Baby 2017 Mercedes-AMG C43 Convertible Spied
By -
2017-mercedes-amg-c43-cabriolet-spy-shots--image-via-s-baldauf-sb-medien-1-(4)
Since 1993, in its nearly 25 years of production, the C-Class has never been made into a production convertible. Thanks to some spy shots from the good fellas over at Motor Authority, there is now proof that that’s about to change.
This slightly camouflaged C was seen puttering around recently. It is likely the Mercedes-AMG C43 Cabriolet, the little bro of the C63 Cab. The C43 is basically the new name for the C450 AMG, which was previously a model under the regular Mercedes-Benz name as an in-betweener from the base to the C63 (there’s also a GLE450 AMG, in case you weren’t confused enough). The 450 moved under Mercedes-AMG and is now going to get the 43 treatment. The first model range to get that was the 2017 Mercedes-AMG SLC43.
So, do you like what you see?
Chime in with your thoughts on the forum. >>
Via [Motor Authority]
Looking for a good deal on a new Mercedes-Benz? Get insider information here.
