Mercedes-Benz Owner Pepper Sprays VW Driver
Road Rage Is Bad Enough, but It’s Much Worse When You Add Pepper Spray to the Equation
Well, I think it’s safe to say this Mercedes driver won’t be landing any “Friendliest Person of the Year” awards after this move. Nope, not at all.
As a matter of fact, pepper spraying another motorist for cutting you off in traffic is the kind of thing that should earn you a little jail time — perhaps enough to rethink if you’re even worthy of driving such a vehicle in the first place. Even crazier, after watching the video below, which we stumbled upon in a Carscoops report, you get the sense that this probably isn’t the first time this guy has pulled a stunt like this.
The 1:40 dash-cam clip actually shows the entire incident as it unfolds, from when the Volkswagen Passat driver first cuts the Mercedes off in slow moving traffic. The Mercedes is then seen pulling up near the Passat driver, attempting to cut the VW off as the car slows down behind a semi. When the semi stops, the Mercedes driver casually hops out of the car and walks up to the VW, pepper spraying the driver though an opening in the window.
Crazy, right?
Chime in with your thoughts on the forum. >>
Via [Carscoops]
