How Mercedes-AMG Got 416 Horsepower Out of the M139 Engine
By -
Mercedes-AMG had to do a lot more than crank up the boost to squeeze more than 200 horsepower per liter out of its M139 turbo four-banger.
As AMG has grown more popular over the years, it’s also become busier. It no longer just enhances V8- or V12-powered Mercedes vehicles. It covers the entire spectrum and increases the performance of four-, six-, eight-, and 12-cylinder coupes, cabriolets, sedans, crossovers, and SUVs. The power mongers at AMG extracted 375 horsepower and 350 lb-ft of torque from the M133 2.0-liter four-pot in vehicles such as the CLA 45.
They managed to top that with the new M139 turbocharged 2.0-liter I4, which cranks out a maximum of 416 horsepower and 369 lb-ft of torque (in S tune). If you do the math, you’ll see that translates to roughly 208 horsepower per liter. In the video above, Engineering Explained‘s Jason Fenske tells us all how they accomplished the feat. We’ve done our best to streamline his already simplified technical breakdown below:
mbworld.org How Mercedes-AMG Got 416 Horsepower Out of the M139 Engine
1.) 180 Degrees of Spin: Mercedes-AMG took the basic layout of the M133 and rotated everything 180 degrees. For the M139, air enters the intake, which feeds it behind the engine to the inlet side of the turbo. That’s then routed up front through the air-to-water intercooler, through the intake and engine, back to the exhaust, and finally out the back of the car. According to Fenske, “Mercedes claims that by switching this around, they now have a shorter length and fewer diversions for both the intake and the exhaust.” Better breathing means better performance.
2.) The Three Bs: Bearings, Breathing, and Boost: The M139’s turbo uses roller bearings instead of journal bearings. Those new bearings create less friction and allow the turbo to spool more quickly and create better low-end torque.
The turbo‘s twin-scroll construction makes it more efficient at pulling exhaust gases out of the engine and pumping them through its turbine. Cylinders 1 and 4 breathe through one scroll and cylinders 2 and 3 breathe through the other one. Each cylinder’s exhaust pulse fires at a different time than the other cylinders fire theirs so exhaust gases are jettisoned out of the engine (instead of the pulses hitting each other and bouncing exhaust back into the engine). The M139 also generates more boost than its predecessor: 30.5 psi vs. the M133’s 26.1 psi.
3.) Deck Closed for Improvements: Open deck engine designs surround the cylinders with coolant circuits, but they do that at the expense of block rigidity. The M139 has a closed deck design that uses strategically placed holes to circulate coolant and help the engine withstand astronomically high cylinder pressures of approximately 2,320 psi – “over 300 psi higher than the 840-horsepower Dodge Demon engine,” according to Fenske.
4.) Port Star: By moving the fuel injectors, Mercedes-AMG engineers were able to install larger exhaust valves to improve the engine’s breathing. Variable cam profiles help even more.
A combination of port and direct fuel engine supplies the M139 with the amount of fuel it needs to produce its impressive amount of power.
5.) Do the Nanoslide: Instead of using solid cylinder liners, the M139 features spray-on liners applied by a twin-wire arc spraying process that Mercedes calls Nanoslide. Fenske says, “It’s very thin, it’s very wear resistant, and it has extremely low friction,” which makes the interaction between the pistons, piston rings, and cylinder walls much smoother. Tiny pores in the mirror-like surface of the liners help lubricate the engine with oil during operation.
*M139 photos courtesy of Mercedes-Benz.
Join the MB World forums now!
Derek Shiekhi's father raised him on cars. As a boy, Derek accompanied his dad as he bought classics such as post-WWII GM trucks and early Ford Mustang convertibles.
After loving cars for years and getting a bachelor's degree in Business Management, Derek decided to get an associate degree in journalism. His networking put him in contact with the editor of the Austin-American Statesman newspaper, who hired him to write freelance about automotive culture and events in Austin, Texas in 2013. One particular story led to him getting a certificate for learning the foundations of road racing.
While watching TV with his parents one fateful evening, he saw a commercial that changed his life. In it, Jeep touted the Wrangler as the Texas Auto Writers Association's "SUV of Texas." Derek knew he had to join the organization if he was going to advance as an automotive writer. He joined the Texas Auto Writers Association (TAWA) in 2014 and was fortunate to meet several nice people who connected him to the representatives of several automakers and the people who could give him access to press vehicles (the first one he ever got the keys to was a Lexus LX 570). He's now a regular at TAWA's two main events: the Texas Auto Roundup in the spring and the Texas Truck Rodeo in the fall.
Over the past several years, Derek has learned how to drive off-road in various four-wheel-drive SUVs (he even camped out for two nights in a Land Rover), and driven around various tracks in hot hatches, muscle cars, and exotics. Several of his pieces, including his article about the 2015 Ford F-150 being crowned TAWA's 2014 "Truck of Texas" and his review of the Alfa Romeo 4C Spider, have won awards in TAWA's annual Excellence in Craft Competition. Last year, his JK Forum profile of Wagonmaster, a business that restores Jeep Wagoneers, won prizes in TAWA’s signature writing contest and its pickup- and SUV-focused Texas Truck Invitational.
In addition to writing for a variety of Internet Brands sites, including JK Forum, H-D Forums, The Mustang Source, Mustang Forums, LS1Tech, HondaTech, Jaguar Forums, YotaTech, and Ford Truck Enthusiasts. Derek also started There Will Be Cars on Instagram, Facebook, and YouTube.
