Trans fluid
Old 02-21-2017, 05:12 PM
e55joe's Avatar
2014 E63s,2004 E55, 2006 STS-V, 1969 Camaro RS/SS 396, 2012 Centennial GS Corvette
Trans fluid
Can i use mobil 1 synthetic as an alternative
Old 02-21-2017, 06:40 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
Mobile ATF 134 is the only trans fluid that meets current Mercedes spec from Exxon Mobile. Here is a link to the rest of the currently approved fluids.
https://bevo.mercedes-benz.com/bevol...236.14_en.html
Member Glyn M Ruck helped develop the current spec fluid and you should only use the current spec fluid as it is far superior to the old spec in every way (you probably should flush out the old stuff while you are at it. here is a pdf of that procedure https://mbworld.org/forums/attachmen...55-p-0100a.pdf). Do NOT use any fluid that says 'suitable for Mercedes' ONLY USE ONE OF THE FLUIDS ON THE LINK I POSTED.
For a more detailed reason why, just read through this thread where Glyn M Ruck thoroughly explains.
https://mbworld.org/forums/clk-class...722-6-atf.html
I know someone is going to post something like 'well I've been using Valvoline maxlife fine for the last 30k miles so do that.' DO NOT LISTEN TO THESE PEOPLE. Instead read through the link to the thread I posted as it very thoroughly explains why.
Old 02-21-2017, 10:34 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
No reason to save a little bit of money on non-recommended fluid when it can cost you a transmission later
Old 02-23-2017, 08:08 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
very well said i would stick with oem
