190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Need Assistance - No Spark
Old Jul 7, 2005 | 10:38 AM
jondaboll's Avatar
77 300d, 92 190e 2.6
1992 190e 2.6 119k auto, roof ,leather.
I have no spark. Traced it to the ignition coil. Power goes in to coil but not out. Could there be a problem with the position pick up on the crank shaft? Also how would I go about testing that? and How do you test the coil? Washed motor a month ago (IDIOT) Before I put waterpump in. Please , I need some help...Thankyou
Old Jul 7, 2005 | 06:57 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Aren't you trying to sell your car anyway?
does anyone want to purchase a piece of ****! 92 190e loaded with 79,646 miles
Old Jul 8, 2005 | 09:16 AM
mctwin2kman's Avatar
Hey I answered what to look for on the other forum! Go read that!
Old Jul 8, 2005 | 01:54 PM
jondaboll's Avatar
Brilliant
You are brilliant! Thanks for reminding me about the 190 in my garage. I wish that I could wake up one morning, and itwas not there.
Yes its for sale! My Question is getting a spark! Again thank!
Old Jul 8, 2005 | 02:02 PM
jondaboll's Avatar
Thank you. I did have moisture in the cap. my vacuum lines are very old so I am replacing. They should be here in a couple of days.Checking rubbers now. I do have a spark now, drying the cap helped. It looks like a yellow spark and not that clean crisp blue. Maybe I should replace cap and rotor
Old Jul 8, 2005 | 03:33 PM
That is where I would start! Cap and rotor if they have not been replaced already! And hey wait til you get her running first before you sell her off! They are a labor of love, but well worth it in the end!
Old Jul 10, 2005 | 06:00 PM
jondaboll's Avatar
I sure do appreciate you assistance, Thank you. I ordered new wires, cap and rotor, Along with plugs. I will pick them up tomorrow at arizona auto haus. You said something about on the idle air controoler. "check rubbers" Sorry! Could you explain. Checking on my cd manual , to find nothing.. This car ran great before water pump went.Just after a washed engine carefully(DUMB IDEA). it ran arough , like water gotten into the distributer. After my pump is installed I am having this minor ordeal! I will let you know how it goes.. Thanks again
Old Jul 11, 2005 | 10:11 AM
Most likey the rubbers are still attached. But remove the air cleaner housing and check to make sure the rubber hoses are all attached under there. Cleaning the motor could have knocked one off! Thus causing a major air leak and thus your problems. The Idle Air Control Valve is under the air cleaner housing.
Old Jul 11, 2005 | 01:54 PM
jondaboll's Avatar
IThanks, I did notice the idle speed adjuster I think thar is what it is! has two **** plug, and intake lione and out. The in line is cracked. I am ordering that today. I hope my wires and cap get here. I Want to sell this 190 and get new wheels for my new Benz. 2003 SL500 Coupe. 11,250 miles. I will Put these items on as soon as they get here and give you an update.... Thanks again
Old Jul 11, 2005 | 04:46 PM
No Problem! When those pieces crack bad enough the engine will not start! Also if the intake boot between the Air Flow Meter and Throttle Body as well.
Old Jul 19, 2005 | 06:28 AM
jondaboll's Avatar
Position pick up sensor
Put new wires distributor, rotor, coil wire on. I have a good spark, Put the air cleaner on, fresh fuel added, Air cleaner looks good. The car seems that it wants to start, It gives a small backfire. Backfire is at the very first time I try to crank it, After that the revolutions will speed up upon trying to start every so often. I checked firing order plugs dist. Everything seems to be in order. There is one vacuum line that not sure of. it comes off the I believe the idle speed adjuster(see Pic). I think that line goes to the hose that is attached to the valve cover. The other thing is i took the position pick up sensor off to change water pump originally. Would that have something to do with what is happening. The manual is very detailed, Just does not tell me if that could be problem. I will look closer thru the manual. Does it have to be reset?Thanks for your help.
PS the red circle is the unit where the vacuum line comes off of, yellow is where the vacuum line goes.
Old Jul 19, 2005 | 10:46 AM
That is the Fuel Pressure regulator. The vacuum line goes over to the big rubber hoses that connect to the IACV and the intake. Should see a plastic looking connector that has a place to put it.
Old Jul 19, 2005 | 02:32 PM
jondaboll's Avatar
I wish I could find that stuff in the manual. Have the mercedes CD. Thank you
