Pumps You Didn't Know About
I've been learning a lot about intercooling in this thread:
https://mbworld.org/forums/m275-v12-...n-pumps-5.html
But other people have been doing some fantastic work as well:
http://www.lingenfelter.com/LPEforum...esting-results
http://caddyinfo.com/wordpress/gonna...ling-motorama/
Although these tests were performed on different cars: Mercedes, Cadillac & Chevy, there's a very clear conclusion to be had, and a new direction to look for suitable IC pumps.
IC systems are quite unlike engine cooling systems (or buckets of water for that matter). They're all HIGH RESISTANCE systems, so they need a lot of pressure to achieve good flow. Many pumps are rated for open flow, with no load, but that's almost totally useless for chosing an IC pump. If you want to use a single figure, the static pressure (maximum head) gives a better indication of improved performance, but pumps are more complicated than that, and you really need proper flow vs pressure curves, which is where the Lingenfelter tests are so useful.
There's a lot of talk about 20 gpm pumps, but 3-4 gpm is quite normal in the real world, and 5 gpm is a good figure. Its actually quite difficult to get even that high - I spent several days trying - and a high antifreeze concentration, an uncharged battery, or a tiny bit of air in the system, really knocks it back.
What this means is that pumps that are suitable for engine coolling, or that do well with the bucket test, aren't really suitable for IC systems. So that includes pretty much all Johnson, Meziere & Davies-Craig pumps. So that means that all the forum favourites, like the EWP-80, WP136, CM30 or even CM90, are no improvement on the Bosch. Many people swear by the Jabsco 50840, but even that's a high-flow/low pressure pump.
In my searches, I did find a couple of other likely 20gpm+ candidates - the Dayton 5PXX0 and the SURflow COMSV012D, but they give much the same performance as the above:
http://www.drillspot.com/products/13...ton_5PXX0_Pump
http://www.pumpvendor.com/media/shur..._DC_series.pdf
IC systems normally run at around 0.5 bar, and if you want more flow, you need a lot more pressure. So you need to look for pumps that do 1 bar or more, and I found a couple of real candidates. They have 15-20 gpm open flow, but they achieve up to 1.1-1.2 bar, and the installed performance will be better than ALL the above.
The first is an identical twin big brother to the Jabsco 50840, called the 50860. It looks and cost about the same, has less open flow, but much more power, pressure and installed flow.
The other I never heard of before - the FLOJET DC 40/10.
http://www.xylemflowcontrol.com/mari...-item14187.htm
http://www.xylemflowcontrol.com/file...43000-0858.pdf
http://www.aquaintl.com/product_deta...6&item_id=3339
http://www.xylemflowcontrol.com/file...S_950-0676.pdf
They're both monster pumps, bigger even than the Renntech pump, and I would guess similar to the stock Stewart-EMP E2512A that Lingenfelter promote so effectively in the top thread.
Nick
Old 11-09-2013, 08:49 AM
  #93
Welwynnick's Avatar
2006 S600
Interesting update:
The CWA-200 that I use in my S600 is really being throttled by the IC's, so I decided to try a purpose-made IC pump instead.
I bought a CWA-100 / A0005000486 (subject of this thread) from my local dealer, and asked him to give me a list of the other applications.
These are the MB models and versions that it fits - its a surprisingly long list:
169-090 A-class
197-377 SLS-class
197-378 SLS-class
197-477 SLS-class
197-478 SLS-class
212-075 E-class
212-076 E-class
212-275 E-class
212-276 E-class
218-375 CLS-class
218-376 CLS-class
218-975 CLS-class
218-976 CLS-class
231-474 SL-class
231-479 SL-class
463-272 G-wagen
463-273 G-wagen
463-274 G-wagen
639-601 Vito
639-603 Vito
639-605 Vito
639-701 Vito
639-703 Vito
639-705 Vito
639-711 Vito
639-713 Vito
I've no idea what the Vito application is, but I believe its generally used as the IC pump for the turbo-charged AMG models.
It sounds like Mercedes have seen the light about the Bosch pump, leap-frogged the CWA-050 "BMW pump", and gone for broke with the best option across the board.
If they were developing the E55, SL55 or S600 now, this is presumably what they would have used.
Nick
NH_E63 (08-10-2022)
Old 11-09-2013, 11:18 AM
  #94
mertd93's Avatar
04 E55 B07
Originally Posted by Welwynnick
Interesting update:
169-090 A-class
197-377 SLS-class
197-378 SLS-class
197-477 SLS -class
197-478 SLS-class
212-075 E-class
212-076 E-class
212-275 E-class
212-276 E-class
218-375 CLS-class
218-376 CLS-class
218-975 CLS-class
218-976 CLS-class
231-474 SL-class
231-479 SL-class
463-272 G-wagen
463-273 G-wagen
463-274 G-wagen
639-601 Vito
639-603 Vito
639-605 Vito
639-701 Vito
639-703 Vito
639-705 Vito
639-711 Vito
639-713 Vito
I've no idea what the Vito applicaiton is, but I believe its generally used as the IC pump for the turbo-charged AMG models.
If they were developing the E55, S55 or S600 now, this is presumably what they would have used.
Nick
Did you install this pump yet and do you know the pin out and plug for this pump?
Old 11-09-2013, 05:37 PM
  #95
Welwynnick's Avatar
2006 S600
No; I only got it last night, and it will be some time before I can fit it.
The connector question was answered here, earlier in the thread:
https://mbworld.org/forums/5178168-post73.html
Nick
Old 11-09-2013, 07:21 PM
  #96
mertd93's Avatar
04 E55 B07
Thanks Nick, if you figure out the wiring please let us know, I would like to get this pump as well.
Old 11-10-2013, 03:57 AM
  #97
Welwynnick's Avatar
2006 S600
At the moment I'm using the larger CWA-200 pump with a customized Tecomotive pump controller. The pin connections are:
1. Battery
2. Control / ignition
3. Control ground
4. Power ground
The CWA-100 has a smaller connector than the 200, but I expect the pin-out is the same. I'll try to find out for sure.
Nick
NH_E63 (08-10-2022)
Old 01-05-2014, 10:29 AM
  #98
Welwynnick's Avatar
2006 S600
Hi Rockthemullet
Thanks for the offer - can you tell us what is the pin-out on the CWA-100 / MB 0005000486?
Is it:
1. Chassis ground
2. Control return
3. Control
4. Battery?
Many thanks, Nick
Old 01-05-2014, 03:16 PM
  #99
FlyByNight's Avatar
05 E55
Hey everyone... lots of awesome information here... but for those of us that don't get our hands dirty all the time, what is the EASIEST upgraded pump to install as opposed to just replacing the stock unit? Bought a 2nd 2006 E55 in another country (central America) and shops that know how to change the oil in this car are rare, SO I need to install it myself. Which means I need to buy it in the US and take it down here on a plane... and install with remedial tools. I know, I know.
Anyway, this used 2006 is great except for the heat soak after about 20 seconds of hard driving. So I suspect the pump. I changed the pulley and reprogrammed the engine myself with the Logic Lab kit (again, needed something portable), but the engine was cutting out before the mod. Now, more frequently because of increased temps.
Any suggestions would be greatly appreciated! I'm about to just replace the stock unit with another stock unit at this point.
Old 01-06-2014, 06:44 AM
  #100
Welwynnick's Avatar
2006 S600
If you want to replace a stock unit, be sure to use a -010 unit, rather than a -002.
Otherwise the AMG pump is a great option.
Nick
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: Intercooler Pump you didn't know about
